Question about Air Tools & Compressors
Gardner-Denver D190 portable air compressor problems
When start it, it revs up, but as soon as goes to idle, it stalls.
4 Suggested Answers
  • 89 Answers
SOURCE: we are looking for a manual on both a gardner
I CAN PROBABLY HELP W/ THE GARDNER DENVER BUT HAVENT HEARD OF AIR TRACK. CALL ME AT C&A EQUIPMENT SERVICE @ 919-231-8700 OR EMAIL AT JBRIDGERS@CA-EQUIP.COM
Posted on Mar 14, 2009
SOURCE: We are looking for parts for a Gardner Denver air
i have the unit you need. i have the entire compressor. need 250.00 for the whole compressor, must be picked up phone 270-830-9894
Posted on Jan 12, 2010
  • 205 Answers
SOURCE: gardner denver air compressor is blowing oil, need
Is this a rotary screw compressor? If so, is it blowing oil out of the air filter or out of the discharge air lines? If it's blowing oil out of the air filter you have a oil stop valve or minimum pressure check valve bad. If oil is coming out of the discharge air you need to change the seperator.
Posted on Nov 16, 2010
I HAVE A GARDNER DENVER 25 hp MOD EBEFFD ser m90917. Is 1/4" line that goes into the side of the cooler is an air line or an oil line. I do know that it is a temp monitoring line. dont know which.
According to the diagrams for those, it appears to be an unloader line which means the compressor unloads after stopping via the center of the crank shaft. It would therefore be an air line.
Jan 27, 2017 | Cars & Trucks
Have a Gardner Denver Electra Saver 2 compressor and it is not getting power to the control unit to start?
Is this something new you just installed? Is it not getting electrical power to junction box? If your getting 220 volts of power to unit is there a reset button or reset protocol? Thank you Sylvia and good luck. Make sure breakers are on. Please consult an electrician to obtain your power issue.
Jul 13, 2016 | Gardner Denver Electra-Saver II EB000E...
Need manual for air compressor 5 rca
That is made by Gardner Denver under the same model number. I could not find a manual for it but here is their site. I would contact them and see if they can furnish you one.
Gardner Denver
Aug 25, 2012 | Champion International Champion 2 Stage...
Durango 4.7 starts will not idle and stalls with throttle open
Sorry take it to a dealer who have the right software to diagnose the problem,But first do check the engine breather pipes as i have had similar problems with earlier ford focus where the pipes in the front of the engine split and go soft causing very bad idle/run symtoms
Sep 22, 2017 | 2000 Dodge Durango
Gardner denver 450 pumping oil out. Did something let go and go down line, and or level to high lowered and still pumping maybe lower yet!!!
Hi alan, my name is John. Welcome to FixYa. try loosing the valve at the bottom of the tank and bleed all the water and stuff out until nothing comes out. Thanks for choosing FixYa....John
Dec 02, 2010 | Air Tools & Compressors
Gardner denver air compressor is blowing oil, need help
Nov 15, 2010 | Air Tools & Compressors
My '97 Kia Sephia has a stalling issue. It starts fine, and if I just let it sit and idle it has no problem, although it has started making a sort of ticking sound as it runs. As soon as I hit the gas,...
does it have a check engine light on? if so i would start with getting that code pulled most auto parts stores will do it for free. it could be any number of things that are going wrong with it.
vacuum leak, egr problems, faulty cps... ect
if you don't think it's safe to drive and you can't fix it on your own then i would suggest having it towed to a shop.
Jun 19, 2010 | 1997 Kia Sephia
We are looking for parts for a Gardner Denver air compressor. ADA 1006. We need piston rod and rings.
Your looking for a rebuild kit for a low production, high end compressor pump. You have two choices. The first is to search and maybe stumble across the parts you need, I have a better chance at finding the parts and I know it will take a while. The other choice is to contact a supplier for the kit. It will be a lot quicker. Trust me.
Try the link below. Just fill out the info and if it's available they will find it. In the mean time I will try a couple other sources and if I find anything I will post it here. The second link is direct to Gardner Denver.
Hope this helps.
http://www.aircompressorsandparts.com/Gardnerdenver.htm
http://www.gardnerdenverproducts.com/Compressors/SalesAndServiceLookup.aspx
Dec 24, 2009 | Air Tools & Compressors
Idle irratic
Here are some of the causes of surges, stalls at stops, slow idle speed, erratic idle speed, rough idle and engine hesitation (and other problems), it is in most cases the idle speed control air-bypass valve and or throttle valve and upper intake, these area's get full of gunk and combustion residue over the miles and cause idle issues (stalls, low idle) like yours, Get a can of intake cleaner from any local parts store, not carb spray, intake cleaner, it is made by a company called CRC, remove the air intake hose to the engine, hold the idle high so the engine won't stall, then spray the can of cleaner into the intake while keeping the engine running, use at least 1/2 the can, shut down the engine and disconnect the battery for 5 minutes, then restart and complete a number of mixed driving cycles, town, freeway, stop and go etc., after a few days the problem will go away as the system will relearn to the clean intake
Apr 11, 2009 | 2001 Chrysler PT Cruiser
We are looking for a manual on both a gardner denver air compressor and a Air track with hammer
Mar 10, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
151 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
