Question about Panasonic Lands Phones
Panasonic KX-TG5634 Display of handsets gone blank
Display on my Handsets is gone BLANK-just lighting up, how to fix it?
SOURCE: Panasonic KX-TGA101S base not charging.
PyroPC Man is right! Thanks!
Posted on Mar 18, 2008
  • 3 Answers
SOURCE: Handset voice very low and LCD display is blank
My 1740 handset volume was also low. As a shot in the dark I changed the speaker and it fixed the problem. I got a new speaker from www.panasonic.com .
Posted on Aug 13, 2008
SOURCE: Panasonic cordless handsets all say line in use
I had the same problem. Something makes the phone's memory get "stuck."  Take the battery out of the phone for a minute and then put it back. Then unplug the phone and plug in again. You need to do this with all extensions. The problem goes away.
Posted on Jan 12, 2009
SOURCE: Screen gone blank
I had the same fault with the handset losing it's display, phone worked great but could not see to access internal phone directory.
To strip down the phone you need a very clean hard plastic/granite
work surface and a small philips screwdriver and a small flatblade screwdriver.
First of all remove the battery cover and the batteries, put them in safe spot on the work surface (Tip: take the top cover off an aerosol tin to use for holding the screws and small parts you remove)
Remove the front facia by gently teasing it away from the body of the phone, there are 2 plastic lugs either side of the battery compartment, ease them towad the edge of the casing to release the front facia, it should then unclip easily with your thumbnail.
Near the edge of the phone you will see 2 small screws, remove them carefully and set them aside, please note these are longer than two other screws you will encounter later in the disassembly.
Seperate the two main parts of the case from the battery compartment end of the phone and work towards the other end, there are two release points on the outside of the casing, gently insert a small driver into the recess whilst applying a small amount of lifting pressure between the two casing halves and it should spring open. (Note that the case hinges on a clip at the top edge of the phone which helps with its re-assembly later.)
Please be aware that the speaker wires are soldered to the main board and should not be disconnecetd or cut!!!
At the battery end of the phone is a small strip of white plastic tape covering two short screws, these hold the cradle charging contacts to the circuit board, remove them with the metal contacts and keep them safe.
With a little coaxing the rest of the phone should now come out of the casing. Be very carefl not to touch any of the gold contacts on the circuit board or the buttons may not work, you may gently clean these using a dry microfibre cloth. DO NOT SCRUB THEM, simply rub gently a few times.
Unclip the display holder andnote the earpice comes loose, this can be fed through the plastic holder byturning it sideways and pressing it through. DO Not damage wiring!
You should now see the tiny ribbon cable on the display itself, either side of it are a thin white plastic lug which can be slid carefully away from the edge of the display to release the cable. Remove cable gently and re-insert it back into the connector it came from, ensuring it is fully home and is perfectly aligned at right angles to the display, then carefully slide the retaining lugs back into place which will lock the cable back into place.
You can now re-assemble the phone, carefully.
It worked for me, hopefully it should for you unless the display is damaged prior to or during disassembly.
Posted on Mar 09, 2009
SOURCE: Panasonic kx-tga101cs incorrect voicemail message
Press and hold "Clear" until it beeps. It will clear the invalid voice mail msg.
Posted on Jul 28, 2009
Manual for Panasonic kx-tg6521R cordless with answering machine 2 handsets
It is this one. The handsets are the same on the base unit and the extensions.
KX TG6521 Cordless Panasonic
Jul 09, 2016 | Panasonic Lands Phones
Yellow light constantly flashes on all handsets
Yellow light constantly blinks on top of all the cordless phones
www.faqqq.com/.../yellow-light-constantly-blinks-on-top-of-all-the-cord...
Question Product: Panasonic KX-TG5432 Digital Dual Cordless Telephone Question Details: Yellow light constantly blinks on top of all the cordless phones The.
Panasonic KX-TGP550 Normal Status Lights
www.statuslights.com/panasonic/panasonic-kx-tgp550.html
Red (Rapidly Flashing), The Base Unit is paging handsets. (KX-TGP-500 only). Amber(Solid), The Base Unit's IP address may conflict with the IP addresses of ..
Jan 16, 2016 | Panasonic KX-TG7641M KX TG7641M KXTG7641M...
Blank lighted screen
Phone is defective seek help of service center .
Nov 16, 2015 | Panasonic KX-TGA101S Cordless Handset
Handset display lights up but is blank
If the batteries in handset are old then replace it. Follow battery change instructions in this manual.
http://service.us.panasonic.com/OPERMANPDF/KXTG5631S.pdf
Sep 12, 2014 | Panasonic Lands Phones
Led display does not work on my panasonic 5.8Ghz phone KX-TG5632
I just spoke to Panasonic Tech Support about the LED screen being blank. FYI its blank on both my handsets - one which I never even use. He made me do a few button presses, etc but nothing worked. So he tells me I have a "loose connection on the LED" so I must have dropped the phone or something. I said NO, I never dropped the phone, and one of the handsets I never even used - and its happening on that one too. So bottom line you have to take it to a Panasonic repair center at your own expense if its over the one year warranty - for what I personally think is a flaw on their phone design. I think after so much time the LED screen just goes away...since its happening on both handsets, and neither of them were dropped. Its a shame because the phone works fine, but I need the LED screen for the mute button, etc. So my solution for you is to stay away from Panasonic phones and the lame customer support, and go buy a different brand.
Apr 02, 2011 | Panasonic KX-TG5632 Phone
Display on the cordless is completely blank
You could buy a new handset from :-
http://cgi.ebay.com/PANASONIC-KX-TGA560M-5-8-GHz-CORDLESS-HANDSET-/230557643171?pt=LH_DefaultDomain_0&hash=item35ae4e71a3
The cost of the handset is less than $25. If the unit is under warranty ( less than i year old ), you could contact the service center and get it replaced without any cost.
The average cost of repair is around $75 on this set for display. That is one of the reasons why we recommend buying a new handset. This is a common problem on most of the handsets. We did everything that we could - swapping batteries and making sure that it is properly registered.
I know, it is not a good new, unfortunately there is no reset button unless you take it apart and look for a loose wire or connection. That is the only possibility.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 02, 2011 | Panasonic KX-TGA560M Cordless Expansion...
Own model KX-TG6031CM. Handset display is lit up
need access code to retrieve messages for kx-tg6031cm panasonic phone
Jan 23, 2010 | Panasonic Lands Phones
I have the panasonic kxtc1175bxb cordless phone pair the handset
sorry, it seems that they have no manual for this model online yet. however, the procedure to reset handsets might work if you go to page 35 of the manual ("http://service.us.panasonic.com/OPERMANPDF/KXTG1032.pdf") good luck!
Feb 04, 2009 | Panasonic KX-TG1033S Cordless Phone
Feb 11, 2007 | Panasonic KX TC1740 Cordless Phone
Lands Phones Logo
96 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
