Question about TP-LINK TLMR3420 300Mbps Wireless N 3G Router UMTSHSPAEVDO USB 24ghz Retail
Trouble connecting ZTE Vodafone k3565z usb modem to tp-link 3G router
The modem and sim work fine when plugged directly into the laptop, but the sim card fails to connect when in the 3G router. The router says it has successfully recognised the modem and the model is listed as supported. I have installed latest firmware, but still no internet connection. Router takes a long time to id the modem and then a long time trying to connect. Eventually gives up. Could it be the associated software that loads automatically first (after quite a wait) on a laptop, is interfering with the modem-router link?
  • 98 Answers
SOURCE: My tp-link TD-W8950ND 150Mbps Wireless Lite
this is because your modem is out dated your better off getting a new one
Posted on Mar 20, 2011
male_28_cam
  • 1555 Answers
SOURCE: I have a TP-Link TL-WR941ND
Can you kindly let me know the settings on your modem and router. Whether they are connected via using bridging mode or ppoe mode. In order to find this simply enter 192.168.1.1 in your browser and enter user id as admin and password as admin and hit enter. In advanced lan settings just click on first right hand side edit button and click next and see wether ppoe is selected or bridging is selected in order to ascertain the ip of wifi modem simply click on start button when connected to internet via wifi modem and select run type cmd and hit enter in the black window type tracert www.google.com wait for few seconds the first ip in the list will be your modems ip. use the same method as described above to find which way is it connected to server bridging or ppoe.
Posted on Jun 15, 2011
SOURCE: After using TP-Link TL-R480t+ Router Video streaming from internet at sites such as youtube does not work at all
Hi ,This is Clare Su from TP-LINK support technical force.To you issue,I have the following recommendations:1. try to use only one line to connect to the internet,and see if you can watch the video on youtube2.if you can see the video with one line connected to the internet.Then,you can get another internet line with the router.And you can try to set the rule to the website: youtube, let the flow from youtube come in and out just from one wan port.if you can't solve the issue with my recommendation,you can email me. I will help youas soon as possible.My email is:clare.su from tp-link.com
Posted on Nov 23, 2011
nasro2
SOURCE: TP-Link TL-WR642G recovery after failure upgrade to latest firmware
may find this page helpful. http://www.dd-wrt.com/wiki/index.php...om_a_Bad_Fl ash Its not for the TP-Link router but the same principle could be applied to you with the correct firmware. Its worked for me on more than a few occasions. Providing you can ping the router via a lan cable then the chances of recovering it are very high.
Posted on May 22, 2012
maxcarson
  • 7627 Answers
SOURCE: Internet connection speeds much slower when LAN is routed through a router as opposed to directly linked to the modem?
Depending on the Wireless device, speeds differ with the protocol a bit. A cable/hardwire connection will always be a faster. I would not get to hung up on speed test software, there are many factors when using different one's , your speed will vary wildly, form one to another. Your dealing with ALL the outside ISP equipment you have no control over. If you go to 10 different "Speed Test" software websites, you will get 10 different Uploads speeds, and 10 different Download speeds. Most of this is due to Outside equipment. You just may be Obsessing over something you can't control, but I could be wrong. Maybe your ISP is "throttling" your signal? http://www.pcworld.com/article/158552/check_ISP_speeds.html
Posted on Dec 29, 2012
L cannot get internet when connected to my router, but l get internet when connected to modem directly.
Your ISP allows only one device to connect to their network.
When you change devices (router versus computer),
you need to power-off the ISP's modem, and unplug it.
Connect the router to the modem, and connect your computer to your router.
Plug the modem back in, and the modem will "forget" what device was previously connected.
Feb 18, 2015 | BestPriceCables TP-LINK Ultimate 300Mbps...
Zte mf 190
ZTE MF 190 is compatible with W8968
Source : http://officeneeds.sulekha.com/tp-link-td-w8968-3g-dongle-support-data-card-worldwide_604863_blog
Apr 16, 2014 | TP-Link Technologies TP-LINK TD-W8968 -...
I have a TP LINK router, it transmit signal properly. the problem is when the 3G USB internet modem is fixed into it, it does not send internet signal so the laptop shows TP Link signal: excellent, but no...
To solve your problem:
go here
http://www.tp-link.com/us/article/?faqid=92
Basically what you have done is plugged it in but did not set up the router on a static or dynamic IP address.
Once you have established the IP address of the router and it is recognized by your ISP device (DSL, Cable, Satellite modem ....etc etc.) then you have to decide which device will be the DNS server and assign IP address to all the wireless devices that connect to it.
Lots of things can be wrong. You need to follow the steps on the set up link i gave you properly and in the correct order
Oct 23, 2013 | Computers & Internet
TL-MR3420
insert your 3G Card adapter to the USB port and thenuse your PC come to http://192.168.1.1 log in to the admin with name admin, password admin .
Open the operating status, it will show being identified, waiting about 20s it will done. else if it can't be recognized. You need to set the BIN file by you self, you can download the file from www.tp-link.com
Then set it step by step as it show
May 02, 2013 | ASI Tp-link Tl-mr3420 300mbps Wireless N...
ZTE MF190 Dialing problem
I have a unlocked ZTE Mf190 USB-Modem. When I put the SIM card in it and connect it to the computer, I am able to connect to 3G Internet via beetel connection manager. Is it also possible to send and receive SMS. But when I try to make a voice call on beetel voice call panel, I receive this error message "Dialing failed! Please try again!" . And also when I use another phone to call the SIM card line number that I put in the USB-Modem, I receive busy tone
Mar 31, 2013 | ZTE Mf190 Unlocked 3g Gsm 7.2 Mbps...
3G usb modem wont connect to internet through wireless router
Sure you can that. 1. you have new internet connection. need to configure the router according to internet connection type. it could be manually ..
2. set the wireless settings on the router again manually.
then try to connect the router.
If you need my help
the send me some information about the network.
1. when you connect your pc to modem what ip address you get.
2. what ip you get when u connect your pc to router. make hard wired in both condition.
and possible send me your email add.
Dec 23, 2012 | Computers & Internet
How can i unlock my zte modem
First you will need to find out the whole name to the product you have ....
Like for example ....is it a ZTE K3565Z USB Modem or an ZTE MF100 USB Modem...
Because you might need to look up the default username and password (aka Backdoor username and password).
So once you have that....I'm pretty sure it should have a tiny hole where there a button to reset the product ..... (Make sure if its a usb you plug it to the pc so it get power then try to press the reset button to hard reset)......
And if you dont find the default username and password then the hard reset should do it .......
Please leave a testimony and vote!!!
Also feel free to ask more questions.......
Apr 05, 2011 | Computers & Internet
Trying to connect a ZTE K3570-Z vodafone modem to Netgear 3G router MBR624GU, but am told modem not supported. Have tried to download latest firmware, but still says not supported. Does this mean that i...
Sort of. It looks like Vodafone doesn't want people using routers with this device. You may be able to get around that if your router has the 'spoof mac address' functionality, but I imagine that's against Vodafone's Terms of Service.
Mar 05, 2011 | NetGear MBR624GU Wireless Router
TP-LINK TLMR3420 300Mbps Wireless N 3G Router UMTSHSPAEVDO USB 24ghz Retail Logo
171 people viewed this question
Top TP-LINK Computers & Internet Experts
Martin Murray
John Anderson
John Anderson
Are you a TP-LINK Computer and Internet Expert? Answer questions, earn points and help others
