Question about Maytag Neptune MAH5500B Front Load Washer
Error code 5h
Battery charger for Challenge drill
http://argos.scene7.com/is/content/Argos/2580580_R_D001pdf
Here is the customer helpline for this product:
0345 640 0800
Thereer is an 18V charger for another Challenger Extreme drill but I do not know about its use with your designated drill. I notice in the documentation 2 x 1.2 Ah Ni-Cd battery back
-1 x 3-5h charger
Here is a smart charger which is 3-5h:
It shuts off when the batteries are charged.
http://www.uniross.com/products/3-5h-lcd-charger
May 30, 2017 | Miscellaneous
SH OR 5H error code on my smeg induction and no heat
I have the same problem and can't fix IT!
did You Solve the problem?
Dec 01, 2016 | Smeg Cooktops
My Frigidaire Stainless steel FFHB2740PS D.D. has an error code that reads 5H. What is wrong?
I appreciate your inquiry, friend!
Based off the information you have provided your Frigidaire dishwasher is displaying an error code of "5H". That appears to be the time remaining on your wash cycle. Typically an error code would be displayed with a number and an "E". What is the current problem with your dishwasher? Are you getting long wash times? There is a sensor inside of your dishwasher that reads how dirty the water is, if your dishwasher continues to circulate dirty water it will tell that sensor to continue washing. You may want to check your filter, which is located at the bottom of the tub, for any debris. Additionally, if your drain hose is restricted it may be providing dirty water back into your tub. I hope this information is helpful to some degree. -Matt
Feb 24, 2015 | Frigidaire Dishwashers
What does a 5h code indicate
The GE dishwasher error codes I have seen start with a letter (usually "C") not a number. I suspect that this isn't an error, but an indication that you have activated the system to delay starting the dishwasher. I believe 5h represents a 5 hour delay. Pressing the "Delay" button should cycle through the different selections and eventually bring it back to Zero.
Feb 07, 2015 | GE Dishwashers
Error code 5H whirlpool front load washer, what does that mean.
Water temperature sensor control error:
• Check the Water Temperature Sensor, Heating Element and Element Relay
• Check connections to the Sensor, Heating Element and Relay
Jan 11, 2015 | Whirlpool Duet 3.8 cu. ft. Front Load...
Freezer error and code is 5h it can not freezer
The cooling coil inside the freezer compartment is probably blocked with ice and frost due to a malfunction in the self defrost system.
Oct 02, 2014 | Refrigerators
5h error code frigadaire French door
Got a problem with oven lightiing and not staying on the model number FG50t11w took plate out to see flames it occassioally it does stay on.
Oct 24, 2013 | Refrigerators
Induction hob not heating up. What does 5h or SH error code indicate?
if they are not steel bottomed pans they will not work with induction hob test them with a magnet
Apr 07, 2013 | Smeg Cooktops
I need the key code for FORD MONDEO 6000 CD RDS EON and ford mondeo 2001 model engine no CHBA1B41415A. If possible.
then it comes dp mv 5H then it comes 09--00--00 does anyone have the code for this plz my email is khhove@hotmail.com
Jan 28, 2011 | Car Audio & Video
Maytag Neptune MAH5500B Front Load Washer Logo
32 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
