Question about Taylor Measuring Tools & Sensors
Lost my instructions. I installed the batteries and I can't get it to sinc up
Honeywell ct3200 thermostat won't turn on
DON'T BUY A NEW ONE JUST YET! IF THE BATTERIES DIED & THERMOSTA LOST POWER, IT MAY HAVE LOST IT'S MEMORY. IT MOST LIKELY WENT BACK TO FACTORY DEFAULT SETTINGS, & NEEDS TO BE RE-PROGRAMMED THROUGH THE INSTALLER SET-UP MENU. HOPEFULLY YOU HAVE THE PAPERWORK FOR THE THERMOSTAT STILL & CAN POSSIBLY DO THE SET-UP YOURSELF. IT SHOULD HAVE STEP BY STEP INSTRUCTIONS FOR THIS IN THE INSTALLATION GUIDE (NOT THE OWNERS MANUAL)
Oct 13, 2012 | Honeywell Programmable Thermostat Heater
How to open battery compartment on remote
That clear plastic tab was there simply to keep the battery from making contact and running down.Since you declined to specify a make or model I can't give you definitive instructions. Can you find the outline of the battery cover? There's probably a set of grooved ribs on the cover, possibly with an arrow. If there is an arrow, put your thumb on the ribs and push in that direction. If there isn't an arrow you may have to try both directions if it's not obvious which way it's supposed to go.If you need further assistance feel free to reply to this post, but also be sure to specify the make and model of whatever device you're trying to open.
Apr 22, 2012 | Audio Players & Recorders
My microwave oven is dead. Apparently the fire protector blew. How to locate and how to replace?
Since you didn't mention the model number, I have to be kind of general.
If you mean the flame sensor or oven cavity thermostat, they are usually located on the top of the cooking cavity, so you would first have to remove the oven from the wall mount if it's an over the range type.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
If for some reason you don't still have your installation instructions, y
ou can download GE owner's manuals and installation instructions here.
You can download owner's manuals and installation instructions for several brands (including Amana, Jenn-Air, Kitchenaid, Litton, Maytag, Roper, Tappan, Thermador and Whirlpool) here.
You can download Frigidaire owner's manuals and installation instructions here.
You can download Samsung over the range microwave installation instructions here.
You can find links to other brands and find helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Then you can remove the outer cover to access the parts.
Sep 29, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Hi, I'm trying to install a Panasonic Printer KX-MB771 but I have no disc, can you help please. Thanks Corinne
Hey Corinne, to install a printer on your computer all you need is the driver for your according printer, since you have lost the Installation disk you can always download these drivers from the internet. After you've downloaded the drivers plug in the printer into your computer and run the installation. Follow the instructions and you should be good to go.
Here is a link where you can download the drivers for KX-MB771 for all Windows Operating Systems: http://drivers.downloadatoz.com/8128,panasonic-kx-mb771-mb773-mb781-mb783-driver-multi-function-station-1-11-windows-9x-me-nt4-2000-xp%28x32-x64%29-vista%28x32-x64%29-english/downloading.html
Have fun :)
Aug 19, 2011 | Panasonic Office Equipment & Supplies
My bioaxxis bd1 finger print deadbolt lock had to have the batteries changed. I removed the batteries and left the batteries out for a day. Once I installed the batteries, the lock would not work. I get an...
Here is the link to the website for the manufacturer, Axxis Biometrics:
http://www.axxisbiometrics.com/products/locks/deadbolt-fingerprint/bioaxxis-bd1/
I want you to have that because if all else fails, you'll have the contact information for further assistance.
Here is the direct link to the installation and programming instructions, which includes the beep codes. You likely lost the programming when you left the batteries out for such a long period:
http://www.axxisbiometrics.com/images/upload/File/pdfs/BD1_Complete_User_Manual.pdf
Notice that the above is a .pdf filetype. That means that you need to have Adobe Reader or similar installed on your computer to view it. So if you are unable to view the file, download (for free) and install Adobe Reader first. You can get it here:
http://get.adobe.com/reader/
Hope this helps. Good luck!
Aug 08, 2011 | Deadbolt Bioaxxis Bd1 Biometric...
Don't really have a problem. Lost the Instruction manual for machine looking for another.
Can't help much since you didn't include make and model info. Once you have that, just enter it in the search window with the addition of 'manual.'
Aug 07, 2011 | Vacuums
I lost my instructions to my lock, and I need to change my codes but i don't know how.
Here is the link to the installation and programming instructions for the 909-15 lock:
http://s7d5.scene7.com/is/content/BDHHI/kwikset-smartcode
It is a PDF file format, which requires that you have Adobe Reader installed on your computer to display properly. If you don't have it--http://get.adobe.com/reader/
It is a good time to replace the battery if you haven't done so already! Please carefully follow the programming instructions, because they can be tricky. If you goof up, simply start over.
Jul 02, 2011 | Kwikset 909 909-15 Satin Nickel Smart...
We are trying to remove the battery from our 2000 Jeep Grand Cherokee, but it feels like it is screwed in? We've searched everywhere but can't find anything. Any ideas?
This is a picture (not great quality, sorry) in the Battery replacement section of my Haynes Repair Manual for Jeep Cherokees 1984 thru 2000. Since you probably can't read the instructions they are as follows:
1. Caution: Always disconnect the negative cable first and hook it up last or the battery may be shorted by the tool being used to loosen the cable clamps. Disconnect both cables from the battery terminals. (yes, I know most people know this, but it's in the instructions. Better to be safe, than sorry)
2. Remove the battery hold down clamp. (refer to the photo - Instructions under the picture of the battery state: Unscrew the nuts (#1), remove the bolt (not visible in the photo) and lift off the locator bracket (#2), then pull the hold down clamp (#3) off the battery.
3. Lift out the battery. Be careful - it's heavy. (no brainer again.)
4. While the battery is out, inspect the carrier (tray) for corrosion.
5. If you are replacing the battery. make sure that you get one that's identical, with the same dimensions, amperage rating, cold cranking rating, etc.
6. Installation is the reverse of removal.
I hope this helps.
May 01, 2011 | 2000 Jeep Grand Cherokee
I need instructions on setting the time on my Wave Ceptor 4756 142A. Recently replaced batteries and lost manual.
browse through my tips and you will find link for all Casio watch manual downloads.
Sep 28, 2010 | Casio Watches
Measuring Tools & Sensors Logo
Top Taylor Measuring Tools & Sensors Experts
jhnolson
rdjagger
Are you a Taylor Measuring Tool and Sensor Expert? Answer questions, earn points and help others
