Question about Nokia 6255i
Nokia 6255i keypad problems...PLEASE HELP!
I spilled a tad bit of water on the counter and my phone got a little wet, I thought it was just water on the front and not even close to any of the keys, but everything works on my phone except 4 keys...the send/end key and the top 2 keys up from those (navigateing buttons) I have tried everything to dry it out (im still not sure if it was even wet) and they still don't work. I can dial but i can not send. PLEASE HELP any suggestions? Or is it done?
  • halfpimp Dec 19, 2007
    I don't think my phone even got wet, just a little humidity, but now my nav keys end all functions, and the volume is stuck on low. I can pull up the menu, but cannot select a function. Also, it seems to have reset to default settings. Anyone seen this before?
  • 67 Answers
If you manage to open the phone you go to the face plate were the key pad is possitioned and clean it with isoprophyl alcohol that can curethe problem . advice by dogy
Posted on Dec 21, 2007
  • 44 Answers
Hi....how good are you opening phones? ok say you open the phone under your keypad strip there will be corrution you need to clean that with ipo or 100% alchol base solution and that should be it. or you could post me it and i can do it for you http://www.mobilephoneservicecentre.co.uk/ Thankyou MPSC
Posted on Jul 05, 2007
SOURCE:
I have a nokia c5 mobile, everytime i'm on the phone to someone the volume during the call is very low though the volume is maxed out. This did not happen before.
If you spilled water or any drinks or liquid on your cell phone, or if it was in the bathroom while you were taking a shower, it is possible that the audio is damaged. I spilled a little bit of water on my cell phone and had the same problem.
Jul 24, 2011 | Cell Phones
My nokia 5130c kepad is not properly working that the key is 6,9,# is not properly working
Thanks for writing Fixya. I am Marion and let me help you with this.
There are reasons why your phones keypad is not working, first, have you tried re aligning your keypad if it fits exactly on the button, also, you may try pressing the keys without the keypad tofind out if the problem is just on the keypad or on the phones hardware already. Also, the keypads functionality may affect if it had a water spill or had dropped previuosly.
Jun 24, 2011 | Nokia 5130 Cellular Phone
Keypad problem for nokia 3250
hello dear, My 3250 keypad have a problem please solved this and help me my problem is my 3250 joystick is not moving now what shall i do shall I renew my Set or change the board
May 13, 2009 | Nokia 3250 Cellular Phone
LED Problem
try clining it using brushteeth and a lilbit of medical alcohol
the n dry it witha hair dryer teh tell me what u got
plz do rate this post
Sep 24, 2008 | Nokia N73 Cellular Phone
Nokia 6255i mini screen light won't go off
how can i get the keypad ights on nolia 6255
Feb 19, 2008 | Nokia 6255i
REPAIR NOKIA 6255I
bagaimana sih format nokia 6255i, menggunakan *#7780# masih aja tidak hilang applikasi yang ada di hp
Jan 17, 2008 | Nokia 6255i
Nokia 6255i (or 6256i) Verizon
check the tracks of mic to headphone
Dec 20, 2007 | Nokia 6255i
Some of the parts on my keypad do not glow
send to shop to fix or change you led on keypad
Aug 02, 2006 | Nokia 6255i
3 buttons on Keypad don't work
If You haven't already, open the phone remove the battery and SIM. I believe you can also remove the front face plate and key pad. Make sure the contacts behind the key pad are dry as well as the underside of the pad itself. Leave the cover and face plate off to allow to dry for as long as possible. If the phone was too wet it may not recover. If it does not you will have to replace it. The cheapest option is a go phone. You can get the Nokia 6010 refurbished online at Cingular for $29.95 and use your current SIM and will be good to go. When you order You will need to select a go phone plan but you do not need to activate it. Good Luck
Mar 19, 2006 | Nokia 3595
Nokia 6255i Logo
107 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
