Question about Canon imagePROGRAF IPF710 Printer
E198-401E I'm getting an E198-401E error on startup
Have error with 4600 loading descriptor 1 ...done on startup. Can't figure out why
If you want to know what this is the error code is related to
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured Right click on the error message select properties you will see all details about the error or click start type in event viewer press ENTER you might be able work your way through the problem
Jan 03, 2013 | Dell Dimension 4600 PC Desktop
Why does this come up? There appears to be an error with your installation. Please reinstall the application. Always pop up everyone I
If this error appears every time you start the computer, then there is a program in your system start up that isn't properly installed. I can't tell you which program without more information. A quick search shows that this is a common problem with DriverCure and FileCure. Uninstall/reinstall them if you have one of these programs.
If you don't know which program it is, then you need to go through your startup programs one by one.
Press "windows key + R" to bring up the run dialog box.
Type in "msconfig" and click "OK."
If the UAC dialog box comes up, click "Continue."
Click on the "Startup" tab.
It will display a list of every program that runs when your computer boots. Uncheck the first box for the program that you think might be causing the problem and then click "OK."
A box asking if you'd like to restart your computer will appear. Click "Restart Now."
A dialog box will appear notifying you of changes to your startup, click "OK" and msconfig will reopen.
If the error reoccurs, then uncheck the next item on the startup tab and repeat until you find the one causing the error. Make note of the name of the last thing you unchecked and uninstall/reinstall that program.
To get rid of the startup notification box, simply check "Don't show this message..." before clicking "OK"
Oct 22, 2012 | Computers & Internet
Bootmgr missing error on startup
There are a number of possible causes for BOOTMGR errors, including the most common "BOOTMGR is missing" error message.
The most common reasons for BOOTMGR errors include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors an outdated BIOS and damaged or loose IDE cables
Anothe reason you might see BOOTMGR errors is if your PC is trying to boott from a hard drive or flash drive that is not properly configured to be booted from. In other words, it's trying to boot from a
non-bootable source.
This also would apply to media on an optical drive or floppy drive that you're trying to boot from.
make sure there are no disks in cd floppy usb drives
How to Create a Windows 7 System Repair Disc:
http://www.sevenforums.com/tutorials/2083-system-repair-disc-create.html
"This will show you how to create a Windows 7 system repair disc to use to boot to the system recovery options if you don't have a Windows installation disc, can't find your
Windows installation disc, or can't access the recovery options provided by your computer manufacturer."
or
If you do not have access to either disc: Windows 7 - Repair Disc download
http://neosmart.net/blog/2009/windows-7-system-repair-discs/
a) Insert the Windows 7 System Repair DVD or Installation DVD and reboot.
b) Select the correct keyboard input method and click 'Next'.
Note: If you are using the Windows7 Install DVD then at the 'Install Now' prompt (Do not pick the Install
Now option) instead choose the 'Repair your computer' option located in the lower left of the dispay.
c) The System Repair tool will search for a valid operating system and will report that "Windows found problems with your computer's startup options. Do you want to apply repairs and restart your computer?"
d) Click 'Repair and restart' and reboot again to the Windows 7 System Repair environment.
e) Click 'Next' at the keyboard selection prompt and when the 'System Recovery Options' screen appears verify that the "Use recovery tools that can help fix problems starting Windows" is selected.
Note that on your Dual Boot system there now should be only one operating system listed. Click the 'Next' button.
f) Now from the menu list select the 'Command Prompt' option.
g) At the DOS prompt type the following three commands:
bootrec.exe /fixmbr
bootrec.exe /fixboot (may return an 'Eliment not found' message)
bootrec.exe /RebuildBcd
h) Close the command prompt window and click the 'Startup Repair' option.
i) The repair process may take some time, so wait until the process completes at which point you will see two messages "Windows cannot repair this computer automatically" and "Startup Repair cannot repair this computer automatically".
These messages are the result of the radical changes made by removing the other drive. Ignore the Send/Don't send options.
J) Close this message window by clicking on the X in the upper right corner of the Send/Don't send window. Next click on the 'View advanced options for system recovery and support' option and from the main menu once again click 'Startup Repair'.
This time the repair process may only that a few seconds and when prompted "Startup Repair could not detect a problem", click 'Finish' and run the 'Startup Repair' option one more time, click 'Finish', and then remove the System Repair DVD and click 'Restart'. Reboot the computer.
hope this helps
Oct 09, 2012 | Dell Studio 1737 Laptop
She gets an error message when booting up:: Fail to load language file
Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig. Go to Startup tab and uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running.
This just disables them in startup. Programs will still load, but only when you initiate.
If this fails, even though this should fix it, download CCleaner (free) and clean your Windows Registry.
Oct 05, 2012 | Acer Aspire Computers & Internet
My A305-S6857 freeze every time when I tried to login. I cannot access to my desktop.
Try doing a startup repair by pressing F8 repeatedly on startup. On the options menu, choose 'repair my computer'. If this isn't successful you can try running your antivirus software in safe mode to check for any infections. Press F8 as before and choose safe mode. If this works, you can also check your event viewer to see if there are any system errors recorded: control panel>system and security>administrative tools>event viewer. Expand the critical and error menus under 'summary of administrative events' You can double click on an event for further detail and the event ID which may help you troubleshoot the problem further.
Apr 03, 2012 | Toshiba Satellite A305-S6857 Laptop
Error 03 thermal fuse open
if not getting full voltage to ignitor possible bad fenwal
Sep 03, 2017 | Pentair Minimax NT Heater
When i switch off power and restart the pc i get error 'cmos/gpnv checksum bad' and sometime 'cmos setting wrong press f1 to set defaults or press f2 to enter cmos setup'. I replace the...
sir have you tried clearing the jumper settings. if it still persist remove power supply of board and cmos battery for 5 mins. Then try to startup.
Sep 14, 2011 | Asrock P4I45GV...
I keep getting gfxui stopped working .error messag
here the resolution to the problem:
Start ==> Run ==>type 'msconfig'
Go to Startup tab
UNCHECK 3 things: dldtmon.exe, dldtmon and DataSafeOnline
Reboot.
PROBLEM SOLVED.
May 12, 2011 | Samsung Computers & Internet
Canon imagePROGRAF IPF710 Printer Logo
53 people viewed this question
old marine
old marine
