I have a broksonic drvcr900 that i purchased new. It did not come with a manual and I have been unable to download one. I have never been able to dub from vcr to dvd and need to know how.
My second question is can you dub without the remote
-   I have a broksonic DRVCR-900A that I purchased new. Cannot find the manual. How do I change to time on it? We switched to Daylight Savings Time on Sunday. It is now 9:50 pm and the VCR time says 8:50 pm.-   tapeit59
Prepararion:
Turn on the tv and set it to the video input mode.
Select "Clock" from "System Setup".
1. Select Clock
2. Select the desired items using < or > (month,date,year,hour, minute and AM/PM), the press enter.
3. Press the down arrow or up arrow to set the value of the selected item.
4. Repeat steps 2 and 3 to set the date, year and present time, and press ENTER. The SETUP Menu will close.
For the Daylight savings time...it is under the clock menu too. Just change it to what you want.
When I record using a hdtv converter box the sound has a large humming noise. But when I record...
(More)
When I record using a hdtv converter box the sound has a large humming noise. But when I record using just the attena it records the vhs tape perfect. I have checked the setup and disconnected and reconnected several times with no change. Could you please help me? johnr.heide@gmail.com Thank You John Heide
how to prepare DVD blanks when Broksonic DRVCR900 does not respond to remote contol ? LiteOn DVD...
(More)
how to prepare DVD blanks when Broksonic DRVCR900 does not respond to remote contol ? LiteOn DVD 5005x recorder lost system function and display hello only after one power outage. How to restore reading disc ?
I am unable to get the VCR to record from a timed recording. The time and day are correct. If I...
(More)
I am unable to get the VCR to record from a timed recording. The time and day are correct. If I press record it does record. I just hooked it up to another tv. Please help me.
Will not play any DVD's. Does not indicate DVD is in machine when switched to DVD mode. All DVD's...
(More)
Will not play any DVD's. Does not indicate DVD is in machine when switched to DVD mode. All DVD's report incorrect disk - 104
