Question about Dryers
Bought a home with whirlpool side by side fridge/freezer. There was no light bulb in the door for the ice/water dispenser. How do I know what to replace it with?
Model ED5PHEXRL00
    New Friend:
Front load not going through full cycle.
Posted on Jan 11, 2013
4 Suggested Answers
SOURCE: GE Monogram refrigerator is leaking water on the floor
At some point the freezer got too cold and the drain froze (it is a poor design with a loop in the bottom). Once this freezes it will not thaw for a long time.
Here is what I did:
  • Remove all items from freezer and let it completely thaw
  • Pull unit away from wall to access rear
  • Cut loop off drain line where it hangs in drain pan
  • Place a bare copper wire (#12 will work) through the drain line and wrap it loosely around the heating coil above drain pan
  • Enjoy
Did this 6 months ago and have not had problem since
Posted on Jul 12, 2009
  • 5 Answers
SOURCE: GE GSS25QGTA Side by side fridge not cooling, no
did you plug the fridge in and connect and turn the water pipes leading from the fridge to an outlet and water outlet, if you didn't you should
Posted on Dec 02, 2009
  • 1891 Answers
SOURCE: COMBINATION OF PROBLEMS WITH MODEL 25 HOT POINT
i think you answered your problem / sounds like the board. some times you can smell the burn and some boards have clicking sound . / from what you have stated . i would replace board. mm the burn is the price of the board .. mm
Posted on Dec 03, 2009
Testimonial: "Thanks much appreciate the shortcut t/c"
Model #WSF26C2EXY02. Why is ice maker not making ice?
When the ice-tray is full it pushes 'UP' a lever that shuts the water supply off. When you move the lever down all goes back to normal.
Oct 14, 2015 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool fridge freezer
The fridge side is cooled by the freezer side. Try unplugging power, open freezer door and let thaw out/defrost.
Apr 30, 2014 | Refrigerators
How do i connect 15mm water pipe to whirlpool fridge freezer the plastic nut is too big
Most home improvement or hardward store will sell adapters that will work for you.
Aug 01, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a Whirlpool side by side fridge freezer with ice maker and water dispenser which is about 3 years old. Model number I think is WSC5533. Recently I had an interior lamp bulb blow in the fridge which...
HI,
You may have a failing door switch which is causing this problem, if you remove the bulb and close the door, the the red light out? If so, its possible you bulb is fine, you door switch has failed.
I hope this helps
Jul 26, 2011 | Whirlpool Refrigerators
Refridge. light went out. Bulb is good. Indicator
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 25, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice dispenser won't work, light won't work.ge side by side fridge
A GE uses a 12 volt bulb . It will not come on , if you went and bought a bulb with the same receptical end . HAS to be a 12 volt .
Sep 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool Gold side by side SR2659325
are you hearing a hum then loud click hold my rating till we are done
Mar 31, 2008 | Whirlpool ED2FHEXN Side by Side...
Fridge Freezer Ice maker problem
We have an Whirlpool side by side America fridge freezer. Water is not flowing into the ice-maker
Mar 31, 2008 | Refrigerators
 if posible try turning off over night, if its ok when you start it back up after 24hours, defrost not happening, ice builds up air flow is restricted
Oct 18, 2007 | Whirlpool ED2FHEXN Side by Side...
Dryers Logo
Top Dryers Experts
