Question about Dell Precision Computers & Internet
Dell precision 670 will not power up - Precision Dell Computers & Internet
  • Dell Master
  • 27,725 Answers
Test your PSU power supply unit or replace it if your power supply units fan is not working your PSU is faulty http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Remove the memory modules from their slots. Take the opportunity to clean the slots on the motherboards and the memory module connectors. Use compressed air to blow dust away and clean contacts with a soft cloth. Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components. Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol (Methylated Spirits) on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r Allow the pins to dry. They will air dry in a matter of minutes. If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer. Check the memory module and memory slot contacts. They are either copper tin or gold. The colour will tell you which they are. Mixing tin and gold can result in corrosion that prevents proper contact. Look for any sign of physical damage to the memory module, memory slots or the motherboard. Reseat the memory modules. You should hear an audible click when they are in place. Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard. The hardware that you are trying to access is damaged or failing.
The device drivers for the hardware are faulty or incompatible. Could be a problem with the Hard Drive or the Hard drives PCB http://www.onepcbsolution.com/ There is a connection problem such as a bad cable for internal hard drives
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40pin ide this will be the first to fail Make sure all leads that are attached to your drives dvd\cd and floppy (If Applicable) have secure connections and are not faulty. or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
Hope this helps.
Posted on Jan 10, 2013
melnavz
  • 1226 Answers
SOURCE: Dell precision 670
Ok go to bios setup and then "load bios default" and press "F10" to save and exit. i will tell you in case this not work just tell me.
Posted on Jan 18, 2008
sandrew
  • 2961 Answers
SOURCE: Dell Precision 670 throws "BIOS not installed!" message
i think this means that the harddrive needs to be refoarmated as the bios sees no logical drive in which the boot.ini file resides
Posted on Sep 01, 2008
efs_perpends
  • 1996 Answers
SOURCE: Dell Precision 670 6 long beeps on post no video but pc is on
Please consult this Dell link for general startup troubleshooting for your system., and this link will take you to the codes for the error lights and beeps.
Finally, here's a good article to help solve general startup problems and diagnose the possible cause.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on May 26, 2009
SOURCE: My Precision 670 won't power up.
If it not power up the first make sure power cable isgood try with other power cable.
Then check on cpu.reconnect ATX connector from smps to motherbord.
Pull cmos cell from motherbord for 10 minutes ..
Make sure your smps power supply unit of cpu is good.It is squarebox in back side of cpu .
If still not power up the smps has issue.
Let me know if you need further assistance.
Thanks.
Posted on Nov 05, 2009
  • 10406 Answers
SOURCE: Take a 2-CPU Precision 670 down to 1-CPU
You probably removed the "primary" CPU,
and the computer cannot operate only with the "secondary" CPU installed.
Move the CPU from the "secondary" slot to the "primary" slot.
Posted on Jan 13, 2010
Testimonial: "Very courteous and helpful response. While it did not answer my question, I do appreciate the response and I shared my findings in additional comment."
Dell precision 670 diagnostic lights y g y
http://www.dell.com/support/Manuals/us/en/19/Product/precision-470
Click on -
Dell Precision Workstation 470 and 670 Computer User's Guide
In the list on the right side, click on - Tools to Help Solve Problems
In the list on the left side, click on - Diagnostic Lights
Yellow (A) Green (B) Yellow (C)
"A possible VRM 1 failure has occurred"
VRM stands for Voltage Regulator Module.
It regulates Voltage for the Processor.
The Processor MUST have a steady, 'clean', supply of Voltage; and it MUST be kept within the tight voltage range, for the Processor.
Too little, or too much; and the Processor turns off. (BIOS turns it off)
Your motherboard supports two Processors.
1) Processor (CPU_0) Zero which is in the middle of the motherboard, next to the PCI Express x16 slot;
2) and Processor (CPU_1) One, which is next to it.
The VRM 1 has failed. Needs to be replaced.
http://www.ebay.com/itm/DELL-H2703-PRECISION-470-670-VRM-VOLTAGE-REGULATOR-MODULE-TH-0H2703-WS470-WS670-/380369885440
VRM's used are interchangeable.
IMHO you can remove Processor 1 (CPU_1), and it's VRM, and still use the computer; albiet slower though.
For additional questions please post in a Comment.
Regards,
joecoolvette
Mar 22, 2013 | Dell Precision Workstation 670 PC Desktop
DELL Precision Workstation 670 second processor not working
Update your motherboard's Bios to the latest version.
Jul 24, 2012 | Dell Computers & Internet
I need a replacement PSU for DELL Precision WorkStation 670. Where can I buy one?
Access the manufacturer's web-site: http://support.dell.com
and enter '670' and do the search.
Find the part-number, and order the part.
Sep 22, 2010 | Dell Precision Workstation 670 PC Desktop
Precision 670 crash during bios upgrade from dell site, now when i start the computer it beeps and nothing happens. I need solutions! Thanks, Pablo
How many beeps? Any pattern? (e.g., short, short, long, long, low, high) ?
Contact Dell, and purchase a replacement motherboard.
Sep 02, 2010 | Dell Precision Workstation 670 PC Desktop
Did you change BIOS settings or does your BIOS supports dual processors?
Jul 19, 2010 | Dell 3.8 GHz Second Processor for...
My Dell 670 had a blue screen when the c drive
try to remove or detach any newly hardware.and check the Ram
Feb 03, 2010 | Dell Precision Workstation 670 PC Desktop
Jan 13, 2010 | Dell Precision Workstation 670 PC Desktop
Can I use a SL8MA 2.8 dual core 4mb / 800 fsb processor in a dell precision 670?
I know this is late but it is the CORRECT answer.
Dell used different motherboards in the Precision 670 and they are listed as follows:
X0392XC837MG022U7565
I am running the XC837 motherboard and it WILL support the SL8MA processors. I have been told that the XC837 is the ONLY motherboard what will support the Dual Core Paxville Processors. If you are trying to use them in a 470 you will need XC838 Motherboard.
Nov 25, 2009 | Dell Precision Workstation 670 PC Desktop
With my Dell precision 670 the USB ports do not initailze
You can try updating the bios firmware but more than likely it's a hardware problem since you've experienced it with two separate operating systems.
If you've got one usb port that works really well you can get a powered usb hub and that will "solve" some of your problems.
Nov 20, 2009 | Dell Precision Workstation 670 PC Desktop
Computers & Internet Logo
Alun Cox
