Question about Dell OptiPlex GX280 PC Desktop
Dell optiplex gx280 will not start
When my pc is turned on it displays a black screen that says press f2 to go to setup menu and when pressed goes to the setup menu..that is al my computer will do..I dont know what to do to get it to start
  • Dell Master
  • 27,725 Answers
Test your PSU power supply unit or replace it if your power supply units fan is not working your PSU is faulty http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Remove the memory modules from their slots. Take the opportunity to clean the slots on the motherboards and the memory module connectors. Use compressed air to blow dust away and clean contacts with a soft cloth. Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components. Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol (Methylated Spirits) on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r Allow the pins to dry. They will air dry in a matter of minutes. If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer. Check the memory module and memory slot contacts. They are either copper tin or gold. The colour will tell you which they are. Mixing tin and gold can result in corrosion that prevents proper contact. Look for any sign of physical damage to the memory module, memory slots or the motherboard. Reseat the memory modules. You should hear an audible click when they are in place. Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard. The hardware that you are trying to access is damaged or failing.
The device drivers for the hardware are faulty or incompatible. Could be a problem with the Hard Drive or the Hard drives PCB http://www.onepcbsolution.com/ There is a connection problem such as a bad cable for internal hard drives
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40pin ide this will be the first to fail Make sure all leads that are attached to your drives dvd\cd and floppy (If Applicable) have secure connections and are not faulty. or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
Hope this helps.
Posted on Jan 10, 2013
hothawk
  • 174 Answers
SOURCE: Dell OptiPlex GX260 PC Desktop wont boot
Your cd Rom is also not working properly
Posted on Aug 13, 2008
  • 565 Answers
SOURCE: can't boot my Dell Optiplex GX280 from the
u need to use the sata drive floppyor windows xp corporate with sata drivers. can download from torrents.
If helped rate fixya
Posted on Mar 07, 2009
lucky1484
  • 90 Answers
SOURCE: CPU Fan Failure on Startup
if you have tried changing the fan then the problem is with the motherboard & motherboard needs to be replaced.
Posted on Apr 25, 2009
anandg27
  • 1272 Answers
SOURCE: unloked setup dell
Visit the link below to reset bios password
http://tomcat.yc.edu/servman/Desktops/GX270_SM/replbrd.htm
Posted on Jun 23, 2009
SOURCE: No Display in dell optiplex gx280 & Fan speed is veyy high
GM from pakistan fsd problem in motherboard chepset......you should repare u r gx 280 or heat the chepset with heat gun ........
Posted on May 21, 2010
How can get inside again in the boot setup of a dell optiplex 170L?
Good Day,
That is quite an easy thing to do.
Immediately you turn on your PC, after displaying the brand (for some PC), the computer dispalys 'press F__ to enter boot setup'. If you can't get to read it, either press F2, F12, F10 or F1 continously after you turn on your system. Then you can make your corrections.
I hope this helps. Thank you for using Fixya.
Jul 23, 2012 | Dell Computers & Internet
How do I know if my boot ste up is correct
If your PC doesn't boot up using the hard drive, you can check that by looking for the F2 or F12 displayed on the screen during boot up. Then start pressing F2 or F12 quickly to get setup.
In setup follow the directions and set your "boot device" to "hard drive"
Hope this is what you needed.
Feb 15, 2012 | Dell Inspiron 531 Athlon 64 X2 4400+...
NTLDR is missing to restart Ctrl+Alt+Delete
the easy part is to repair windows:
put original cd whit windows in
boot from cd
press r to repair
chkdsk
fixboot
fixmbr
restart and should be ok
if not reinstall windows
best regards
Sep 22, 2011 | Dell OptiPlex GX280 PC Desktop
This problem just started yesterday.When booting up,the first screen with the white bar goes across,then it goes to a black screen and beeps once with the message,hit F1 to reboot or F2 to setup menu,but...
restart your computer press F8 then click restore the directory setting this will restore all the directory in the system and the system will reload properly if this doesn't work you will have to re install the OS
Jun 28, 2011 | Dell OptiPlex GX110 PC Desktop
I have problem with my fan when turn on my computer say fan failure press f1 to continued press f2 setup
You should first check to make sure the fan is working. Just open it up and turn it on and see if the fan is functioning properly. If not then you can just order a replacement fan from Dell.
Feb 18, 2011 | Dell Optiplex GX280 (99301) Motherboard
Dell Dimension 3000 Video problem
There may be a problem with your windows installation. Search Google for Hirens boot CD, it is a free download and should contain a live XP installation. When you turn on the computer tap the appropriate button to reach the boot menu, then insert the CD and select your CD drive. Once booted it should display a live XP.
Alternatively you may have your monitor set to an incompatible resolution. If tapping F8 won't display the advanced boot menu then try finding an auto setup on your monitor or change the resolution using the monitors controls. If the advanced boot menu does display then select low resolution mode.
Hope this helps,
www.PuterCare.com
Jul 02, 2010 | Dell Dimension 3000 PC Desktop
Goes On ..Then Goes Black Screen I have 2 GX280s. One failed the other day after 2 years use. The BIOS screen appeared then it all went black. About every 10th attempt to get it going, it works and boots...
have you tried booting in safe mode? When it starts press F8 and select "Safe Mode" or "Last Known Good Configuration.". On that 10th try you do get it to come up make sure you install all updates for your computer. Then you can put int he Optiplex disk from Dell and run some diagnostics.
May 28, 2009 | Dell OptiPlex GX280 PC Desktop
Apr 25, 2009 | Dell OptiPlex GX280 PC Desktop
Can't enter BIOS
Hi there.
  • Boot the system. Press F2 to enter the BIOS setup.
  • Press ALT-F
  • Press ALT-B
  • Computer will restart and display a message indicating it is re-detecting IDE drives. After a minute or so, Windows will start. Test the device that wasn't working before.
  • If you want to restore other BIOS settings you have set, such as the boot sequence, you will have to restart the computer and enter BIOS setup again.
If this does not work try another usb keyboard in the same port.
Good luck and thanks for using FixYa!!
Apr 22, 2009 | Dell OptiPlex GX280 PC Desktop
Dell OptiPlex GX280 PC Desktop Logo
22 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
