Question about Dell Dimension 8300 PC Desktop
Dell pricision 670 will not power up - Dell Dimension 8300 PC Desktop
  • Dell Master
  • 27,725 Answers
Test your PSU power supply unit or replace it if your power supply units fan is not working your PSU is faulty http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Remove the memory modules from their slots. Take the opportunity to clean the slots on the motherboards and the memory module connectors. Use compressed air to blow dust away and clean contacts with a soft cloth. Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components. Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol (Methylated Spirits) on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r Allow the pins to dry. They will air dry in a matter of minutes. If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer. Check the memory module and memory slot contacts. They are either copper tin or gold. The colour will tell you which they are. Mixing tin and gold can result in corrosion that prevents proper contact. Look for any sign of physical damage to the memory module, memory slots or the motherboard. Reseat the memory modules. You should hear an audible click when they are in place. Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard. The hardware that you are trying to access is damaged or failing.
The device drivers for the hardware are faulty or incompatible. Could be a problem with the Hard Drive or the Hard drives PCB http://www.onepcbsolution.com/ There is a connection problem such as a bad cable for internal hard drives
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40pin ide this will be the first to fail Make sure all leads that are attached to your drives dvd\cd and floppy (If Applicable) have secure connections and are not faulty. or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
Hope this helps.
Posted on Jan 10, 2013
DELL Precision Workstation 670 second processor not working
Update your motherboard's Bios to the latest version.
Jul 24, 2012 | Dell Computers & Internet
I need a replacement PSU for DELL Precision WorkStation 670. Where can I buy one?
Access the manufacturer's web-site: http://support.dell.com
and enter '670' and do the search.
Find the part-number, and order the part.
Sep 22, 2010 | Dell Precision Workstation 670 PC Desktop
Precision 670 crash during bios upgrade from dell site, now when i start the computer it beeps and nothing happens. I need solutions! Thanks, Pablo
How many beeps? Any pattern? (e.g., short, short, long, long, low, high) ?
Contact Dell, and purchase a replacement motherboard.
Sep 02, 2010 | Dell Precision Workstation 670 PC Desktop
Did you change BIOS settings or does your BIOS supports dual processors?
Jul 19, 2010 | Dell 3.8 GHz Second Processor for...
My Dell 670 had a blue screen when the c drive
try to remove or detach any newly hardware.and check the Ram
Feb 03, 2010 | Dell Precision Workstation 670 PC Desktop
Can I use a SL8MA 2.8 dual core 4mb / 800 fsb processor in a dell precision 670?
I know this is late but it is the CORRECT answer.
Dell used different motherboards in the Precision 670 and they are listed as follows:
X0392XC837MG022U7565
I am running the XC837 motherboard and it WILL support the SL8MA processors. I have been told that the XC837 is the ONLY motherboard what will support the Dual Core Paxville Processors. If you are trying to use them in a 470 you will need XC838 Motherboard.
Nov 25, 2009 | Dell Precision Workstation 670 PC Desktop
With my Dell precision 670 the USB ports do not initailze
You can try updating the bios firmware but more than likely it's a hardware problem since you've experienced it with two separate operating systems.
If you've got one usb port that works really well you can get a powered usb hub and that will "solve" some of your problems.
Nov 20, 2009 | Dell Precision Workstation 670 PC Desktop
Dell Workstation 670 video
Support for ISV-certified PCI Express graphics cards up to 150 watts and with up to 512MB graphics memory including: nVIDIA® Quadro® FX 4500;
nVIDIA Quadro FX 3450; Quadro FX 1400; ATI™ FireGL™ V3100; nVIDIA Quadro NVS 280; All graphics cards support dual monitor configurations
All the info for your pc can be found here..... http://www.dell.com/downloads/global/products/precn/en/spec_precn_670_en.pdf
Jan 15, 2008 | Dell Precision Workstation 670 PC Desktop
Dell Dimension 8300 PC Desktop Logo
mukhtar21 shaikh
mukhtar21 shaikh
