Question about Dryers
Kenmoore 70 series dryer wont start - Dryers
  • 4 more comments
  • waynebeedle Jan 22, 2009
    I checked everything I could think of. Jumped the thermal fuse witch is open and still won't start. checked the door switch,the start button. If I checked the motor correctly, I have continuity on the start winding of the motor. What else could it be?
    Will not start at all! 110.66722692
  • Mark Egan May 11, 2010
    If you checked continuity of the start winding, did you check continuity of the the run winding?
    Does the motor try to turn at all?
    Please reply the complete model number so that the wiring diagram can be reviewed.
    Describe more of your symptoms and we can better help you out.
    Does it start when the button is pushed?
    Is it plugged in, and you know it is getting power?
    President:
  • 1,214 Answers
Are you 100% certain the dryer has 240 VAC? Just because a light may light does not guarantee both legs of 240 VAC are hot.
If you measured motor continuity, then you must be able to read a wiring diagram/schematic. Most Kenmore units have a wiring diagram/schematic glued to the back of the rear service panel, or folded and stored in the control head.
I am unable to find a wiring diagram on the internet, but, you have a door switch, and the timer/control.
Use the wiring diagram to trace the signal path's to determine where the failure is.
Let me know if you have any questions and I will do my best to help.
Posted on Jan 22, 2009
Kenmoore 70series dryer goes on while turning to desired setting before hitting start button
you start button is fuse together get a new start button and it wont do that any more
Mar 14, 2015 | Dryers
I have a Kenmore Series 70 dryer wont start, just hums
Check for correct voltage at the terminal block on the back of the dryer, where the power cord attaches to the dryer.You should be getting 220/240 volts, check by way of a voltage tester.
If the voltage is correct, then could be the motor capacitor or the motor itself, or start button?
Good Luck !
Feb 07, 2010 | Kenmore 63942 Dryer
Kenmore 70 series dryer has power just wont start when push the button is it the start switch?
could be the start switch or it could be the safety switch in the bottem of the dryer that turn the dryer off incase the belt brakes.
Oct 02, 2009 | Kenmore 63942 Dryer
Dryer wont start.
can you hear the motor or does the unit humm or vibrate when it is turned on
if yes then have a look at the belt
if not it's time sor a service call
Aug 04, 2009 | Kenmore 700 6972 Dryer
Kenmoore 80 series heavy duty (gas dyer) no heat.
If you still need help please post your model number. Gas/Electric?
Eric
May 25, 2009 | Kenmore 63942 Dryer
Kenmoore Dryer will not start
ok im with you,,send me the model #..and check your door switch..i want to veiw schematic on this,,,we have a defective part..
Jan 17, 2009 | Kenmore 63942 Dryer
Kenmoore 70 series Buzzer will not stop
buzzer is built -in the timer you all should replace it if you really want it solved they have done their work over the years. It's not something you can just go in and unplug or cut sorry. Good Luck. Post your make and model numbers next time please.
Dec 19, 2008 | Kenmore 60172 Electric Commercial Dryer
Dryers Logo
172 people viewed this question
Top Dryers Experts
