Question about Syntax ValueBook VT5000 PC Notebook
I have a syntax valuebook laptop that does not have the drivers for the modem etc installed to connect to the net, how can I get a download.
I need to download a Win7 Motorola SB5102 cable modem driver via this XP laptop
Yes, you can do it.
Downloading the driver will result in a file you can copy over to the flashdrive.
Just do not double-click on the file, because that will start the installation process.
In the unlikely case that the file auto-starts the installation process, you will normally have the option to Cancel the installation.
May 07, 2014 | Arris SB5102 SURFboard Cable Modem
How do i connect my net book to use my wireless router
How do you connect your wireless router to your netbook..?
you must have an internet connection with your service provider or isp(internet service provider),...
connect it with your wireless router modem, or modem to wireless router to your wifi laptop,.
make sure power of your modem and wireless router is on there was an ac power cord it needs to be plug...
next in to your laptop install the wifi driver,... to know that it is intalled go to my computer(windows xp/?)right click then properties go to harware tab then device driver look for yellow ? and intall driver if necessary that your wireless connection driver is not install...
if done and install go to start menu then connect to --> show all connection--> wireless connection and done it will connect... sometimes theres a security u need to type wep key,, etc etc..
HOPE IT HELPS!!!
Jun 27, 2011 | Sylvania G-Netbook
Dell Inspiron 2200 cant connect to internet
go to support.dell.com and download the modem driver to an external media (cd, thumb drive, etc.).
then right click 'my computer' and go to properties then device manager. you should be able to go to the modem and update the driver from a specific location and then point it to the external media you have downloaded the driver to.
Jul 11, 2009 | Dell Inspiron 2200 Notebook
Screen resloution and modem problem for hp pavilion dv6000
Your problem is that when you re-installed Vista, the drivers for the laptop devices (eg video, LAN, modem etc) was not installed. You need to download then and install them before your devices will operate. You may already have these drivers on your Recovery disk, if not then download them.
You can download the drivers from Dell WEB site, the support download page. Make sure you select your model laptop, better still, type in the Service Tag number, it is printed on the label on the bottom of the laptop. This will open the page where the specific drivers for your model laptop are located. Also make sure you select the Windows XP or Vista version of the driver for your Windows operating system.
Click on this link :-
http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
Apr 23, 2009 | Dell Latitude D600 Notebook
No Wireless/ wi-fi
did you install the modem driver aswell? the modem and WiFi wireless is a mixed unit, as need both drivers to funktion.
/Teis
Jan 03, 2009 | ASUS Z83V Notebook
Installation software for Huawei EC 325 USB modem
I lost the installation Cd please help me
Dec 29, 2008 | Computers & Internet
...install a modem...
try to download the driver from the net here is a good site:
www.driverguide.com
the modem could be : hfs softmodem, motorolla, or connexant
May 18, 2008 | Acer Aspire 5100 Notebook
Connecting the net with motorola w230 mobile
i dont have any cd to connect my w230 mobile phone with pc
when i was brought this mobile they don't given any cd to install now what can i do?
Mar 15, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Stupid blank screen on my Craptop
Could be a simple video driver problem, try starting up your laptop in safe mode (Pressing F8 on boot up). If and when screen comes up highlight 'Start Windows in Safe Mode' Next a list of startup drivers etc will stream down the screen and tell you you are starting in safe mode, allow this. If your lcd screen stays on then it's a driver problem, go to add/remove programmes and uninstall driver the driver and restart your laptop. This should then start in VGA mode all icons will be bigger than normal. Either re-install video drivers from setup/restore disk or go to laptops manufacturer website to download drivers. If no screen even in safe mode LCD probably dead. Please rate solution.
Nov 15, 2006 | Syntax ValueBook VT5000 PC Notebook
Syntax ValueBook VT5000 PC Notebook Logo
118 people viewed this question
Top Syntax Computers & Internet Experts
Roy May
Gbenga
Are you a Syntax Computer and Internet Expert? Answer questions, earn points and help others
