Kenmore HE2 Front load
The link screen is stuck and won't come out. What could be causing this problem?
  • 1 more comment
  • Deb Owens Jan 10, 2013
    This is the Dryer not the washer.
  • Deb Owens Jan 14, 2013
    Finally figured it out. It was the metal clip that holds the lint screen in place. It fell off. I pulled it out with a magnet and just left it off.
  • Skip Billings Jan 14, 2013
    very cool. its always something ne does not expect..
The screen is more than likely stuck due to lint buildup. try gently prying it up.
Posted on Jan 10, 2013
  • 1 more comment
    I clean it before everyload and always have, weekly I brush it out with one of those long brushes. I tried pulling on it vigorously but didn't want to break something. Could a drawstring get caught in there and cause this?
  • Skip Billings Jan 10, 2013
    Yep it could. Try a very thin bladed knife or a razor balde and slide it down and into the the front and back of the filter drawing it across both areas
    OK, I'll give it a try tonight, THX.
3 Suggested Answers
  • 6 Answers
SOURCE: My Kenmore HE2 Plus Front Load Washer won't drain?
remove front panel at bottom, get a bucket & clean pump out
Posted on Nov 10, 2009
  • 16 Answers
SOURCE: I have a he2 kenmore front end loader washing
Something is in your pump trap, easy fix. pop open the bottom panel by removing the three screws under it. requires a torx bit or a nut driver. if you can tilt the washer back so the front legs are a foot or 2 off the ground, it will make this a lot easier. once open you will see a twist off cap. before you remove this be prepared for the residual water to eject out when you open it. these can not get all the water out so there is always some, tilting it back will minimise this or putting hose clamps on the pump to tub hose can help but not nesesarry. twist it out and clean it out, also stick your fing into the two holes where the trap is located to see if any coins have gotten stuck. once clean, make sure you line up the trap arrow with the base. then button it back up, good luck
Posted on Dec 04, 2009
Testimonial: "Ffantastic, fixed in under 20 mins!!! Thank you"
A light came on to clean the washer. Is there something special I need to do?
Even a blonde can do it! Quick fix/repair for Kenmore He2 ...
? 4:57
https://www.youtube.com/watch?v=4o9hWHQkOMM
Sep 1, 2013 - Uploaded by And Justice For All
Quick fix/repair for Kenmore He2 front loading washing machine... a Kenmore He2 front loading washing machine when blinkinglights error code occurs ... How to Clean Front Load WasherDrain Filter and Empty the Water ...
Front Load Washer Pump Clean Out - YouTube
? 3:03
https://www.youtube.com/watch?v=f9uS8_0-pWY
Sep 6, 2012 - Uploaded by GE Appliances
If you have a front load washer with a pump filter, your pump filter may become ... pressed start again but it still stops and the cleanpump light still comes back on. .... Samsung Washing Machine cleaning the pump & coin trap
Nov 29, 2015 | Kenmore Washing Machines
My Kenmore HE2 front load washer when I go to start a load of clothes it's making a humming sound and not filling up with water?
Either one of your water valves isn't working properly, or the lines have sediment restricting the volume of water . What I would do is turn the water to the machine off and remove the water lines and make sure they aren't filled will calcium, etc. and look in the water valves where the hoses connect because that are, which has a screen, may be full of nastiness. If both those are good then the water valve solenoid(s) are stuck and won't open. The humming sound you hear lets you know the rest of the machine is working because the sound is generated by power being applied to the valve by the control.
Jun 21, 2012 | Kenmore 43142 Front Load Washer
Lights blink on settings around the knob won't run from there
Your door switch is not working, the machine thinks that the door is still open.
Mar 11, 2012 | Kenmore HE2 Plus Front Load Washer
OK- my Kenmore He2 won't spin fast enough to drain when there is a heavy load involved. This is what I've done- emptied the filter- lots of change and other gunk, cleaned out attached hoses and the p
Check the shocks on the drum to make sure they are ok. if they wear out the drum spins out of balance and the computer wont allow it spine because it would WALK and damage itself.
Apr 19, 2017 | Kenmore HE2 Plus Front Load Washer
Kenmore HE2 front load washer. All power to the maching is good. Thhe start button just beeps in quick sucsession. Won't start. It seems to think the door isnt' closed but it is, and tightly. ...
It is indicating that there is a problem either with the door lock or the door locked sensor requiring a service call, sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Sep 19, 2011 | Kenmore HE2 Plus Front Load Washer
My washer did fill, but won't spin or drain now and the door won't open
Hi tragz,
If it can't drain, it won't spin. There may be something preventing the pump from draining in the Pump filter. You will need to clean it.
Please follow my below Tip on how to do it:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER
Kind Regards d")
* If this solution helped you, please rate it
Aug 05, 2011 | Kenmore HE2 Plus Front Load Washer
Won't run or drain water out. Made awful noise before stopping
there is something stuck in the pump that takes the water out, check unplucked, the front of the nachine there will be a pull downh flap that is where you will find the filter for the pump. keep in touch. good luck
Jun 05, 2011 | Kenmore HE2 Plus Front Load Washer
Nov 10, 2009 | Kenmore HE2 Plus Front Load Washer
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
