I also have a Sony STR-D365. Volume control works intermittently as well as right channel. Works if I "wind" the volume control up and down a bit and then goes out again. I reset it and no change. Any
    Genius:
  • 1,669 Answers
There is a wiper on the back of the volume control that varies the resistance through the switch to control the volume. When you move it back and forth you are scraping the oxides off the switch and making it work again. I suggest you either get some contact cleaner and spray the control from inside (where the wiper is) or just change out the switch.
Posted on Jan 10, 2013
marsrover
  • 682 Answers
SOURCE: volume control problem
bring good contact luricat cleaner from near radio shack and apply it over volume and move it forward and backward many times.
Posted on Jul 05, 2008
SOURCE: STR-DE445 Works, but goes into protect when you turn up/down volume
This is a piece of **** unit. Mine only works on the left side, sometimes. When those times are I have NO idea. It doesn't seem to play 5.1 correctly and it goes into speaker protect mode for NO reason. It is TRUE lemon !!! ..let me know if you have any other problems with this JUNK .....schafe1001@aol.com
Posted on Aug 28, 2008
SOURCE: I have a Sony Air
HI I HAVE FIXED THE SAME FAULT ON MY SONY SCANNER BUT NOT FOR THE FAINT HEARTED!. YOU WILL HAVE TO UNSOLDER AND EXTRACT THE CONTROL AS THE TRACK SPRING LEAVES HAVE BECOME WEAK AND ARE NOT TOUCHING THE TRACK PROPERLY.CAREFULLY TAKE APART THE CONTOL CLEAN ANY RESIDUE ON THE TRACK AND CONTACT SPRINGS THEN RE ASSEMBLE AFTER SLIGHTLY BENDING THE CONTACT LEGS TO IMPROVE PRESSURE ON THE TRACK. BEST OF LUCK I HAVE GOT A SPARE WHICH MIGHT FIT YOUR MODEL. CHRIS
Posted on Aug 01, 2009
Nomodo4u
  • 863 Answers
SOURCE: right channel low volume
Here you go buddy:
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&externalId=C225335&fes=true&mdl=STRDE685
Posted on Nov 02, 2009
  • 11800 Answers
SOURCE: I've got a Sony STR-DH800
There is a disparity in the impedance of the speakers and the outputs of the receiver - the speakers are too weak and they act as a short , damaging the amplifiers , hence the Protect status being engaged.
Trying to run the receiver with a wrong set of speakers has probably damaged it. Get a correct one and try the setup only with it, if you're lucky it was just the safety system cutting the output.
Posted on Nov 27, 2010
Factory reset sony mhc-6700
I don't think that will cure the problem. Volume controls these days are done by an IC. If it fails it can cause the volume to go up on one channel and not on the other. If you trace the wiring back from the volume control you will eventually run into the chip. I would have thought that the two channels will go into one chip and not two separate chips for each channel, but it depends on how complex the system is. If you are lucky the PCB will even tell you that the area is tone and volume control.
Feb 27, 2016 | Sony Audio Players & Recorders
I have a Sony reciever (STR-D365) and Time Warner remote (8780L). I found the codes for that combo but none of them are controlling the volume function. Power on/off and mute are working but nothing...
083,091,077. Check these codes. If you wish to get more details, check this link. http://electrohelponline.blogspot.com/ Setup code list and setup proceedings to many popular brand remote controls are given.
May 18, 2013 | Televison & Video
Left channel cuts out, if i tap the reciever it will come back on.
sounds like the controls are dirty...or possibly the solder connection on the volume control has become intermittant...you can goto your local electronics store(or Radio Shack) and get some contact cleaner..open the unit up and clean the volume control as per the instructions on the can...make sure when you spray the cleaner into the control you turn it back and forth several times...then you want to spray more in to flush out whatever debris may have been in there...be careful not to get any on the face plate as it may damage the finish...also , make sure that the chemical spray that you use is safe for plastics...If this doesn't fix it , then the volume control assembly may need to be resoldered.
Mar 01, 2012 | Sony STR-DE185 Receiver
The receiver works ok until the vol is reduced and the right front channel drops out. Increasing the vol usually picks up the dead speaker but it drops out again when the vol is reduced. I've tried...
Make sure the audio level on the left and right channels are balanced. Check the menu for audio levels to adjust and make sure they are not maladjusted. If all levels are adjusted properly then the volume control or volume control circuity may be at fault.
Jun 27, 2010 | Sony STR-DE685 Receiver
Speakers stop working
This is either a loose connection internally or a dirty control such as the volume control. Both of these will require a trip to the shop
Apr 04, 2010 | Sony STR-DE697 Receiver
HOW CAN I HOOK UP CAVILIER 200A POWER AMP TO A sony str av 770x f
You can pull the Left and Right stereo program from either MD/Tape or Video 2 Audio OUTputs. Run a pair of RCA cables to the Active EQ's Line IN; then the EQ's Line OUT to the Cavalier's Line IN.
If the Tape output you're borrowing the program from is already connected to something, use RCA-cable splitters.
Remember to NEVER activate the monitor for that Tape function during playback of any digital audio source - it disables the digital input; or if the 901's are being used - it will remove the signal to the Cavalier.
Now if you wanted to use the 901's in your movie listening this will work with two limitations
Your receiver doesn't have preamp outputs for Front Left and Right out so you'd be extracting only the mixed-down 2-channel version of whatever the Sony is processing.
You'll have to manually control the Cavalier's volume because the pre-out you're using is BEFORE the Sony's volume control.
It might still be an improvement over what you have now.
Mar 21, 2010 | Sony STR-DE675 Receiver
Quiet front R channel on Sony
Does problem persist when you connect other speaker to front right channel? (i.e. when you connect your FL speaker to FR and vice versa)?
Jul 15, 2009 | Audio Players & Recorders
Volume Control not working via remote. Works manually. Is there a motor or belt involved that may require replacement?
Please check volume button works on remote? Take any digital camera / mobile phone camera and see remote front through camera and press volume buttons, if you see IR LED blinking then remote is fine and amp has problem with volume. Let me know exact model of Sony amp to see its schematics.
Jun 05, 2009 | Sony STR-DE935
High volume cut out
power amplifier circuitry problem,you need a qualified serviceman.
Oct 04, 2006 | Sony STR-DE595 5-Channel Amplifier
118 people viewed this question
 Grubhead
Grubhead
