Question about Shark Vacuum. Navigator Lift-Away Bagless Upright Vacuum Cleaner NV352
When vacuuming on position I, the motorized brush does not roll and light does not turn on.
Perhaps, motorized brush is not supposed to roll on bare floor position. Though on brush roll on it it is pretty loud. I have checked for all obstructions.Thank you!
  • mary ferran Jan 15, 2013
    Thank you Small6363& strattt!! My vacuum is good to go!!! thank you very much.
  • Shark Master
  • 18,424 Answers
Dont use brushes on wooden floors ,,,,this link is the manual
http://www.sharkclean.com/manual/NV351_26_NV352_26_IM_ENG_SPA_101207.pdf
Posted on Jan 11, 2013
  • mary ferran Jan 11, 2013
    Thank you!! I was not aware of this important point.
2 Suggested Answers
Strattrpt
  • 159 Answers
SOURCE: The beater brush doesnt work
It seems that your drive belt for the beater brush is stretched. This is a common problem -- if you flip the vacuum over so you are looking at the bottom, you should see several screws holding a faceplate in place. Unscrew these, and you should be able to get access to the beater brush and belt. Pull on the belt a little -- if it has a lot of give, or seems stretched or cracked, replace the belt and your vacuum should be fine. If it is not stretched or cracked, move the belt and look between the belt and where it holds onto the brush (there should be a little groove that the belt is sitting it). If there is a lot of debris or hair (I have long hair and this happens to me quite often) between the belt and the brush bar, clean it out, and you should be good. The squeaking noise leads me to believe that the belt is stretched and could be replaced.
Posted on May 26, 2011
Dyson DC28 head/spinner does not spin in Bare Floor setting only
The brush roll is not supposed to spin when it's on bare floor setting
Mar 11, 2018 | Dyson Vacuums
How do I replace the belt for this model
Make sure vacuum is not plugged in to power outlet. Lay it upside down and remove 4 screws from bottom plate covering brush roll. Remove bottom plate and pull the brush roll out. Clean hair and debris from brush roll and make sure it spins freely. Remove end caps from brush roll if possible and clean debris out. Install new belt around motor shaft then insert brush roll into belt and pull on brush roll to give you enough leverage to stretch belt far enough to put. Brush roll back into position. Reinstall bottom plate and screws. Make sure brush roll will turn before turning vacuum back on. Belt will lose elasticity and should be replaced twice a year.
Jan 17, 2015 | Hoover U5434-900 WindTunnel Plus Bagged...
How to repair windtunnel hoover agitator that will not turn
Likely a broken belt. Also check the agitator brush roll bearings (in either end under the end caps) for hair, strong, thread, etc. as this will make the brush roll harder to turn and wear/break belts prematurely. If all these check okay, then observe the tensioning roller that causes the V belt (runs from the idler pulley to the brush roller) to be sure it is swinging down when the handle is released to hold tension on the belt, causing it to rotate. These tensioning rollers can break, but often are locked into the "Bare Floor" setting without the user noticing. Slide the carpet brush roll selector (located on top, next to the floor height slide adjustment) back and forth and make certain it is all the way into the "Carpet" setting to allow the tensioning roller to engage. [Note: The tensioning roller is always retracted (in the neutral or off position) when the handle is in the upright position. You must release the handle to allow this tensioing assembly to engage.]
Sep 05, 2014 | Hoover Model U6485900 Upright Vacuum...
Why does the brush continue to rotate on bare floor setting as well as using hose attachments?
Hello! The brush roll shut-off feature is on select models. Your vacuum may or may not have this feature. If it does not, the brushes will continue to rotate while hose is removed or in use and at all times while cleaner is on. The vacuum must be in the upright position to lift rotation brush off the carpet when cleaning above the floor. Be sure the vacuum does not tilt forward when doing above floor cleaning. Hope this was helpful!
Aug 10, 2014 | Dirt Devil Vacuums
The red "!" icon is on when I turn on my vacuum
Button on CARPET, lower the handle for use, turn on power and the brush turns. Handle up like for storage, brush does not turn. Bare floor button pushed, does not turn.
Dec 25, 2013 | Electrolux EL8807A Precision BrushRoll...
Dyson dc17 makes loud noise on carpet setting. It's like a high pitch ringing almost but won't make the noise on hard floor, only carpet setting. Ive checked for blockages and cleaned all parts but makes...
It is probably the brush roll motor making the noise. Remove the brush roll & belt and turn both motors on. If you do not hear the noise when both motors are running the noise is likely coming from the brush roll
Nov 02, 2013 | Dyson DC17 Animal Bagless Upright Cyclonic...
Eureka 4870 brush won't stop turning in upright position
there will be a linkage that as come loose and not operating the limit switch to turn it off, try looking at 23. Idler Clamp Assembly on the link below.
http://www.vacpartswarehouse.com/Eureka-4870-Ultra-Smart-Vac-s/1928.htm
Jan 27, 2013 | Eureka Smartvac 4870 Bagged Upright Vacuum
The beater brush wont spin because the brush roll is always in the off position. Moving the carpet/hard switch doesn't turn it on.
Hello :
Try this please :
Switch the carpet/bare floor dial back & forth 5 times, ending on carpet. Tilt the handle back as if to vacuum upright & lay the vacuum on its side so it is resting on the side opposite the carpet/bare floor dial. Turn the vacuum on.
Or Maybe the belt is broke. You will have to replace the belt before the roller can spin. You must have run over something in the carpeting like string or whatever to have it break. Happens all the time. Get several replacement belts to keep as spares while you're at it as nothing is worse then having to vacuum and no spare belts.
Try this also please :
Things You'll Need: Phillips head #2 screwdriver Replacement belt for your vacuum model Spray lubricant, such as silicone spray or teflon lube.
1: Unplug the vacuum. Never work on an electrical appliance when it is plugged into an electrical outlet.
2: Turn the vacuum over and locate the plastic or metal plate that covers the rotating brush. Remove this plate.
Note: This plate is typically attached by a small number of Phillips head screws or by levers that turn and lock the plate in place. In either case, removing this plate is a simple task.
3:Identify the vacuum's rotating brush. This brush should have a black rubber belt wrapped around it, and stretched around the metal shaft of an electrical motor mounted somewhere toward the back of the vacuum.
4:Verify that the brush will rotate freely. Examine both ends of the brush to ensure that no threads, string, yarn, etc. have become wrapped around the ends and thus inhibited a free rotation.If there is foreign debris, remove the brush by sliding it up, away from the bottom of the vacuum. Remove the debris
5:Lubricate both ends of the rotating brush with the spray lubricant. Replace the brush into the grooves which hold it in place
Replace the existing belt on the brush assembly, or replace a broken belt with a new vacuum belt.
6:Verify that the brushes now turn freely when back in place and that the motor shaft turns as the brush rotor turns.
PLEASE DON'T FORGET TO RATE !
Apr 22, 2010 | Hoover U6630-900 WindTunnel Bagless...
How do I replace the brush roll on my oreck xl??
Turn the vacume upside down. Remove the 5 screws on the bottom plate. 3 are near the brush roll, and 2 are near the back. Remove the bottom plate. take the belt off the motor end. pull up on both ends of the brush roll. Put new brush roll on making sure that you put both ends to the new position, not old. ( it is marked on one end, and there are marks on the side that goes up so the can match.)(If putting back the old brush roll you can switch to the old position. After a year or two you can switch the new brush roll to the old position.) Put the bels back on the motor shaft and then stretch and start the belt on the brush roll and rotate the brushroll by hand untill the belt is all the way on.
put the bottom plate back on and tighten the 5 bottom screws.
Apr 21, 2009 | Oreck XL Ultra Bagged Upright Vacuum
Shark Vacuum. Navigator Lift-Away Bagless Upright Vacuum Cleaner NV352 Logo
613 people viewed this question
Top Shark Vacuums Experts
JoeVacs
Thomas Perkins
Thomas Perkins
Are you a Shark Vacuum Expert? Answer questions, earn points and help others
