Question about Exercise & Fitness
Epic el 2980 tension does not change
I have an Epic EL 2980 Elliptical. Everything appears to work, but the tension does not change. All wires are connected between the control panel and mechanism. There are no breaks in the wire. The belt is in good shape, and properly tensioned. The panel comes on when in use, and the controls appear to work, ie you can sign in, choose a preset worlout, and you can change the settings. Everything appears good, except the tension does not change. Any Ideas?
    Habit-Forming:
  • 138 Answers
If the resistance worked before you moved it to where it is now then it's almost certainly a wiring issue. Make sure that each connection that was taken apart is perfect and that each pin is not bent. Make sure that all of the wiring moves freely and there is no pinch. If all of that is correct then it's most likely the resistance motor.
Posted on Jun 18, 2017
  • 3 Answers
SOURCE: Humidifier control .
if humidifier was wired into thermostat circuit for power instead of seperate transformer , this can happen. you need to see if you voltage going to the solenoid valve. if you do , and it isn't opening, the valve is bad . this is assuming that it is using a # 50 relay to come on only when the fan runs . . make sure the water valve is open
Posted on Dec 28, 2007
bargainbox
  • 1388 Answers
SOURCE: SINGER 9836 tension mechanism doesnt work. stitches sew wrong.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with
a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistant diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on May 28, 2008
SOURCE: electrolux epic series 3500 sr serial v87779 l
Sorry I didn't see this sooner. Your problem may be solved as simply as pushing the small red reset button exposed on top of the power head when you tilt the arm back. Very simple. Hope this helps.
John
Posted on Nov 05, 2008
SOURCE: 93 Volvo 940 Threw timing belt, now won't start
The same thing happened to my 94 volvo 960 the engine belt was having the same problem, i changed it the belt, it was fine for a few miles after that it just died, does not fire, not sure if it is getting fuel, but the mechanic says the timing belt went off. you may have to check the crank sensor on yours.
enrixba
Posted on Jun 14, 2009
  • 75 Answers
SOURCE: Sparks in the el. motor of Electrolux Canister.
check the wiring it might have gone bad
Posted on Jul 07, 2009
Everything works except the Treadmill motor ? Incline works OK, belt doesn't turn at at all. Model EPIC View 550
1) You have problem with LUBE deck belt, this happen because the lack of maintenance, you must lube EVERY week, use 100% silicone lube. Maybe you have WORN deck belt,
2) LUBE the rollers bearing too, use wd-40
3) Test the drive belt motor, see for break, or worn, and replace or tension by 1/4"
4) Test the input voltage motor, if there are the motor need repair. see my personal TIPS for help and troubleshooting.
5) Test the output voltage board, for input voltage motor, if there are NOT the board controllers is faulty. God bless you. see the block diagram attached.
Nov 25, 2012 | Epic View 550 Treadmill
Tip
How do I convert, rip, put, get DVD to Samsung Epic 4 for watching?
The tutorial mainly helps you solve the problem with How do I convert, rip, get, put DVD to Samsung Epic 4 to play DVD movie on sprint Samsung Epic 4 for watching home made DVD (or DRM protected DVD)
If you want to play/watch DVD movie on Samsung Epic 4, you will need this easy and simple DVD to Samsung Epic 4 converter app to convert, rip DVD to Samsung Epic 4 mpeg-4playable format. Get either home video DVD or commercial DVD onto Samsung Epic 4 can be fast using this powerful DVD to Samsung Epic 4 converter application, and you will feel satisfied with the best original quality viewing with the 4 inch screen.
Software you need to convert/rip DVD to Samsung Epic 4:
DVD to Samsung Epic 4 converter can convert/rip DVD to Samsung Epic 4 MPEG-4 format for smooth playback, and select DVD title, chapter to convert, and cut, split then join DVD scenes as you wish then put DVD onto Epic 4. DVD to Samsung Epic 4 ripper can also extract audio from DVD and then convert to AAC, MP3 audio. Free download the program to your Windows 7(or Vista, XP or Windows 2000) to convert DVD to Samsung Epic 4 now.
Step 1. Install and Run DVD to Samsung Epic 4 converter for Windows
To install it, simply download
DVD to Samsung Epic.exe file onto your computer hard drive or desktop first.
dvd-to-htc-evo-4g-ripper-300x185.jpg Step 2.Load DVD movies
Insert your DVD movie into your DVD drive .Click the Load DVD button (Or click the Load IFO button) to load your DVD.
Step 3. Convert DVD to Samsung Epic on Windows
If you want to rip DVD
to Samsung Epic format, you need to select the output format as MPEG-4 (*MP4).
If you want to extract DVD audio to HTC Evo 4G, you need to select the output format as AAC or MP3.
Step 4. Transfer converted DVD to Samsung Epic 4
Using Mac OSX (Snow Leopard)? Please download and install DVD to Samsung Epic 4 for Mac.
on Jul 01, 2010 | Cell Phones
Epic E 950
1= the resistance is adjusted magnetically.
2=the resistance is not adjusted o.k
3=check the bolts that secure the magnet
4=if there are slips, the resistance will slip,adjust
5= test the magnet, with the magnet withe the refrigerator. for attraction +resulpusion. and replace if do not pass the tests.,because they are de-magnetized.
God bless you
Jul 12, 2012 | Epic E 950 Elliptical Resistance...
Epic 450mx console lights up but nothing works not even the fan, worked fine yesterday
1) Adjust the REED switch,clean, and tigh the connector wires.see the diagram attached.
2) See inside for any fuse blown adn replace, or c.breaker reset
3) Reset the machine. Tight any connector, and wires looses, or breaker use the DVOM , see the diagram
God bless you
May 08, 2012 | Epic 450 Mx Treadmill
Belt is stopping when i begin to walk on it.
On my Epic you can adjust the belt tension by using an allen wrench in the holes on the end of rails. Tighten 1/4 turn on each side and see how the tension is. Repeat another 1/4 turn if necessary.
Feb 02, 2011 | Epic Overstock T60 Treadmill Treadmills
Tread skips or stops when running
Nov 29, 2010 | Epic Overstock T60 Treadmill Treadmills
Can u change the door direction on a maytag washer
It is possible with little drilling work on the body. But it requires skill and patience. Wirings to the door lock has to be re-routed etc. It is not worth the trouble!!
Apr 05, 2010 | Maytag EPIC MFW9700S Front Load Washer
I am looking for an owners manual for my Epic Series 6500 SR.
Owners manual in pdf-format Electrolux Epic Series 6500 SR:
http://homeappliance.manualsonline.com/ex/thread/view/idThread/1424472
Clicking "Epic6500.pdf" will pop up a registration shortly,
but the manual appears directly after that.
Aug 09, 2009 | Electrolux Epic 6500 Vacuum
Exercise & Fitness Logo
1,134 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
