Question about Canon PIXMA iP1500 InkJet Photo Printer
Paper feed catches on right side
Therefore i get a paper jam message and have to resset the printer
i have to hold the paper on the left side to get it to feed almost straight
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 544 Answers
If the paper tracks are clean.
Using 24 lb weight printing paper sometime works.
Posted on Jan 25, 2009
    President:
  • 8,637 Answers
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 21, 2009
My HP Officejet 7210 all in one is showing the following error message: Carriage Jam. Open carriage door, clear jam, then press ok". There is no jam, I have looked through the back door and the front of...
Carriage jam means the carriage, where you put the inks, can't move right to left properly. Sometimes ink on the clear strip behind it is the cause. You can carefully clean with damp Q-tip, and check also that the cleaning assembly on the right where the printhead parks, is not stuck.
Jul 24, 2009 | HP Officejet 7210 All-In-One InkJet...
Pper jams
The printer hardware should even this out when printing. You should also ensure the paper meets the automatic feeder requirements of the printer.
If printing is skewed, feeding multiple pages or jamming, please follow these instructions (use a regular letter size paper to test after doing the steps given below):
Please check to ensure there is nothing obstructing the paper feed mechanism down inside the printer where it is not easily seen. If there is nothing obvious, unplug the printer and remove the paper. Open the front cover and look above the steel rod. You should see a conveyor belt with rubber teeth on it, like a fan belt. Take the bottom part of that belt and move it gently to the left. The cartridges should come out with it. Make sure the cartridges can move fully from one side of the printer to the other. Check also the output rollers on the bottom of the printer for any blockage. If it is jamming under the carrier assembly, you may be able to fix it using the manual feed slot. Turn the printer off. Next take a #10 envelope and feed it through the left side of the paper feed slot (The manual paper feed slot is preferred, but the automatic feed will do if there is no manual paper feed for this printer) until it comes completely through the printer to the back of the exit rollers. Move it up and down and slowly move it over to the right side. If something is stuck under the black guide plate this may work it loose or you may have to feed the envelope through the front rollers and push your way backward (please be careful here).
Next, take a damp warm cloth and clean the rubber rollers in the automatic sheet feeder. Dust may be coating the rollers there and as they become less tacky, they cannot feed paper correctly.
Finally, turn the printer upside down and carefully shake it for 10 to 20 seconds to see if something falls out of the paper feed path. Then plug the printer back up, take your paper out and replace it with a fresh, small stack (about 5 pages) of paper. Quickly bend the stack in an 'S' shape a few times to separate pages. Make sure it is lined up on the right side of the paper feed and the paper guide on the left is snug on the left side of the paper. Then try to form feed again. If that works, then try to print again.
May 27, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
I have a Canon iP2600. For no apparent reason, it stopped feeding paper on the left side only. On the right side, the paper catches, and tries to feed, resulting in a paper jam.
Sounds like an obstruction of some sort. Have a look on the left side with a flashlight as best you can, and see if maybe a staple or paperclip got lodged in there.
Apr 27, 2009 | Canon Pixma iP2600 Photo InkJet Printer
Paper jam message, but actually no paper jam
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Mar 08, 2009 | Lexmark X2350 All-In-One InkJet Printer
Paper keeps jamming
Its right most of printer has 2 or more paper feed but when its feed the path will be one path its one roller path ,therefor i think roller has problem ,clean it ..
Jan 25, 2009 | Office Equipment & Supplies
Printer 2480- my printer is pulling paper only on right side
Try this :
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
Jan 16, 2009 | Lexmark X2470 All-In-One InkJet Printer
Paper jam message
Good luck...
Oct 27, 2008 | Lexmark X3470 All-In-One InkJet Printer
Paper Jams
most likely there is paper or something stuck in that corner
use a flash-light an carefully inspect the area
hope this helps
thanks for rating
Jan 09, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Paper feed
Your printer is politely asking you to please get a torch, and open the lid of unit and thoroughly check inside all over for a tiny jam of paper or something else. I am willing to bet you will find some jam. I would also switch it off, and wait a while before turning on and printing again. Good luck
Aug 31, 2007 | Canon PIXMA MP530 All-In-One InkJet...
Canon PIXMA iP1500 InkJet Photo Printer Logo
118 people viewed this question
old marine
old marine
