Question about Saachi SA-1430 - High Quality Coffee Grinder / Dry Spice Grinder with Stainless Steel Blades and Safety Device
Can the blade be replaced on the saachi coffee/spice grinder? The ends broke off my blade when I grinded whole cinamon
I need to know if the blade can be replaced because it looks like that plastic nut holding the blade on doesn't come off
Change or sharpen blade on cuisinart spice and nut grinder
you can replace it by contacting cuisineart on line and or their toll free number provide the part # and they will send you another one it will cost you though
Sep 30, 2014 | Cuisinart Spice/Nut Grinder
How do I clean the Black 3-oz. Coffee Grinder by Krups? Remnants of all the spices I used are stuck in the blade.
The best idea is to grind some rice to remove the spice pieces that are stuck. After doing this, wipe it clean with a paper towel or a cloth towel. Try not to get it wet, this makes all the spices get clumpy and it will be even harder to clean.
Jan 24, 2013 | Kitchen Appliances - Others
What is a good spice grinder?
I have had a few different spice grinders over the years and this one is my favourite by far. Just don't use it for both coffee and spices. If you want to also grind coffee beans, i would recommend buying a second one.http://www.cooking.com/black-3-oz-coffee-grinder-by-krups_111215_11/?ccaid=AFFL1&&/
Blade will not spin
While I don't have this brand or model of grinder, (coffee beans, spices?), I use a small elec. grinder for grinding coffee beans and unless the grinder and cover or perfectly lined up and locked in place, it willnot grind, a safety feature. Check and make sure everything is lined up so it closed with all the lines in place and the grinder is also put into the lock position.
Aug 21, 2011 | Cuisinart Grind Central DCG-20N Electric...
Need replacement part for Starbucks Barista Blade Grinder! Please help? Went to grind as I usually do but there is apparently a plastic circular part under the blades (I imagine that keeps the blades in...
your best bet is probably to search ebay for a dead one you can strip, cheaper grinders tend not to be supported with parts, personally id recommended throwing it away and getting a better grinder, blade grinders do not give a consistent grind, they are just about acceptable for grinding for a french press but anything else youll be far better off with a burr grinder
May 10, 2011 | Starbucks Barista® Blade Grinder
Grinder on Cuisinart Grind and brew does not work anymore.
Have you ever heard of the saying: A penny on the rail will prevent a locomotive from starting, but a locomotive will run over the same penny at speed.
This is what I think you have here. A coffee bean is preventing the blades in the grinder from grinding. Just like a garbage disposal, turn the blades (UNPLUG THE MACHINE) backwards to free up the blocked or binding blade, then try again. Depending on the age of the unit and frequency of use, the grinder motor may have failed and needs replacement.
Good luck.
Sep 26, 2010 | Cuisinart Grind and Brew 10 Cup Coffee...
Don't know how to use Mr.Coffee IDS57 coffee grinder
Typically you load in the beans, replace the cover and then either press down on the entire cover or the black knob on the front of the cover. I would hold the lid down with your other hand just to be safe. Grind for about 4-6 seconds depending on how strong you like your coffee (the longer you grind the finer the coffee will be...this means STRONGER)
Jun 09, 2009 | Mr. Coffee IDS57 / IDS55 Electric Blades...
Saachi SA-1430 - High Quality Coffee Grinder / Dry Spice Grinder with Stainless Steel Blades and Safety Device Logo
Top Saachi Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Saachi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
