Question about Hunter 52" Ceiling Fan With Light And Remote Control
Fan wont work only on low the light works - Hunter 52" Ceiling Fan With Light And Remote Control
    Genius:
  • Hunter Master
  • 1,617 Answers
Probably need new receiver.Really need more info, Model #
Posted on Jan 26, 2013
Why won`t the fan of my venmar range hood turn off?
Sounds like you may need to replace the fan switch. The fact that it wont turn off and that it only works on low speed supports that switch is broken.
Apr 24, 2014 | Venmar Kitchen Ranges
Fan works, light does not turn on
First make sure your using the correct wattage of bulb. Check light connector wires at bottom of fan.Also check the light wire connected at the ceiling & make sure there are no bare wires touching .This is a low-end store brand(Home Depot)& they use low-end parts.
Mar 30, 2013 | Hampton Bay Dryers
Gas central heat turns on and lights up then goes out because fan wont blow
pressure switch not working or the pump jump out presseure switch see if it lights , wter leval low
Jan 20, 2011 | Heating & Cooling
The remote controls the fan speed but wont dim or control the light. the unit wont work if the light switch is off so I cant use the fan at all unless the light is turned on
mcdevito75 here, Generally the Ceiling fan motor is hooked up by-passing the wall switch but still to the hot laed going to the wall switch whlie the lights are hooked up to the hot lead after the wall switch, So without the remote, Manually operate your fan and lights. First with the wall switch off the fan should work and the lights no work. Now turn the fan off with the pull chain on the fan shroud close to the ceiling. Now turn wall switch on and lights should work with wall switch and the fan should also work. if so, re-program the remote or change the batteries or even re--place the remote.
Jul 26, 2010 | Hunter Ceiling Fan Light Remote Control
How to Repair Ceiling Fan that only works on low speed and smells like its burning, the light works fine
Check the motor is not seized up.
If the motor turns freely by hand, but still smells hot and wont run at speed it will have to be replaced.
(The motor drive inductor winding is most likely to be faulty - uneconomic to repair)
Jul 07, 2009 | Dryers
Dont know meaning of warning lights bulb with thermoter,box with fan above waves
i am a masrer volvo ASE MASTER TECH yes the one with thermometer is the coolant low and square sounds light the Generator light and why is coolant low???? is fan working properly and relay?? and under thermostat there is a coolant temp sensor and to clarify meaning wet is that the coolant temp sensor has enough coolant to the sensor INSIDE THE THERMOSTAT housing
Apr 22, 2009 | 1995 Volvo 850
How to access ac blower and fan switch, 1999 Volkswagen Beetle?
if its work in only low speed u have to replace the blower motor resstor which located close to the blower
let me know have a good one
Mar 31, 2009 | 1999 Volkswagen Beetle
Hampton Bay ceiling fan remote control
i have a problem with remote ceailing fan and light i tried push on light key - dim light low to high working but fan isnt working hi to low. i checked the supply wire red, white and black so i have a installing receiver and receiver have red receiver wire to black supply wire, white receiver wire to white supply wire , but what i do with red supply wire to QQQQ
Jan 25, 2009 | Universal Remote Control Hampton Bay...
Light and fan trouble
Fan works when component heat is higher so its normal.
Mar 01, 2008 | Samsung SMH7174BC Microwave Oven
Dryers Logo
13 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
