Question about Dell XPS 430 (DXDOBG1) PC Desktop
INSTALLING A NEW HARD DRIVE
TAKING OUT OLD HARD DRIVE AND INSTALLING NEW ONE WITH NEW OPERATING SYSTEM, WINDOWS 8
  • Dell Master
  • 27,725 Answers
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards
http://www.youtube.com/watch?v=A7R5VYsdxIg http://www.youtube.com/watch?v=TyS3-elMozk Hope it helps.
Posted on Jan 10, 2013
  • 43 Answers
SOURCE: reinstalling windows on new hard drive
Place the windows cd in the drive and re-boot.You should be prompted to press any key to boot from the cd.After that,just follow the on-screen instructions.It's really pretty simple!Hope this helps!
Posted on Feb 20, 2008
rtrahan
  • 741 Answers
SOURCE: When installing a new hard drive the system bios
All of the above and you can also go to control panel/adm tools/disk management/click on the hard drive and click format..follow the wizard see if that does it..
Posted on Mar 06, 2009
  • 35 Answers
SOURCE: Can't install WINDOWS.
WindowsXP does not natively support SATA drives. The install disc doesn't contain any SATA drivers for these devices. You can retrieve the correct driver HERE, and slipstream the driver into your windows disc. For slipstreaming tutorials and software, go HERE.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/robert_33d06d08b28d1f14
Posted on Mar 11, 2009
PaulRepair
  • 66 Answers
SOURCE: bad dell hard drive
as long as you have the windows COA code on the back of the computer (certificate of Authenticity) you can just find a good copy of XP Pro, and install it on your machine. When done, you can run the resorce CD and install the drivers.
If you do not have the Operating System disk, you have to find another disk, or contact Dell to get a new one sent to you.
The key is that you have the code on the back of the computer (or top, or side, or wherever.)
Posted on Apr 06, 2009
emb_solution
  • 40 Answers
SOURCE: I have had the hard drive cleaned, re-installed
Slow computers are sometimes due to bad hard drives. Run a hard drive diagnostic test on your computer to make sure the hard drive isn't bad. Download this hard drive diagnostic from Western Digital: http://support.wdc.com/product/download.asp?groupid=612&sid=3&lang=en
Also, make sure you have enough RAM to support your growing number of installed programs. Download and run this system scanner to check if you can add more ram to your PC:
http://www.crucial.com/systemscanner/
Best regards,
Embraced Support
computer repair plantation
Posted on Sep 19, 2011
Hard drive failure
You select custom if you want to either delete any old operating systems and format the drive first. If you want to keep all your old data select Upgrade. Other wise in the custom menu select each partiton and select delete. Then select the hard drive click New, Ok and next and the install will start.
Jun 08, 2013 | Toshiba satellite c660
Transfer data and operating system from one hard drive to another
Use AOMEI Partition Assistant,a free Windows partition software, to clone data or OS from one hard drive to another. http://www.disk-partition.com/copy-disk-partition-wizard.html
Oct 12, 2012 | Hitachi TravelStar Computers & Internet
Can I install the hard drive of my old hp 8510p in my hp presario cq 42? will it run the old windows vista? My new hp presario cq 42 is running the new windows 7?
If the hard drive is compatible with your presario cq 41 then it will work. The operating system does not matter if you're switching hard drives.
If you want to update the operating system on the old hard drive, you will need to have the software for Windows 7.
Jun 14, 2011 | Compaq Computers & Internet
I wanted to wipe my entire hard drive on my old Dimension 8400 that contained windows xp on it and reinstall it with windows vista, which i have the cd for. however, when i did so, each time i try loading...
1. you will need to know 1st that the hard drive you are installing is compatible with the desktop.
2. Is the hard drive compatible with the new Operating system (VISTA).
3. Check to see if you have the hard drive properly inserted that is properly cabled and connected.This will render error in installation.
4. Make sure you are installing the Operating system correctly.
5. Some boot sectors become corrupt during a change in Operating system if the hard drive is not properly formatted.
6. Try formatting the hard drive again and re-installing.
Feb 12, 2011 | Dell Dimension 8400 PC Desktop
Reboot error - did not come with disk
You could have a hard drive failure. In that case you need to get a new on and re-install the operating system. Depending on the operating system which i guess is windows XP you should have no problem re-installing it with a valid license. To optain the software you need to find it on the internet and download it. then use your license to validate it. Hope this helps
Jun 13, 2010 | E-Machines eMachines Desktop PC
Take Three: I have an older Maxtor Hard DriveTake Two: I have an older Maxtor Hard Drive (Model 90645D3). I need to transfer some files from it (Win98SE) to new hard drive (WinXP Pro). I asked earlier and...
Jumper off will set the drive to slave. If you can connect both drives to the same ribbon cable with the master on the end & the slave to the second connector. Look at your bios as win is booting up to see if shows the drive as slave, you will not be able to copy windows as a operating system off of the drive, but should be able to copy files.
Good luck on your endevors.
Lee
Nov 12, 2009 | Maxtor Hard Drive
WHAT IS THERE TO DO WHEN INSTALLING A NEW HARD DRIVE TO MY LAPTOP
1. Remove the old drive, noting whether it has a SATA interface or an IDE interface.
2. Take the old drive to a computer-store, to buy a new drive with the same style of connectors.
3. Connect the new drive.
4. Find the "System Restore" CD-ROM(s) that were shipped with your laptop.
5. Turn the computer on.
6. Put the first of those CD-ROMs into the computer.
7. Force the computer to boot from the CD-ROMs.
8. Reinstall Windows.
9. Install anti-virus software.
10. Access http://WindowsUpdate.microsoft.com to get all the latest security-updates for Windows. You may have to access it MORE than once, in order to get "updates-for-the-updates".
Oct 10, 2009 | Acer Aspire 5100 Notebook
Installed a new hard drive
Well, since the new hard disk is not formatted, and there is nothing currently on it, you will not get a dos prompt or an operating system detected. What you need to do is insert your Windows XP disk, then reboot the machine. When you see the HP screen, tap the F12 key, which will take you to a boot menu. On the boot menu, choose your CD drive, then the computer will boot from the windows disk. From there, just format your disk, and install Windows.
Apr 14, 2009 | HP Pavilion 520c PC Desktop
Updat to new sata hard drive from old idie hard drive.wont reconi
Hi, you will need to load the sata raid drivers when installing the OS. Some off the older versions of xp will not have these, when windows is installing it will ask if you need to install a 3rd party raid driver press F6. later on it will ask you to insert the raid driver disk. which you may have to do/make yourself if you haven't already got one.
Mar 01, 2009 | Computers & Internet
WindowsXP not loading after installing Windows Vista Demo Version
You need to get rid of the Vista Demo, and reload xp. You need to keep one or the other I think, you can't keep both operating systems on the same drive. What were you thinking?
Did you install the vista demo as a dual boot setup? Doesn't sound like it.
I hope someone can help you, I can't.
Nov 24, 2008 | Microsoft Windows Vista Ultimate Edition
Dell XPS 430 (DXDOBG1) PC Desktop Logo
Alun Cox
