Question about Goldstar Refrigerators
Cant locate the drain pipe for a GR-302FDS gold star refrigerator/freezer
  • 5 Answers
SOURCE: ge profile refrigerator mod# tcx18paaarbb
drain tube is blocked .....you need to thaw it and after thawing clear drain tube all the way to condenser water tray in back
Posted on Apr 02, 2008
EllaWatson25
  • 725 Answers
SOURCE: Whirlpool Gold refrigerator water leaking
If it's flooding, it's NOT the drain pan. It's probably the water valve has gotten stuck in the open position. Hope this helps!
Posted on Aug 21, 2009
BIKER T
  • 909 Answers
SOURCE: Gold star compact refrigerator has very hot backside
Leave it alone, it is totally correct. That is the radiator and it is supposed to get rid of heat through the radiator. You even have heaters in the sides of the fridge called mullon heaters.
Posted on Sep 21, 2009
heatman101
  • 43501 Answers
SOURCE: I have an amana abb2522feb bottom freezer
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 11, 2010
  • 5370 Answers
SOURCE: We have a Whirlpool Gold
The defrost is not working so the The evaporator coil in the inner section of freezer is got blocked by ice .
Before doing anything try manual defrost reset procedure: ----
First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. It will take near to 4 hours to get run in its proper cooling cycle. Then check, if the problem returns again. If the same problem occurs then it's defrost problem. The defrost timer and the defrost thermostat and heater are not functioning properly and it has to be checked and replaced.
The heater is located on the evaporator coil and thermostat beside the evaporator coil and heater. defrost timer clicks to defrost the heater gets heated and it defrost the ice collected in the unit and thermostat sense the temperature.But if defrost timer is faulty then it will not go in defrost mode so the ice gets collected on the coil and go on collecting and this freezes the freezer section and refrigerator section does not function properly.To see how the timer looks see the fig below:--
To order this part click here:--
http://www.repairclinic.com/PartDetail/Defrost-Timer/3348
To see how heater looks see fig below:--
http://www.repairclinic.com/PartDetail/Defrost-Heater-Assembly/1175560
To see how thermostat looks see fig below:--
To order this part click here.
http://www.repairclinic.com/PartDetail/Defrost-Thermostat/586213
If you require complete disassembly diagram for your unit.Click the link below:--
http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Refrigerator-Parts/Model-GT22DKXGW01/1198/0166000?pathTaken=&prst=0&shdMod=GT22DKXGW01
For timer location see the part number 4 in liner section and for heater and thermostat location see part number 2 and 4 in "unit" section of the diagram.-----------------------This will help.Thanks.Helpmech.
Posted on Jan 29, 2011
I have model LG-GR-391SCA. water leaking to the floor. opened the freeze panel but unable to locate the drain-hole. please advise location ? how to unclog the drain hole.
Look in the bottom rear of the freezer compartment. The drain tube may be clogged and needs to be reamed with a pencil or cop stick or equivalent.
May 05, 2018 | Refrigerators
Lg express cool turbo gr-t452gva water build up in fridge
Drain pipe is in the freezer below where the fan(s) are. You may need to take a cover off to get to it.
Mar 20, 2013 | Refrigerators
8 year old Whirlpool Gold refrigerator: Freezer icing up. Found ice on shelves and on the bottom under the vegetable hydrators. The shelves and drawers constantly have a humid film on them. Last week,...
for no frost type;cleaning of freezer cub underneat is a must...cloggged drain outlet buildup thick frost on your freezer cub..
.ie..for frost type;you must set your thermostat setting to normal,replace it with new one
Oct 20, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Hi There, I require desperate assistance for my fr...
Throw it away and purchase a new one
Apr 14, 2017 | Refrigerators
WHIRLPOOL GOLD REFRIGERATOR MODEL GR2SHTXKV 02 - WATER INSIDE
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer. If this repeatedly happens with yours, you may can prevent it by taking a bare copper wire and wrap it around a fin near the heater and put the other end a few inches down the drain. The heat convection may prevent it from freezing.
Mar 06, 2010 | Refrigerators
Motor running, but freezer not freezing items.Second hand fridge was working from 10 Feb 2010 stopped freezing on the 19 Feb 2010 Gold Star GR 252 fds
First of all you have to check if the fan is working properly because this is the one responsible for "taking the cold out" from the evaporator and into the freezer
Jan 23, 2010 | Goldstar Refrigerators
WHERE IS THE DRAIN PAN LOCATED???
The bottom of the refrigerator and near compressor is where the condensate drains to. The condensate begins in freezer during defrost and collects in a collection tray behind rear wall of freezer and with a drain hole and pipe that feeds through the cabinet and down to drain pan where it is warmed by the compressor heat and returned to the air inside your home. The only way to really get a good look at pan is to pull the refrigerator away from wall and remove cover over the compressor are. I recommend unplugging first before placing hands inside.Thanks, Sea Breeze
Dec 14, 2009 | GE Profile¿ Arctica® Energy...
Aug 19, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
Top Goldstar Refrigerators Experts
AJMAL KHAN
Tom Chichester
Are you a Goldstar Refrigerator Expert? Answer questions, earn points and help others
