Question about HP DESIGNJET T770 Printer
My printer doesn't star and the on button just blink amber!! what can I do???
  • HP Master
  • 1,121 Answers
Note: Only professional can do this activity, be careful to handle such major works. Is there any message?...
1. Remove & Resit Formatter properly.
2. Check star wheel, might be it's broken.
How to reach star wheel..
A. Remove Formatter.
B. Remove left door.
C. Remove Electronic module
D. Remove spit on.
E. Remove star Wheel.
"These are major parts, some other parts also need to remove"
my printer doesn't star and the on button just - 1_12_2013_6_27_10_pm.jpg1_12_2013_my printer doesn't star and the on button just - 1_12_2013_6_28_44_pm.jpg_mi1_12_2013_6_28_44_pmmy printer doesn't star and the on button just - 1_12_2013_6_29_49_pm.jpgg src=1_12_2013_6_31_20_pm.jpg1_12_2013_6_31_49_pm.jpg1_12_2013_6_34_38_pm.jpg
Other these snaps you need to remove electronic module & spit on..
Posted on Jan 12, 2013
2 Suggested Answers
  • 3278 Answers
SOURCE: I just replaced both cartridges
Hello.
If the cartridges are not moving, it could be an indication of a print head stepper motor problem. The stepper motor moves the print head assembly (print head and ink cartridges) back and forth across the paper.
Wipe the bar on which the print head travels. The motor may not be able to drive the print head through the accumulated gunk. Use a soft cloth and distilled water.
Hope this helps.
Posted on Sep 07, 2011
Dell dimension 8400 blinking amber light ethernet port
An Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. Since you replaced the power supply, my guess is that the motherboard has a problem.
Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Jul 27, 2012 | Dell Dimension 8400 PC Desktop
Amber light on oki c3300 continues to flash and printer will not print
Here's what the owner's manual has to say:
Error status (Amber, blinking): you cannot continue to use the
printer. Intervention is required to recover from the error. Fatal
errors are irrecoverable and require a service call.
Blinking 1 (2S cycle)
An error has occurred but
printing can continue if you
press the ON LINE or CANCEL
switch.
Blinking 2 (500mS cycle)
An error has occurred. You
need to replace consumables
or remove jammed paper, for
example. The printer then
recovers from the error and
printing becomes possible
again.
Blinking 3 (120mS cycle)
A serious error has occurred.
rebooting or a service call is
required.
The Status Monitor in Windows provides a readable description
of the printer status corresponding to the indications of the
LEDs. In Mac, the printer driver provides status information
once you have sent a document to print. In Windows, if you
have the Status Monitor Preferences set to Pop up on alerts,
this readable message will be presented on screen whenever
an abnormal condition occurs.
There's no further information. Sorry.
Jul 19, 2011 | OKI C3400n Laser Printer
Blinking/flashing lights(orange & green) & won;t pring. Have rebooted computer and unpluged printer. still won't print.
that is because ur head of ur printing cartridge is damaged.
remove ur cartridges black as well as color
n install only black cartridge n check d blinking of lights on ur printer if it doesn't blinks it's mean ur black cartridge is OK but ur blinking of light on ur printer is same it's mean ur head of black cartridge is damaged
after this process remove the black one cartridge and install the color one cartridge n check d blinking of lights on ur printer if it doesn't blinks it's mean ur color cartridge is OK but ur blinking of light on ur printer is same it's mean ur head of color cartridge is damaged
now take a dry cotton cloth n gently clean ur cartridges head install both cartridges on ur printer n check ur blinking light on ur printer that will work only if u r too lucky other wise u have to purchase a one cartridge.
May 29, 2011 | HP DeskJet 5550 InkJet Printer
My printer is CANON IP 2700 when i try to print Error 5100 appears in the screen and the printer blinks orange ligth
1. hold RESUME then press & hold POWER
2. release RESUME, then press it twice, the light should go amber then green again.
3. you're now in service mode (you can release POWER now)
I think waste tank reset is 4 presses of the RESUME button. To confirm, press POWER once.
May 24, 2011 | Office Equipment & Supplies
After a storm the other night my Proview PL866s amber light is blinking - however when I press the amber button (which usually turns green and then it works) nothing is happening except blank screen and...
If this happened after a storm, the monitor may have been subjected to a power surge, which unfortunately might have killed it.
If you have another monitor (or a friend who has one) try plugging that other monitor into your computer. If the second monitor works, yours will need to be replaced as the input was probably destroyed by the power surge.
If the second monitor also doesn't work, there may be a problem with your computer, most likely with the power supply (this is the part most often damaged by a power surge). You may want to have it examined by a professional computer repair person at that point.
Hope this is helpful!
May 16, 2011 | Proview PL866B 18 in. Flat Panel LCD...
Canon i9950, Operator error,5 amber blinks
  1. Turn off Canon i550, i560, i850, i860, i865, i9100, i9950 Printers
  2. Hold down Resume button and press Power button.
  3. Keep holding down Power button and let Resume button go.
  4. Press Resume button 2 times then let BOTH buttons go.
  5. Green lights will flash and then stop blinking.
  6. When green lights are solid, press the Resume button 4 times.
  7. Press the Power button and the printer should turn off, if not, press the Power button once more.
  8. Your Canon i550, i560, i850, i860, i865, i9100, i9950 Printers should respond as normal.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Jan 02, 2010 | Canon i9950 InkJet Printer
Printer won't print. amber light blinking.
try to power off printer remove the AC adapter, and hold down power button for 30 seconds, then plug in AC Adapter and power on, that may "Reset" the printer. You may be having an intermittent hardware failure. Let me know if this doesnt work. Thanks for any votes
Mar 27, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Light keeps flashing red,amber, green
If you turn off the printer and turn it back on, do you get any noises, ie motor noises, or does it instantly go to all lights flashing?
If you get no noises this usually indicates a board fault and you should look for a new printer.
Apr 07, 2008 | Brother HL 5140 Laser Printer
HP DESIGNJET T770 Printer Logo
73 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
