Question about The Times Case Corporation Tractors International Harvestor
580d backhoe starts but only runs short time.I replaced the filters and fuel lines are clean
The screen in the pump is clean
    New Friend:
  • 11 Answers
Try a new spark plug or u might have a blocked jet in the carboreta.
Posted on Jan 10, 2013
  • Regis Knapp Jan 10, 2013
    the backhoe is diesel
2 Suggested Answers
  • 6 Answers
SOURCE: 580 Case SK Backhoe has got so it will only start
change filters, and clean the inside of pipes from tank to injectors, use a thin peice of wire to do this
Posted on May 19, 2010
Ran out of fuel now it runs for about 15 mins then dies after it sits a few it runs but again only 15 mins or so
Try purging out the fuel system could have a foreign matter trapped in it acting like a valve , it could be material around the suction filter in the tank and needs to be cleaned out or replaced .
Apr 18, 2016 | Cars & Trucks
When I pump the primer bulb, why doesn't it fill with fuel and stays collapsed?
new carbies start around $25.00 us on e-bay so get a new carby
take it to a mower shop for a service
rebuild the carby using a new carby kit
Nov 28, 2015 | Husqvarna 125 Bvx Leaf Blower Lawn Yard...
Specs on head bolts and order to torque sequence for a 580d case backhoe
http://www.ioffer.com/i/case-580d-loader-backhoe-service-manual-580-d-bonus-162592324
Jun 05, 2015 | Cars & Trucks
HOW DO I BLEED THE INJECTORS ON A JOHN DEERE BACKHOE.I BELIEVE IT'S A MODEL 310
I have the 410 model,ran it out of fuel plenty of times in the past but never had to bleed the lines due to the electronic injector pump. If it just stalled then you probably dont have an air pocket problem. Most mechanics dont recomend using starting fluid on these engines,but if you are careful and dont try to keep the engine running on it you will be fine.If it starts and quits try changing the filter,or cleaning the tank filter.
Sep 16, 2014 | Garden
How to change injector pump on CAT 428f backhoe?
Try to loosen the nuts on the fuel lines going to the injectors and crank the engine till all the air bubbles are removed from the system. Don't crank the engine for longer than 30 sec at a time letting the starter cool down before cranking again.
Jul 17, 2014 | Caterpillar Backhoe Tractor
1987 John Deere 510 Backhoe
have you tried cracking the injector lines for air?
if you crack the lines 1 at a time fuel should spay out if nothing comes out after a few moments the injector pump could be bad.
and you did fill the filter before you put it on right.
Jan 19, 2014 | YouTube Videos
2.8 Diesel Pajero Cold start
Have replaced your glow plugs?They dont cost alot to replace,try this
Jun 22, 2009 | 2002 Toyota Land Cruiser
The Times Case Corporation Tractors International Harvestor Logo
119 people viewed this question
Top The Times Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a The Times Toy Expert? Answer questions, earn points and help others
