Question about Garden
Husky 51 starts and idles fine but the chain stops as soon as it hits cutting surface
Older model 51
    Problem Solver:
  • 11 Answers
Sounds like ur cluch has worn out.
Posted on Jan 10, 2013
  • 16 Answers
SOURCE: my 345 chainsaw bogs down when it hits wood
There are two idle screws one high, and one low. Your high adjustment idle screw needs to be adjusted.
Posted on Jan 19, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: Poulan Wild Thing starts great but as soon as I try to cut it die
The carb low idle needs to be adjusted this is fairly common among the Poulan chain saws. Once you adjust the low idle from factory setting it will work
Posted on Feb 16, 2009
steve_lima
  • 181 Answers
SOURCE: Husqvarna chain saw starts and runs for 20 minutes then stops.
two things could be happening.......first is vapor lock......make sure you breather tube is clear and working........next is ....it could have a bad ignition coil on it.....after the coil gets hot the spark can become irratic or just not work any more.....
Posted on Feb 23, 2009
  • 376 Answers
SOURCE: wont stay running when you let off the gas???
Sound like the carb was never adjusted right. Unfortuatley, the carb adjustment screws require a certain tool that's not available to the public. (EPA thing) You'll have to take it to a shop to get it adjusted. That should solve the problem.
Posted on May 25, 2009
  • 132 Answers
SOURCE: while cutting the chainsaw bogs down and stops
Check the air filter and the muffler if either are plugged up it will not run smooth. Carb hi and low screws are very sensitive so if you change them, only move them a little at a time.
Posted on Jan 02, 2010
I just purchased a used 51. it looks almost new. thought i got a good deal until i used it for about 10 minutes. it started to run sluggish as if i was running out of gas and than it stalled. i tried to...
With small 2 stroke engines, it's either a spark problem or it's a fuel problem. In your case, it's definitely a fuel problem.
It could be you have a drop or two of water in your fuel or in the carburetor. Put a bit of HEET (methanol) in your premix, it'll take a while to dry it out if this is it.
Check the air cleaner element. If it's dirty, clean it with carb cleaner or gasoline or similar. If it's missing entirely, this is likely the problem, it won't run properly without a filter element, as it requires a slight drop in pressure to create a vacuum to **** fuel out of the carburetor.
Also check the fuel line for a gap or crack. Either will cause it to do what you're describing.
If you still didn't get a hit, take the carburetor off and carefully clean it. It doesn't take much of anything foreign to make it wig out.
Hope this helps.
Oct 02, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Hi, I go t a new Husqvarna 450. It cut fine for 10 mins and then stopped cutting well. Engine runs fine but it barely cuts at all. The cut is black as if burned and there's sparks from the chain on the...
Suspect that the chain hit a rock or pocket of dirt which will dull the chain in a heartbeat plus pull debris into the chain groove area. Remove the bar and chain and clean everything thoroughly including the chain and bar groove. Inspect the chain teeth carefully looking for burned teeth and other physical damage. If badly damaged, suggest replacing the chain. It's not likely that the bar sliding surfaces have been severely damaged. When you have everything back together and the chain adjusted, start the saw and run the bar tip near some cardboard--it should throw off a thin line of oil in a few moments. There should be an oil volume adjustment screw on the back or just under the same area near the chain return. Turn the screw CCW to increase flow. Hope this helps!
Jul 13, 2010 | Husqvarna 450 e-series 18" Chain Saw
How many turns out is the High and Low screws suppose to be adjusted. Also how many turns out is the larger idle screw suppose to be.
Turn both jet screws CW to stops (lightly), then back out CCW 1-1/2 turns each. This is a basic setting which should allow the engine to start and run. Before adjusting anything, check the fuel filter, air filter and muffler for plugging. Start the engine and allow to warm up. Pull the throttle full on and adjust H needle CW until the engine begins to speed up, but still 4-stroking. Correct adjustment is when the engine 4-strokes running free, but immediately 2-strokes when cutting. Release the throttle and adjust L needle CW for better idle, yet allows the engine to 'follow the throttle'. Adjust idle speed so that the chain stops turning, but the engine continues to idle. Hope this helps!
Jul 11, 2010 | Husqvarna Chain Saw Handle Models 50 51...
Chain spins when not cutting
Sounds like a clutch issue but if the chain is spinning once you start the unit you'll need to do some adjusting to your carb.
Apr 13, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
My Johnsered 625 chainsaw clutch work????
is it a high idle? most chainsaw's chain continues to turn with a high idle.
Jan 12, 2010 | Garden
25 yr old Husqvarna 266. starts fine, lots power, but won't idle.
I think you have exceded our level of help. Please try here.
ArboristSite.com Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
You might read this thread
http://www.arboristsite.com/showthread.php?t=110858&highlight=husky+266
I searched for "Husky 266" and got many positive hits. She is a respected machine.
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/9f5525102886abf488256b52001a33af?OpenDocument
HTH
Lou
Oct 16, 2009 | Husqvarna Garden
Feb 16, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
My 345 chainsaw bogs down when it hits wood
Jan 18, 2009 | Husqvarna Forest & Garden No.967012396 345...
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
