Question about Pioneer SD-P50A5-K 50" Rear Projection Television
Sd p 4553 tv
The picture is distorted and can't be seen clearly
  • tishe ramis Jul 05, 2007
    i can see the picture but it is like all the plugs aren't plugged in when they are
    President:
  • 3,130 Answers
When you say cant be seen clearly, please explain?
Posted on Jul 03, 2007
SOURCE:
Lines going through it and is very distorted
Search Results
    Troubleshooting Distorted Pictures - Stereo & Video Repair ...
    www.stereoandvideorepairco.com/.../DistortedPictureTroubleshooting.ht...
    Usually, this occurs on CRT projection TV's, and occasionally on CRT ... Dark, light, or colored bars can be seen rising slowly through the picture, ... Known as "hum bars" or "common-mode noise," these result from AC power line hum coming ...
    Flat Screen TV Has Lines Going Through Screen - Possible ...
    removeandreplace.com/.../flat-screen-tv-has-lines-going-through-screen-...
    Jun 17, 2015 - Flat Screen TV Has Lines Going Through Screen - Possible Bad ...inch LCD TV which is showing lines (vertically) and getting extremely hot. ..... If you leave the projection TV on for a certain amount of time does it ..... If so the plasma gas is most likely causing the screen to become distorted or color issues.
    Distorted Colors in an LCD Projector ' Business ...
    yourbusiness.azcentral.com/distorted-colors-lcd-projector-8597.html
Feb 08, 2016 | Televison & Video
Please help diagnose problem with Panasonic TH-50PC77U Plasma HDTV
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 31, 2015 | Panasonic TH-50PC77U 50 in. Plasma TV
Lines are shown when the picture is seen or downloaded on the PC - all across the photograph
If there are no distortions on the picture seen on the camera viewfinder then there is some issue with the picture manager software.
If the images seen on the PC are also showing clean pictures, then there fault on the transfer or the camera driver software.
Remove the SD card and insert into the PC using the card reader- use in any laptop- if the picture is clean , then uninstall the camera driver and reinstall, then connect to transfer. If the fault is seen the download another version from the camera support site to be installed.
Dec 18, 2010 | Fuji FinePix Z1 Digital Camera
Tv picture is distorted
If the picture is the only thing distorted meaning audio sounds good and clear. It would be the connects between ur tv and reciever.
Sep 13, 2010 | Onkyo TX-DS484 Receiver
Sony DSC-t33 lcd monitor is distorted.Pictures
Hi!
It's a faulty CCD imager - a very common problem with the T33 - the imager has to be replaced. You can buy it from http://myworld.ebay.co.uk/toms.rammsteins and replace the CCD yourself (ask seller the instructions).
Tom
Oct 10, 2009 | Sony Cyber-Shot DSC-T33 Digital Camera
Distored picture on top half of the screen
This is one of the sets with bad HYPER boards. If it clears up after a while this is your trouble;I just checked a site in LA--the only way to get the board is to go to PTS electronics and send them the original board for repair--part alone is over 200 and is soldered in--a lot of these sets are having this problem.
I know I am not giving you good news but I am pretty sure this is what is wrong with your set--seen dozens of them.
if you think I helped you in some way--give me a vote here I do this for free. IF YOU HAVE QUESTIONS OR NEED MORE HELP contact me by responding to this post.
SD TECH (SAN DIEGO)
Aug 29, 2009 | Toshiba 55H70 55" Rear Projection...
Sony KV-32XB25 Distorted Picture
In most of the case, the problem is a defective LCD panel, if is it, there is not worth to fix.
Aug 02, 2017 | Sony KV-32XBR250 TV
Distorted Picture
the hyper module is defective needs to be repaired or replaced.
Aug 03, 2008 | Televison & Video
Picture distorted
Hello buddylaw,
Can you post a picture of the TV screen with the problem? It will help in the diagnoses. It looks like you may have a thermal sensitive component causing this issue. But I will have to seen a picture of the screen to properly diagnose this problem as to the possible section that may be causing this problem.
Thank you.
Shuttle83
Sep 10, 2007 | Sony KV-36XBR450 36" TV
Not clear picture
If this is an HD set and you are using a SD signal I have seen many disappointed people because the upgrade that takes place in the digital video circuit is far from perfect. It will not look like it did at the store without HD!
Apr 21, 2007 | Samsung TXN2798HF 27" TV
Pioneer SD-P50A5-K 50" Rear Projection Television Logo
Top Pioneer Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
