Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
My Whirlpool refrigerator (ED25RF) has a broken water dispenser nozzle. The part kit includes lots of tubing yet the broken nozzle seems to be separate. How can I fix or replace just the nozzle withou
Nozzle is a small curved plastic pipe (about 2.5 inches long) that guides the water into the cup while dispensing. Over time it has become brittle and snapped off.
  • 25 Answers
SOURCE: water dispenser hose broken
Hi;
you would have to remove the door(and front kick panel) turn water & power supply off first. Unclip water lines and electrical connector on top of fridge. You will require food grade water pipe 6-8mm, this will slide thru the hole, have patients when doing this
Posted on Jul 06, 2010
  • 40 Answers
SOURCE: Has anyone successfully fixed his or her water dispenser?
I have had a few where the water switch housing that holds the switch breaks and does not allow the arm to hit the switch to turn water on. that is one thing it could be ethier way not to big of an expence to get fixed
Posted on Feb 23, 2009
Sea Breeze
  • 4654 Answers
SOURCE: mold in water dispenser tube
Your refrigerator has a filter system below the bottom and behind the kick plate. Two or three times you need to turn the water supply off to refrigerator and fill the old filter with clorox to kill the algae growing in the storage tank and after you finally get this out and purge the chlorine from system will you be able to use the ice or water to consume. I know this seams harsh but really there is very little else that can remove this without changing the whole water system. Once this is done change the filter regularly and this will help, click on link below and place your model number into the model search feature. This will give you pictures of the parts and there location. Let me know how this goes, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
Posted on May 24, 2009
tecnovative
  • 360 Answers
SOURCE: water fill tube broken Plastic fill tube in door
If the area that is broken is accessable all you need to do is pick up a quick connect coupler of the correct size for the damaged tube available at most hardware stores. To determine the tube outside diameter place a ruler across the surface of the tube and note the measurement. It is most likely 1/4" or 3/8" diameter.
Posted on Jan 14, 2011
kdrake84
  • 262 Answers
SOURCE: I have a new Whirlpool refrigerator (model
I despise the copper water lines on refrigerators for exactly the reason you have mentioned. This is why my customers will not pull out the refrigerator to clean behind it and to clean the compressor area which in turn causes non cooling issues.
I have many times installed just the plastic water line seen on many part distributor websites.repairclinic.com
You now will be able to move your refrigerator in and out without the worry of crimping the line. If you can find a long enough Stainless braided line....even better.
Just ignore the Whirlpool instruction guide on the matter.
It should not be necessary to use teflon tape on compression fittings. The compression fitting is made to seal without the tape.
Using a reverse osmosis should not harm the copper line. If you have hard water this would have a tendency to harm the copper more than the osmosis filtering.
You can use a brass fitting but with the plastic line you would not need one.
Here is the link that will show you the line you can use. The copper line is not for the water but for the compressor.
Click on the link http://www.repairclinic.com/Hose-Tube-Or-Fittings-Parts?s=t-ED5FVGXWS06-%3d%3dc23
if you have any other questions and or concerns please post.
Keith
Posted on Mar 13, 2011
Hello,have a whirlpool gs6nbexrb01,side by side.how do I remove the dispenser touch panel unit in freezer door, thanks
Heat from the night light probably has cracked the delivery tube for the water dispenser. There are repair kits available. from Whirpool. Instructions are included
Sep 29, 2016 | Whirlpool Refrigerators
My water hose line is broken inside of the whirlpool side by side fridge, how can I get inside door?
In most side by side fridges the water tube goes up through the bottom of the hinge on the ice dispenser door.Where is the tube broken?
Aug 07, 2011 | Whirlpool Refrigerators
LG refrigerator won't dispense water any more
The water line is freezing in the door due to deteriorated insulation. The only fix I have found to work on my fridge was to defrost the inside door with a blow dryer. Then place a weedeater replacement line (the orange 10" or so size you find at Lowes' or Home Depot) up through the dispenser nozzle, If the line only travels about 3-4 inches up the nozzle, then ice is still in the tube. Blow dry it until you are able to get water to dispense. After the tube is ice-free, place the weedeater line up throuth the dispenser nozzle leaving about 1/8" sticking out. The dispenser will still work with the line stuck in it. The dispenser will probably freeze again in about 8 hours, But all you need to do each time this happens is to pull the weedeater line out, dispense the water to unclog the ice, and place the weedeater line back in the nozzle. I have been using this method for about a week now and it works great. My GE Side-by-side is also 4 years old and this seems to be a problem with all of them. There is a part you can order to fix the problem, but I have heard it may not work.
Mar 21, 2010 | LG LRSC-26922 Side by Side Refrigerator
Water dispenser spout broken
we had the same problem. My husband cut a flexible straw to the length he wanted, and crammed in in the hole. works great !! saved between $ 35.00 and $55.00 (labor was free)
Aug 06, 2009 | Whirlpool GS6NBEXR Side by Side...
How to repair the ice dispenser door on a whirlpool refrigerator
If you will look on the bottom of the dispenser cover you will see 2 notches on the left and right side. carefully pry the cover off using a flat tip screw driver. then you will see a white switch plate that is either held on with latches or 2 srews depending on model. once this is removed you will gain access to the dispenser door.
once you gain access I think you will find the hinges for the dispenser door are broken off. if so you will need a dispenser door repair kit form whirlpool part # 8201756 this kit includes new door and hinge repair kit. this is something you can do yourself if you are pateint and pay lose attention to detail. otherwise I would recomend a god servie company. thanks for using FixYa Peyton
Feb 18, 2009 | Whirlpool 21.8 cu. ft. Side-By-Side...
Whirlpool icemaker
Your unit has infered sensors on the frezzer left and right walls. There is a diagnostic test sheet brown in color in your kick plate.All you have to do is open frezzer door look on the right sensor it should blink twice followed by a 1-2 sec delay,if that is good press in flapper door on right sensor do not block path of infered beam you will not see a beam its invisable.Once you hold in flapper on right sensor the led should be solid.If solid optics are good if not solid led replace optic sensors
Jan 25, 2009 | Whirlpool ED5SHAXM Side by Side...
Whirlpool icemaker
Try using an hairdryer or defrosting the unit completely , this often get rid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace the water valve, the icemaker solenoid, or the whole icemaker assembly.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Jan 23, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
118 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
