Question about Dryers
Clothes roll into a ball on matag dryer
Clothes roll into a ball in the dryer
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
THE DWADDER
One of the most time-consuming uses of a dryer is drying blankets and sheets. The reason it takes so long is the blanket or sheet can be twisted into a tightwad or ball during the drying cycle. Once this happens the dryer is incapable of drying the center of the wadded blanket or sheet. The solution today is to take the blanket or sheet out of the dryer halfway through the drying cycle and unwad the bundle of sheets or blankets.
Then place the blanket or sheet back into the dryer to restart the dryer cycle over and over again until the blanket or sheet is dried. If you forget to
unwad the blanket or sheet when you get ready to make the bed, the blanket and or the sheet will be wet. In order the fix this problem the Dwadder is strapped to the sheet or blanket using a silicone cord before it is placed into the dryer. Once the dryer is started the blanket or sheet will wrap around the device allowing a space to be in the center of the blanket or sheet. With the space that is created by the
Dwadder the center of your blanket and sheet will dry faster and will not roll into a tight ball or cylinder shape. This will help save time drying your sheets and blankets. The device will also prevent wadding of your sheets and blankets so you don't have to
unwad your blankets and sheets half way between the drying cycles.
The Dwadder will save you time and money. It can save up to 30 minutes off your drying time. This will save you energy. You will save time and worry less about your blanket or sheet not being completely dried when the drying process is finished. As an added feature the HDPE plastic ball opens to allow for a dryer safe fragrance to be placed inside the ball. This will reduce the use of dryer sheets.
We would love to have you as our customer. We know that the Dwadder will save you time, money and
lower the frustration of drying laundry.
For more information and
videos on how to assemble and use the Dwadder come visit us at
WWW. Defuturesolutions.com
Clothes roll into a ball on matag dryer - dwadder pic 2-hanupyigh5vsd5uy3x55zw5h-2-0_0.jpg
http://www.defurturesolutions.com/
Posted on Mar 06, 2018
    Genius:
  • Dryers Master
  • 1,669 Answers
As you insert the clothing into the dryer make sure you open up the larger pieces fully so they do not ball up. Frequently people put large bed sheets in before opening them up and everything gets rolled inside them. If your load is too small, that might happen, also!
Posted on Jan 10, 2013
4 Suggested Answers
  • 126 Answers
SOURCE: kenmore dryer
could be;
belt slipping
over loading
tumble veins inside drum broken
Posted on Dec 13, 2007
TheMobilian
  • 8220 Answers
SOURCE: clothes roll into a ball on kenmore gas dryer #11062202101
Just get the filter out and remove the 2 phillips screw init's housing on top. Then use a putty knife to press against the spring clips that hold down the top Then just roll the drum around to the top where the holes are to reattach the baffle, get some screws and put it back.87656db.jpg
Posted on Dec 18, 2008
  • 4088 Answers
SOURCE: my matag dryer seems not to be turning off when
Check for and replace a small switch (looks like a larger watch battery) on the exhaust line leading from the blower.
Posted on Aug 23, 2009
My dryer sounds like there are metal balls rolling around inside when clothes are drying
Sounds like the rollers are worn out. If they are fine then see if the dryer has glides on the drum.
Apr 23, 2014 | GE Profile Wizard DPSE592EAWW Electric...
MY MATAG #MDE9316AYW RUBBING SOUND NO START WHEN HOT
the drum of the dryer that holds the clothes has a seal surrounding the entire front of the drum. once dried out alot of build up is accumulated and will cause your problem. also the belt and tensioner should be looked at as well when opened up for inspection
Feb 06, 2010 | Dryers
Matag Dryer sounds like it has a tennis shoe in it.
Bad rollers or blower wheel is worn out.
Nov 15, 2009 | Microwave Ovens
My dryer sounds like golf balls r rolling around in it with very few clothes in it
that's actually a really easy fix....the dryer should have 4 roller wheels that the drum rides on and one or more of them must be worn out that is where your noise would be coming from.
Oct 04, 2009 | GE Energy Star WCVH6260F Front Load Washer
My matag dryer seems not to be turning off when clothes are dry
Aug 23, 2009 | Dryers
Weak Dryer exhaust
I have seen the blower unit in those machines split where the impellor is fastened to the shaft. This causes the fan to not spin fast enough to move a lot of air.
Mar 04, 2017 | Dryers
Sheets aren't drying
Sounds like out take, something blocking the vent, pinched line, birds nest, snow?
Feb 11, 2009 | Dryers
Clothes roll into a ball on kenmore gas dryer #11062202101
Dec 15, 2008 | Kenmore 63942 Dryer
Kenmore dryer
could be;
belt slipping
over loading
Dec 13, 2007 | Kenmore 62802 Electric Dryer
Dryers Logo
136 people viewed this question
Top Dryers Experts
