Where can I find and learn how to replace my CD driver in my 2004 Dell pc?
Somehow while installing a new outlook express program I lost my CD driver and now I can' t play or record CD' s on my pc. it is running on Vista.
    Genius:
  • 1,669 Answers
Go on line to the Dell website and look for downloads related to the make and model of your CD. It also may be better to find the downloads at the manufacturer website of your CD player!
Posted on Jan 10, 2013
TampaNative
  • 778 Answers
SOURCE: hitachi-lg cd-rw gce-8487b device driver corrupted or missing error code 39
You may find your driver here: http://us.lgservice.com/ or here: http://www.kauaikeepsakes.com/computerguy/
Good luck
Posted on Mar 22, 2008
  • 44 Answers
SOURCE: Dead Driver for Easy CD Creator
Resolution WARNING: THIS PROCEDURE MIGHT CAUSE ANY OTHER ROXIO OR ADAPTEC SOFTWARE INSTALLED ON THE PC TO BECOME INOPERABLE. PLEASE UNINSTALL ANY OTHER ROXIO OR ADAPTEC SOFTWARE FIRST BEFORE ATTEMPTING THE LISTED PROCEDURE.
  1. Renaming the Take Two system file
    • Click on the Start button, and then select Search
    • Search your Local Hard Disks for the following file prtseqrd.sys
    • If you do not find this file, please go to step 2
    • If found, right click on the file and then click on rename. Change the file extension to ROX (i.e. prtseqrd.sys would be renamed to prtseqrd.rox)
      NOTE: If you decided to not finish this article at any point please rename this file back, you will be doing that later in this article. right hand corner of the window
  2. Remove Easy CD Creator 5 from Add/Remove Programs
    • Click on the Start button, then go to Setting and select the Control Panel
    • Double click on the Add/Remove Programs icon
    • Uninstall Adaptec Easy CD Creator 5, if prompted choose No to reboot the PC
    • Then click the X in the top right hand corner of the Window to close the control panel
  3. Removing Directories from your Hard Drive
    NOTE: All directories stated might not be found
    • Click on the Start button, then right click on the My Computer icon and then select Open
    • Double click on the icon for the Local Disk that the software was installed to
    • Double click on the Program Files folder
    • Locate the Roxio and Adaptec folders, right click on each folder and choose Delete
    • Go to C:\\Program Files\\Common Files folder, locate the Roxio Shared and Adaptec Shared folders, right click on each folder and choose Delete
    • Go to C:\\Program Files\\Common File\\InstallShield folder, locate the Engine and Iscript folders and rename them to Engine.ROX and Iscript.ROX. Once all the directories are remove right click on the "X" in the top right hand corner of the window to close it
  4. Rename additional files on your hard drive
    NOTE: All files in the list might not be found
    • Search your Local Hard Disks for the following files:
      *CDR4_2k.sys
      *CDR4_XP.sys
      *Cdr4dll.dll
      *Cdr4vsd.sys
      *Cdr4vsd.vxd
      *Cdral.dll
      *CDRALw2k.sys
      *Cdrtc.dll
    • If found, right click on the file and then click on rename. Change the file extension to ROX (i.e. cdrtc.dll would be renamed to cdrtc.rox)
    • After all files are searched for and renamed close the search window by clicking on the "X" in the top right hand corner of the window
    WARNING: THE NEXT STEPS INVOLVES EDITING YOUR SYSTEM REGISTRY. WE STRONGLY RECOMMEND YOU EXPORT YOUR REGISTRY BEFORE SYSTEM DAMAGE. WE RECOMMEND THAT IF YOU DO NOT FEEL COMFORTABLE EDITING YOUR REGISTRY THAT YOU SKIP THESE STEPS.
  5. To export a copy of your registry, please do the following:
    • Click on the Start button, then select Run
    • Type regedit and click the OK button
    • Locate and left click FILE in the upper left hand corner of the Registry Editor, then click on Export
    • Choose the Desktop as the location to save the file in, and name the file regbackup
    • Also ensure that under the Export Range section there is a dot beside All
    • Click on the Save button. Your registry should now be backed up to a file named regbackup.reg on your desktop.
  6. Remove the Roxio and Adaptec registry entries
    • Expand the HKEY_LOCAL_MACHINE key (looks like a folder) by double clicking it (or clicking the + next to it.)
    • Expand the SOFTWARE Key
    • Locate the Roxio and Adaptec folders, right click each folder and click on Delete
    • If prompted to confirm the delete click the Yes button
    • Collapse the keys that you expanded by double clicking the expanded key (or clicking the "-" next to them.)
    • Expand the HKEY_CURRENT_USER key
    • Expand the SOFTWARE key
    • Locate the Roxio and Adaptec folders, right click on each folder and click on Delete
  7. Remove the UpperFilters and LowerFilters values:
    • Expand the HKEY_LOCAL_MACHINE key (looks like a folder) by double clicking it (or clicking the "+" next to it.)
    • Expand the SYSTEM Key
    • Expand the CurrentControlSet Key
    • Expand the Control Key
    • Expand the Class Key
    • Please look for a key containing the following string of letter and numbers: {4D36E965-E325-11CE-BFC1-08002BE10318}
    • High light this key by left clicking once on it
    • On the right hand side you are looking for UpperFilters and LowerFilters under the Name column, once you find these please delete them by right clicking on them and choosing delete
      Note: It will be easier to use the Registry editor in the future if you collapse the keys that you expanded by double clicking the expanded key (or clicking the "-" next to them.)
    • Please exit the registry by clicking on the "X"in the top right hand corner of the screen
  8. Renaming the Take Two system file
    • Search your Local Hard Disks for the following file prtseqrd.rox
    • If found, right click on the file and then click on rename. Change the file extension to SYS (i.e. prtseqrd.rox would be renamed to prtseqrd.sys)
  9. Shut down and Reboot the PC
    • Click on the Start button, then click on Shut Down
    • Choose the Restart option and click the OK button
    • Adaptec Easy CD Creator 5 should now be removed from your PC
Kindly give a feed back to Improve my statistics and to see If it was helpful for you...
Thanks and Regards
Posted on Mar 28, 2008
  • 116 Answers
SOURCE: Lost Norton Icon from Toolbar Outlook Express
reinstall norton
Posted on Jan 09, 2009
  • 6 Answers
SOURCE: Dell Webcam Center and Manager not showing up on my PC
Try Uninstalling them using the add or remove programs and then try reinstalling them again
Posted on Apr 07, 2009
leecom72
  • 4806 Answers
SOURCE: Lost resolution windows vista upgrade on GX260
Hi there.
The optiplex GX260 does not support Vista, it only supports XP, Win2000, Win98 and NT 4.0.
Regards and thanks for choosing FixYa!!
Posted on May 27, 2009
I just got Windows 7 and was told Outlook Express wouldn't work with that OS. So, I loaded in Eudora. Not really fond of it but then was told I could go back to Outlook Express IF I changed the...
I would suggest using Windows Live Mail, as this is what Microsoft intended when they retired Outlook Express.
You can download from: http://explore.live.com/windows-live-mail?os=other
It is a more feature rich email program than Outlook Express and should provide all needed functionality.
Jul 12, 2011 | Microsoft Computers & Internet
How to instal outlook express?
Outlook express only comes with windows xp and earlyer windows versions.
However in windows vista microsoft did replace outlook express with windows mail and
in windows 7 they left it completely out of the package.
In windows 7 you'll have to install windows mail from the windows live essentials package, wich is free to download.
Outlook express can't be installed on windows vista and 7, use windows mail instead.
Download Windows Live Essentials here: http://explore.live.com/windows-live-essentials?os=other
May 22, 2011 | Microsoft Office Professional 2007 Full...
Somehow I have managed to remove my outlook express, where can I download it again??? old lady need help
If you're using Windows XP you can try this:
Go to control panel, open Add/Remove programs, on the left side click on Add/Remove windows components, put a check mark on outlook express and then click next. It will activate Outlook Express again on your Windows XP.
Apr 12, 2011 | Microsoft Computers & Internet
My son cannot get to his new email address
I am sorry but without more information I cant help you or him.
I need to know what kind of email address he has. Is it one of the cheapo free ones from google (gmail) yahoo or hotmail? Or is it a good old smtp email address that you would access from outlook express or windows email program?
windows xp and older used outlook express as a default email program. Vista and newer have a windows mail program somewhat inferior to the old outlook express.
Gmail, yahoo, and hotmail are all browser based and as long as you know your signin and password you can access it from any computer.
Apr 12, 2010 | Dell Dimension 2400 PC Desktop
Dell E520.Outlook Express
taking the backup of your outlook and reinstall the window.
Jan 19, 2010 | Dell Dimension E520 PC Desktop
I reloaded vista and now have microsoft outlook but want outlook express and can not find it on my PC, (gateway GT5228)
Microsoft Outlook Express does not have its own setup program. Outlook Express is distributed as the mail client for Microsoft Internet Explorer. The Internet Explorer setup program includes the option to install Outlook Express. So, download IE latest version and install OE in it.
Jan 14, 2010 | Gateway GT5228 PC Desktop
Reinstall outlook
to install outlook express, make sure you have the windows installation cd, insert the cd and click on control panel, choose add/remove program, click on add/remove windows components and unchecked the outlook express box to uninstall outlook, check it to install outlook.
Aug 04, 2009 | Microsoft Outlook Express
How to import Outlook Express mails to Windows
Open Outlook Express go to File then Export and proceed to what you want to export. Follow the instructions from there. You will need a flash drive or CD to save the files and move them.
Next go to Windows Mail, go to File then "Import".
Follow the instructions and you should be good!
Mar 20, 2009 | Microsoft Windows Vista Ultimate Edition
Our Outlook Express has vanished from our computer. Can you tell us why and what we can do to re-install it. Thank you, Norman Crites
Click start, Click RUN, type: msimn.exe, Press <ENTER> outlook express should open. If it does, then you can create a new shortcut on the desktop by Right Clicking the blank desktop, Click NEW, Click Shortcut, type the path: "C:\Program Files\Outlook Express\msimn.exe" then finish the wizard.
If msimn.exe give an error, the go to add/remove programs, Click Add/remove Windows Components, Check the checkbox next to Outlook Express, Click Next and finish the wizard (You may be prompted for your Windows XP CD)
If you are using Windows Vista, it doesn't include Outlook Express, Vista uses Windows Mail for the default mail handler.
Aug 25, 2008 | Microsoft Computers & Internet
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
