Question about Samsung LE Televison & Video
Samsung LE32R738D picture has stopped working
Everything seems to power up as it should but there is no picture being displayed although there is life in the screen, but if you press the menu/volume/source nothing is displayed has anybody encountered this problem and overcome it?
  • 4 Answers
SOURCE: not working at all~
Customer support is not much help, but they did say that it sounded like either the power supply ($150) or the inverter on the screen ($450) could be defective. They say they'd be happy to sell me the parts if I needed them if I called the RMA dept at 909.292.2513. Someone around here also suggested all getting together for a class action suit since this seems to happen to a ton of people with this model. I'll definitely be looking into that as well.
Posted on May 27, 2008
SOURCE: Screen is black except briefly blue upon power on or putting source on "VGA"
Your backlights power inverter board is what causes this prob. It is a Darfon V144-001.
Posted on Jul 08, 2008
SOURCE: Samsung Plasma 50" No Picture but have sound
BAD Y BOARD
Posted on Jun 08, 2009
SOURCE: was watching tv all of sudden screen turned black, with audio...
i was watcing tv afeter a while i realized there is no picture but we have sound
Posted on Sep 29, 2009
satavlad
  • 405 Answers
SOURCE: no picture
If model of your TV is LC19SB25U, TV powers up, TV has back light,but on picture or menu, The problem is the part called main unit.
Posted on Oct 24, 2009
Samsung LE32R738D 32 inch LCD television has stopped diplaying a picture
ou just need to replace the inverter board. Very es=asy and takes just a few minutes with a screwdriver.. no special tools required. You can get the inverter board from www.tvrepairworld.com and they can assist with installation assistance if needed.
Jan 10, 2013 | Televison & Video
Can hear sound but cannot see picture
Hi, if your LCD projector turns on and projects light with sound but not the picture on your computer screen, first make sure the projector is plugged into your computer. If it is, check your computer display settings. Go to "Control Panel" and "Settings" or "Windows Setup." Select "Display." Make sure it's set to appear on your laptop screen and the the projector screen. Most laptops have a "Fn" key dedicated to changing the output display setting.
If your projector turns on but emits no light or picture, replace the projector's bulb, often called the lamp. Most have a life of between 2,000 and 6,000 hours. Your projector may warn you when the lamp life is about to expire, although some models simply stop working when the lamp needs replacing.
Thank you.
Jun 06, 2012 | InFocus Proxima UltraLight DX3 Multimedia...
Camera switches off after each photo taken although blue light remains on and lens is extended
Are you sure it's not just shutting off the screen to conserve power? Try taking a new picture by pressing the shutter button half-way....does the camera come back to life?
Feb 25, 2011 | Kodak EASYSHARE Z1285 Digital Camera
HI, I was wondering if there is way to adjust the horizontal position on the screen of Sony KP-57WV600. By adjusting I mean a way to shrink the displayed picture horizontally or vertically.To give you an...
There is button "Wide Mode" on tv remote, press it repeatedly to select desired zoom mode to view best fit picture in screen.
Click Sony Support link to download user manual free copy and check page-48 for details.
Thanks.
Jan 06, 2011 | Sony Televison & Video
How do I get rid of a blank screen on my laptop
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
Sep 16, 2009 | Dell Inspiron 1501 Notebook
Dropped Ixus 50 in water...!
place your camera in a hot press, or where your boiler is, on shelf and it might dry out in a day or two, then try it again.
Aug 26, 2008 | Canon PowerShot SD400 / IXUS 50 Digital...
Kodak v550 easyschare camera
As long as the pictures look fine it is something going on with the lcd display.
If it was taking pictures the same, it could be a special effect that is turned on or the CCD is bad. It sounds like the LCD display is bad. Some cameras can be repaired at a reasonable price with a new LCD display.
Have you replaced the batteries in the camera? That might take care of the problem.
Jun 15, 2008 | Kodak EasyShare V1003 Digital Camera
Camera will take picture, but the picture is coming out black!!!! Help Please!!!
Dear vera11:
The symptoms you're describing sound like a classic case of having a faiiled CCD image sensor.
First try pressing the display (DISP) button on the back of your camera several times to see if your image returns at any time. One of the three display modes is "off" to preserve battery life. Your problem may be as simple as inadvertently pressing this button into the off mode.
If that doesn't work, try doing a reset and then removing your batteries from the camera for a few minutes, reinstalling them and turning the camera on to test the LCD screen.
If your screen is still black, but you can clearly see pictures taken previous to the problem, and you can clearly see the menu system when you press the MENU button, then you likely have a CCD sensor problem. Contact Canon Tech Support at 1-800-828-4040 to have the camera repaired.
Hope this helps.
Sincerely,
HeavyDLB
Jun 01, 2008 | Canon PowerShot A520 Digital Camera
Canon A75 No startup sound & display on LCD, rest of things works fine
Think it might be your batteries. 700mah batteries are pretty weak by today's standards (most are at least 2,500 mah these days). I'm guessing your batteries are several years old? If so, they're really only meant to have a usable shelf life of a few years, whether they are used or not. Recommend trying a new set of rechargeable batteries.
Mar 20, 2008 | Canon PowerShot A75 Digital Camera
Beep - Beep - Beep - but No Picture
1. If the camera can not focus on a subject, or can not determine the appropriate exposure setting, the camera will beep and disable the shutter button. This is to avoid improper processing of the image. This is usually due to either poor lighting conditions or movement. 2. The camera Flash Element requires ten seconds to recharge between images. Although the camera is ready to continue capturing images almost immediately in bright (daylight) settings, if you are using Flash photography the Flash element will need to charge between shots. If you try to take a picture before the Flash is charged, the camera will beep and disable the shutter button. Once the Flash unit is fully charged (10 seconds), the camera is ready to continue. 3. The batteries may be running low. LCD Display, Flash, and Playback use much more power than taking pictures. It is possible to quickly consume battery power, even if you are not taking many pictures. Try turning the Mode Dial to the OFF position to recycle power. If the camera beeps and will not take a picture under normal conditions, you may need to change batteries. Please refer to the section pertaining to Battery Life.
Sep 11, 2005 | Toshiba PDR-M25 Digital Camera
Televison & Video Logo
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
