Question about KitchenAid KEHU309SSS 30 Built-In Microwave/Oven Combination with Steam-Assist Technology
KitchenAid model KEHU309sss steam assist oven just came up with an error code f7-E2 with the message "Boiler NTC out of range". What happened?
Came into the kitchen and this message was showing on the main oven panel and I am unable to use the oven. Error f7-E2 Boiler NTC out of range.
MicrowaveSvc
  • 9047 Answers
SOURCE: kitchenaid double convection microwave /
I'm guessing the model number would be KEMS308GSS0.
In some cases, this is a glitch that can be cured by unplugging it for 1 minutes, then resetting the clock.
In other case, it may be a bad keypad (membrane switch) or control board.
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jun 08, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Works for approx 30 secs then it cuts off with a error Code F7 message.
Assuming yours is a model KHMS2050SSS0, here is what the technical sheet says about the F7 error code:
1. Unplug microwave oven or disconnect power.
2. After 40 seconds, check to see whether this solves the problem.
3. Unplug microwave oven or disconnect power.
4. Check cooling fan operation
5. Check the magnetron.
6. Check P65 connection on the relay control board.
7. Check the P56/P66 connection between relay board and relay control board.
8. Check wiring to the 1200W inverter and control system. See “Checking Inverters.”
9. Check operation of all interlock switches.
10. Replace all parts and panels before operating.
11. Plug in microwave oven or reconnect power.
12. Check voltage at 4903-1 on relay board. If it is 120, unplug microwave oven or disconnect power.
13. Replace inverter.
14. Replace all parts and panels before operating.
15. Plug in microwave oven or reconnect power.
16. If problem persists, unplug microwave oven or disconnect power.
17. Replace relay control board.
18. Replace all parts and panels before operating.
19. Plug in microwave oven or reconnect power.
20. If problem persists, unplug microwave oven or disconnect power.
21. Check for reversed plug connection on controls or loose wiring.
22. Replace all parts and panels before operating.
23. Plug in microwave oven or reconnect power.
(This troubleshooting guide presumes one does not know how to test electronic components. That's why they say to replace and part and check it again.)
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
If yours is a different model number, please reply back.
Posted on May 26, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave turns on & control panel is frozen. F2&PAN error codes
You have a shorting membrane keypad. If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and please do not leave it running unattended.
On this model, the membrane keypad is not available as a separate part, so you would have to order the control panel frame which comes with a new keypad.
In this case, you simply move your circuit board into the new frame.
That is a simple do-it-yourself job.
You can find helpful exploded view diagrams and order parts by entering your full model number (KHMS155LWH1 without dashes) from the tag on the oven here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Posted on Jun 11, 2009
  • 7 Answers
SOURCE: kitchenaid microwave hood combo KHMS155LSS
First, do not leave this machine plugged in until it is serviced. If this is a KHMS155LSS, there is a very high probability that you have a keypad short. This defect can cause the machine to start on its own at ANYTIME; while you are on vacation or at work or at night while you are sleeping etc. Contact Whirlpool Customer Service and ask for Safety Dept immediately. They will most likely send A&E (Sears) out to fix it. Although they will fix the problem, if the keypad fails again, the underlying logic self start defect is still present. You should be under warranty if it is above model. Please be polite, insistent, but polite. With KitchenAid's pathetic quality in recent years, their customer service reps get more then an earful. Also, please go to the Consumer Product Safety Commision website at www.cpsc.gov and post a Report Unsafe Products report. This will help get this model recalled before someone loses their home or life. I almost had a fire this past Monday, Labor Day, 9/7/09 when my machine self started at 3 AM with a package of bacon left in it to thaw at room temp for the morning. What a smokey mess. Chinese made garbage. Shame on Whirlpool. Long live Hobart!, please buy back KitchenAid and bring back the lost quality.
Posted on Sep 09, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: my kitchenaid microwave/convection oven shows "DOOR" on display
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
If you only need a switch, you can order a universal type here for $5 postpaid.
Posted on Sep 20, 2009
ERROR CODE F6-EO
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
May 02, 2016 | KitchenAid Kehu309Sss 30" Microwave...
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Mod.KHMS155LSS-1 Getting F-6 Fault code ????
Search Results
    Combination Microwave Wall Oven - Error Code/Message ...
    www.kitchenaid.com/...microwave...error-code...f6-error-cod...
    KitchenAidQuestion: Combination Microwave Wall Oven - Error Code/Message - F6 Error Code -F6 E8. Answer. Product Symptom: Combination Microwave Wall Oven ...
    Over-the-Range Microwave - Error Code - Starts with F ...
    www.kitchenaid.com/...microwave-error-code...f...f6...code/P...
    KitchenAidKitchenAid's product help articles give answers to your frequently asked questions (FAQs). ... Microwave - Error Code - Starts with F - Starts with F6 - F6E0 Code.
    Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kitchen Aid Model # KEMS308SSS02 and I getting the follow error message... is working and was always working but the top microwave/oven does not work. ...Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost Err/ F6 E0/ ... Most "F6/E0" fault codes is usually because of a loose wire connections, loss of ...
Feb 05, 2016 | KitchenAid Microwave Ovens
Kitchenaid microwave runs for a few seconds and then shows error code F7. Kitchenaid Phone Center never heard of this error.
Hi alykat737,
This error code F7 on KitchenAid microwave is about a function key that is stuck on ERC. You will have to Replace control board (also called ERC or clock) to fix the problem. In case you will have to buy a replacement part you may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central.
Hope this helps.
Thank you for using FixYa.
Feb 06, 2011 | KitchenAid KHMS2050S 1200 Watts Microwave...
KitchenAid KHMS 2050 SSS, doesn't heat up and indicates "Error Code F7, VH SMPS feedback, call for service"
Hi asoleyma,
This error code F7 from a Ktchenaid oven means that the function key is stuck on ERC. This can be fixed by having the control board (also called ERC or clock) be replaced.You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central. Just get your model number ready when you call.
Hope this helps.
Jan 30, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
I am getting an F7 error message frim my KHHS179lWH-2. Any ideas?
For model KHHS179LWH2, from the tech sheet located behind the controls or found online here:
F7 Power to magnetron interrupted
2. After 40 seconds, check to see whether this solves the problem. (Possible
reason: Over temperature protection for the magnetron opened.)
3. See safety info here, then check resistance of the magnetron thermostat. It should be close to 0 ohms.
4. Check the magnetron.
5. Check wiring to the 1100W inverter and control system.
6. Check operation of all interlock switches.
7. If switches operate correctly:
- Replace 1100W inverter.
- If problem persists, replace power supply board.
8. Plug in microwave oven or reconnect power.
You can find links to helpful exploded view diagrams and part ordering help here.
Nov 22, 2009 | KitchenAid KHHS179L Convection/Microwave...
Controlpanel flashes f 3
You have a faulty keypad. You could probably special order this part from a local appliance parts supply store for 50-60$ or purchase a new microwave.
Oct 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
May 26, 2009 | KitchenAid KHMS2050SSS Microwave Oven
Error Code
F7 problems are usually caused by poor connections. I suggest to unplug the ribbon connector off the control board and cleaned the copper connectors using alcohol or with a pencil eraser. If that does not work the touch pad may be defective.
Jan 19, 2008 | KitchenAid KHHS179L Convection/Microwave...
KitchenAid KEHU309SSS 30 Built-In Microwave/Oven Combination with Steam-Assist Technology Logo
385 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Stu Ungar
Darial Jr Lasaria
Darial Jr Lasaria
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
