Question about Canon PIXMA MP530 All-In-One InkJet Printer
Set up. i can't remember which line goes where. the phone line on top or the modem line on top?
    Problem Solver:
  • 4 Answers
Phone line is the top and modem on the bottom. Take a look in the back and where you see the phone symbol that's your phone line.
Posted on Jan 27, 2009
What happen when a adsl line work with a phone but not with a router
The phone line does two jobs. Voice phone which is what it was originally used for and ADSL modem which works at a high audio frequency.
Somewhere between the phone socket and the modem should be a filter splitter. One part goes to the phone and the other to the router. Make sure you have that.
The modem will have a power light and several additional lights. Assuming the power light is on we are interested in two of them; The ADSL light and the Internet light. When you switch the modem on you should first see the power light flash then go solid. Then the ADSL light will flash and then this should go solid. If this light does not come on then you have not plugged the phone wire in properly. If this light just keeps flashing slowly then the modem can't see an ADSL signal on the phone line. If you have a spare router you could try it and see if the ADSL light goes solid on that.
If the ADSL light is fine then the modem has locked onto the signal on the phone line, sync'ed. If not then this is the problem you must solve. Ask your ISP if service is set on your line.
The next light is the Internet light, this maybe a symbol like an i or a world. This light will begin flashing then go solid. It will flash with Internet traffic. This means you have Internet, as far as the modem is concerned. If this light does not stay on then your ADSL account name and password maybe wrong. You can correct this but that's a different question you need to ask.
Feb 18, 2015 | D-Link Dsl-2750b Adsl2 Verizon N Wireless...
How do i connect my wireless internet
Connect your wireless modem into the telephone or ADSL capable line from your phone company or internet service provider (ISP.) Remember to place an line filter between any hard-wired phone and also the modem. (The modem will have at least one in the box, use it for the modem.) Open the modem box and read all the instructions carefully. Connect your PC with a CAT5 (RJ45) cable in the modem box to the modem... yes, you need to use a cable to set it up. This is bit wider than the normal telephone jack and there is a place for it on your PC called an "Ethernet" plug. The modem should have a CD ROM that will help you set it up. Before you begin, make up a unique, easy-to-remember name for your network, also think of a password that you want to use to secure your wireless connection. Call your ISP and tell them what the brand and model of your wireless modem is and they will talk you through the set-up at no cost. The key thing to have handy is the "Default gateway URL" This is sequence of numbers and periods between them that is absolutely essential to set up your wireless modem. If you don't have it, don't worry... there is a command prompt (CMD) that your ISP will instruct you to use to retrieve it after you have installed the modem's driver and are ready to set it up. Normally, the first 2 to 4 passwords required are to get access to set up the modem... using "admin" is just fine. (Passwords are most always asked in duplicate to reconfirm the password.) The important password is the one that allows access to your home or business wireless network. Remember to write down your username, unique password, and the network name for your network and the Default gateway URL so you can easily diagnose connection problems later. I keep this stuff in the modem box with the cable, instructions, and CD. Good Luck
Oct 05, 2012 | Panasonic TC-P42G15 Plasma TV
WILL NOT CALL OUT SAYS TO CHECK ISDN LINE WE ARE NOT USING ISDN LINES WE USE THE INTERNETWhat's your problem?
When you use the internet you are using a connection to your ISP (Internet Service Provider) over some kind of line whether it is a phone line using a modem or a cable for a cable modem. ISDN is just another way that you connect to the internet. ISDN stands for Integrated Services Digital Network. ISDN is a digital phone connection system and is often used to give you higher and more reliable service. So, what they mean is to call your phone company and ask them to check your line, that is all they mean. Remember, the Internet itself is just a huge set of connections using an unbelievable number of types of connectivity from phone lines to space based relays and how you get there is through whatever line you have set up between you and your ISP. Does that help?
May 23, 2012 | Polycom Viewstation Pvs-14xx & More...
How do I use my Pearl as a modem for my destk top that does not have bluetooth?
You can use either a USB cable to connect the phone to the PC or buy a bluetooth dongle that connects to the USB port of your PC and then communicate with the phone. But remember to install your phone on the PC from the CD that came with the phone. And after all is done then you will have to set the phone as a modem in the Phone settings. Do not worry about this as calls will still come through even if you are in the middle of surfing or downloading.
Oct 07, 2010 | Cell Phones
When i reset my modem it goes through the normal start up process but when it is trying to connect online the lights start flashing.(receive &send ) lights flash.
The light pattern you have described shows that the modem can not establish a connection to your internet service provider (ISP). This is typically do to a signal related issue. To trouble shoot the problem you will need to connect the modem directly to the main cable line where it first enters into the home. You will know when the modem establishes a connection by the top 4 lights becoming solid green. If at any point all 4 top green lights start to blink in sequence than you will need to contact your internet service provider to "unwall the modem". Remember most internet service providers require you to register new modems on there network. So if you have not all ready completed that process you will most likely not have access. If you can not get a connection from the main line than there is a issue with either the modem or the signal coming into the home and you will need to contact your internet service provider.
I hope that information above has helped is some way.
If possible please rate this solution.
Aug 31, 2010 | Arris SURFboard SB5101U DOCSIS 2.0 Cable...
Where do i plug the lines from my 6310 all in one into my modem
On the back lower right of the unit you will see two ports for regular phone lines and one port for en RJ-45 ethernet cable. The phone port are for a phone line to come into to accept faxes through a ground line. If you still have regular phone service, the line coming from the wall outlet goes into the port marked "line" on the back of the All-In-One. The other port on the back of the printer is for a phone line to hook into a portable phone, that way you can answer the phone if there is no fax. The other port, for the ethernet cable goes to the modem or router, however you happen to have it set up.
Oct 04, 2009 | HP Officejet 6310 All-In-One InkJet...
Divice goes to intercom not a outside line
just dial 9.
If this is more of an issue of auto line select, we need to know the model of the phone system. Merlin 820? 410? 1030? 3070?
Sep 29, 2009 | Avaya AT&T Merlin Basic Telephone & Modem...
How do I hook up my acer aspire to my existing phone line modem? I know there is an ethernet cable that goes to the Aspire but I need something that fits the phone jack also. Is there an adapter?
Hello, I regret to inform you that you cannot connect a phone line directly into an ethernet port. The phone line is an analog signal and requires a modem to convert it to a digital signal the computer can understand.
+++++Please remember to leave feedback to help keep this site free+++++
Sep 02, 2009 | Acer Aspire One Netbook 8.9" Notebook
Have SBCglobal with 2wire but want N wireless capability
Follow the dots -
2 wire DSL wire to back of DSL modem.
Ethernet cable out of DSL modem, to current router (if you have one).
Ethernet cable out of current router (if you have one) to new Wireless N router.
If you currently have a wireless G router, keep it, or, use the new Wireless G/N router alone. You will need to set up all security settings again if you remove your current router, and if the new router is N only, you will need to make sure all your wireless connecting computers have wireless N cards in them.
Jan 24, 2009 | 2wire 2700HG-B Router (2700HGB)
No directions for attaching a phone line to mfc 240c.
small phone line goes from your wall switch to the rear of your ADSL modem, then the fatter wire goes from the modem to the input on the rear of your computer.
If it is wireless modem,,and you have a wireless connection on your computer then it should discover the connection by itself, after hooking all the wires up properly
Jan 16, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
32 people viewed this question
old marine
old marine
