Gestetner - COPIER, PRINTER, & SCANNER Copier
Problem for Gestetner - COPIER, PRINTER, & SCANNER Copier
Functional problem code SC542-00
By rich495 on Jan 21, 2009
I have an older copier gestetner 3245e and when I turned it on today it showed this code and I have not used it for a couple of days. It said to try turning the main power switch off and then back on which I did and code still shows.
Best Solution
posted on Jan 21, 2009
Helpful)
jrmicallef
Rank: Guru
Rating: 90%, 62 votes
Enter SP mode > Clear (yellow) button > 1 0 7 > and press and hold the Stop (red) button for 3 seconds.
Then switch off and on the machine.
If error still there, probably you have a problem in the fusing unit.
Possible causes are:
Thermistor defective;
One of the fusing lamp is open circuit;
Thermofuse open;
Fusing unit connector defective; and
Power supply board.
Good luck and please rate me, thanks.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Gestetner - COPIER, PRINTER, &
Questions and Unsolved Problems for Gestetner - COPIER, PRINTER, &
Do you recommend Gestetner - COPIER, PRINTER, & SCANNER Copier?
Answer
Answer
j'ai achete 1 copieur et il afiche inserez le compteur cle ou entrez le code utilisateur puis... (More)
Answer
# 756 Bsk III Stage 5 th Block 5th Cross, Bangalore - 560 085
Answer
where can i get the hp deskjet f2235 printer drivers please guide me.
Answer
I bought a printer and stuck the plug in my *** how do I get the damn thing to work now ??? Confused... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Copiers Experts
Top Copier & Fax Repairmen
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
