Question about Dishwashers
Maytag dishwasher MDBH969AWQ1 will not start
Clean button is flashing. Want to start a new cycle. Push on start/resume button and nothing happens. Clean button continues to flash
  • 11 Answers
SOURCE: Model 17019 ~ Clean light flashing
try pushing heat dry then normal back to back three times. then start. this should clear it up but only temporarily. you have a problem in your heat element or your control board.
Posted on Mar 21, 2007
SOURCE: Need help with dishwasher
I misplaced my diagnostics paperwork, but I found you here and you saved my life!  The wife is much appretiative!
~Teddy Bear
Posted on Oct 20, 2007
SOURCE: "Clean light" keeps blinking; dishwasher won't start new cycle
It says in the manual to check the heating element.
Posted on Sep 10, 2008
SOURCE: Maytag dishwasher, no power, then flashing lights, now no power.
Had the same problem, removed the kick panel to find a set of instructions under the insulation, had to push a sequence of the panel buttons, its been running great for a couple of weeks now!
Jeff
Posted on Mar 08, 2009
SOURCE: ''clean'' light flashing (whirlpool Dishwasher GU2300XTLS1 model)
I had the same problem recently and a repair person came to my home to fix the dishwasher. He said he had to reset the control panel. He did this simply by making sure the soap dispenser door inside the washer was closed, then making sure the main dishwasher door was closed and locked. Then he quickly pushed the Heated Dry button and the Hight Temp wash button alternately. He said each button needed to be pushed twice within five seconds. After he did this all the lights on the control panel came on, then turned themselves off before the washer went in to a test cycle. This simple reset fixed the whole problem. Works great so far.
Posted on Jun 16, 2009
Dishwasher starts on its own (no house is not haunted). Start resume button flashes
have a service technician in as it appears to be a problem in the program board
could be moisture across the circuit board
Feb 06, 2016 | Maytag MDB7749AWQ Builtin Dishwasher
Dishwasher shuts off during cycle
Since the troubleshooting and repair process is too lengthy to include here, please go to the following link: http://www.appliance411.com/service/repairmanual.shtml
to open [or download] the service / repair manual. It is free.
Scroll about half way down the page, in the left column, under Maytag products, select the Maytag / Jenn Air / Jet Clean II "Tall Tub" Dishwasher repair manual... it covers your model dishwasher..
It includes a troubleshooting guide as well repairing instructions
Best wishes on your project.
Dec 01, 2013 | Maytag MDB9600A Jetclean II Built-in...
Reset button maytag dishwasher
  • 1 Open and close the dooricon1.png of your Maytag dishwasher.
  • 2 Locate the "Rinse" button on the dishwasher control panel. Press and release the button five times in quickicon1.png succession.
  • 3 Press and release the adjacent "Drain/Off" button on the control panel two times; this will deactivate the dishwasher's demo mode and reset your dishwasher.
  • If you need to restart your dishwasher or forgot some dishes and want to open it during a cycle and restart it
  • 1 Press the "Cancel Drain" button on the display. Allow about 2 minutes for the dishwasher to completely drain.
  • 2 Choose a cycle under "Cycles" on the panel.
  • 3 Select an option or options under "Options" on the panel.
  • 4 Push the "Start Resume" button.
  • Oct 24, 2013 | Dishwashers
    Service number kuds301xbl2
    I would find the electrical breaker for this unit and shut it off for a minute, then re set the breaker thus resetting your unit.
    Apr 28, 2013 | Maytag MDBH975AWS Stainless Steel...
    Dishwasher is locked but the door is open start/resume light flashes continuously
    shut the door and push the start/resume button and wait 5 min before doing anything else. if the start button is flashing that means the cycle was interupted in some way.
    Apr 08, 2012 | Dishwashers
    I have filled dishwasher selected temperature and the start light is flashing but nothing happens I think the m/c type is 7197
    The Start/Resume light is flashing
    This flashing light indicates that your cycle or start-up was interrupted.
    Possible causes: The door opened during the cycle, or the power was interrupted.
    To resume operation: Make sure the door is closed, and press Start/Resume.
    The Clean light is flashing
    You should call for service if the Clean light is flashing and the machine is inoperable. It is normal if the Clean light stays on after the cycle is complete. The Clean light is an indication that the dishwasher has been run and that the dishes inside it are clean. Once the door is opened after the cycle is complete, the light will shut off.
    The lights are rapidly flashing
    Any key that gets stuck will rapidly flash. Press the key a few times in order to release it or press Cancel.
    The Rinse Only light is rapidly flashing
    If multiple keys are stuck, the Rinse Only light will flash. Press each key, one at a time, to release the stuck keys, or press cancel.
    Jun 28, 2011 | Dishwashers
    My Maytag QuietSeries 400 dishwasher won't start. Sometimes 88 flashes on the display and that's all. What does that mean? Model # MDB7601AWB
    Dishwasher will not start Is the door open or unlatched?
    Make sure the door is completely closed and latched. On models with a dual-digit display, the control displays "- -" during a cycle if it believes the door is not latched. Check for obstructions (spoons, etc), interfering with the door operation. A lower dish rack that is installed backward will also cause incomplete door closure.
    Check your household electrical box to see if a fuse has blown or if the circuit breaker has tripped. If the unit has a plug-in power cord, make sure it is plugged in.
    Does your dishwasher have a rotary timer knob? (Some Models)
    The cycle selection must match the position of the timer knob. Turn the timer knob to the beginning of the preferred cycle. The timer knob should click when you reach the start of the cycle.
    Is the control lock option activated?
    Press and hold the Heated Dry option (button with lock icon) for three to five seconds and the light should turn off. Instructions are also placed on the label on top of the inner door to unlock the controls.
    Is the delay start option activated?
    To cancel the delay and cycle, press Cancel/Drain.
    Has the motor stopped for less than 10 minutes?
    The motor may have stopped due to an overload. If this is the case, the motor will automatically reset itself within 5-10 minutes.
    Is the Start/Resume indicator flashing?
    Opening the door or interrupting the power can stop the cycle. Close the door and press Start/Resume. If the Start/Resume indicator flashes three times when you press Start/Resume, the dishwasher is waiting for you to open the door after the last cycle. Open and close the door, and then press Start/Resume.
    On models where the controls are on top of the door be sure to close the door within 3 seconds of pressing the Start/Resume to start or resume the dishwasher cycle.
    Is the water shutoff valve (if installed) turned on?
    Make sure that the water shutoff valve is turned on.
    Jun 19, 2011 | Maytag Dishwasher
    I have a Maytag Quiet Series 300 Dishwasher (can't find any other model number etc). The normal and high temp wash lights are steady and the Start/Resume light is flashing. I've tried turning off the power...
    Turn everything off first then turn off the power at the switch. Wait 10 minutes, then turn all power back on..the electronics should reset itself..also, verify it is draining properly... cheers
    Nov 14, 2017 | Maytag 24 in. MDB5651A Built-in Dishwasher
    Have a brand new maytag dishwasher. When the cycle is finished the clean light stays on and I have to push buttons to clear is this normal?
    If you open the door after the cycle, does it clear the display? Mine is a different maytag model, and when it's done it shows the display as clean. The display will go blank when I open the door manually... let me know if that helps.
    KEN
    May 10, 2009 | Maytag 24 in. MDB5651A Built-in Dishwasher
    Normal Light Blinking - Dishwasher not working
    I HAD THIS SAME PROBLEM. TRY PUSHING THIS SEQUENCE OF BUTTONS: HEATED DRY, NORMAL, HEATED DRY, NORMAL. THIS RESET MY PANEL AND IT IS WORKING NORMALLY NOW. I FOUND THIS SUGGESTION ON ANOTHER SITE.
    Sep 14, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
    Dishwashers Logo
    43 people viewed this question
    Top Dishwashers Experts
