Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
GE disposal won't drain
Sink will not drain. When I turn on the disposal it swirls the water around and the water turns dark brown and has pieces of food in it. The disposal is very loud and shakes the counter and sink...the longer it's left on the harder the shaking. Also caused the dishwasher to fill with dark brown water and overflow when I ran it.
The disposal is a GE Disposal model gfc1020f...The site wouldn't let me put down that disposal.
  • 10,865 Answers
It sounds to me like the knock out plug leading from the disposal has never been removed. Remove the drain like and you may find that there is a thin plastic wall preventing any water from leaving the disposal. Just place a small screwdriver in the opening up against the plastic barrier and tap it out with a hammer. good luck
Posted on Jan 21, 2009
Water does not drain from sink unless disposal is turned on and running. what could it be?
It would appear there is a blockage (a clog) in the disposal. You might try "FIRST" unplugging the disposal from under the sink. Put a piece of masking tape over the switch to secure it in the "OFF" position. Then remove the black rubber strainer from sink leading down into the disposal. (just pull it out by hand) Clean out all debris by hand. Put the removed debris in the trash can. Run hot water down into the disposal assuring it to drain properly. Do not put items into the disposal which cannot be ground up easily such as potato peelings and meat products.
Jun 24, 2014 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Tip
How to unclog a garbage disposal
Before you tackle this problem, you should understand how to use your disposer so you'll probably never have to deal with a clog again. You can easily use put a sinkfull of waste down your disposer without a hitch. It's all about controlling the amount of water mixed in with the waste. Your disposer is designed to break waste down to pieces a little smaller than a BB. This is efficient but without much water, the pieces will clump together right where the disposer connects to the drain line, and will cause a clog. Never turn on the disposer without a full flow of cold water. Cold water not only helps to cool the motor, but keeps any fat solidified so that it doesn't build up on the walls of the pipes. The full flow of water will allow the disposer to mix the waste in and it'll go right down the drain. The second thing you must control is the amount of waste that goes in the disposer. It's really a bad idea to put more than like half a cup of waste in the disposer without it running. Ideally you'd turn on the water first, then start the disposer, then feed the waste in. Listen to the disposer running with waste in it. It sounds different when the waste inside is gone. Use this to get yourself used to keeping up with its pace. The problem with any disposer is that they work so fast, they can grind the waste faster than the water can carry it away.
Whatever you do, don't use a chemical unclogging product. Over time, this can damage the metal components of the disposer, and if you have to call a plumber, they will charge you extra because these chemicals make their equipment wear prematurely and can burn the skin.
If water doesn't drain, make sure the problem isn't fixed by simply turning the disposal on. If the water just swirls around, you'll probably need a plunger. When you want to use a plunger to unclog your disposal, the easiest way is to use suction more than pressure. When you push down on the plunger, the pressure from it will cause the backed-up waste to compress even further and make it impossible to push water down. You want to push the plunger down so that it "leaks" water out, and, when the plunger can be pushed down no farther, make sure it then has a good seal on the disposal's opening, and yank the plunger up pretty hard. This will pull the backed up waste back, mixing it with the water and will probably unclog the unit in only a couple strokes. Be careful not to soak yourself when pulling up on the plunger. In a pinch, a full soda can will actually form a seal and can be used in place of a plunger for disposals that have a splash guard made of one piece. If water is backed up into the other sink bowl, that means the clog is in the trap and not in the disposer itself. One way to fix this is to make sure the other bowl(s) of the sink are firmly stopped up. If you use a stopper you'll most likely have to push down hard on the stopper while plunging the disposer to form a good seal. If none of this helps, you may need to take apart the sink trap. This can be done by loosening the two nuts on the part of the drain pipe assembly shaped like a "U". You then may be able to clean the clog directly out of the u-bend or you may need to snake the pipes. If you take the pipes apart, have a bucket under there to catch the large amount of that will gush out.
on Dec 07, 2009 | Plumbing
Will not drain...but is turning....i tried to reset by pushing the red button and did nothing...i took the L wrench and turned it from the bottom and still nothing...sink is full of water too..what can i...
1) If disposal will not drain: Clean the tubular drain under sink.
Remove 2 nuts on p-trap, and trap falls loose, then remove tailpiece on side of disposal, hand rag over opening to direct water downward, turn on water, turn on disposal and see if disposal empties, clean p-trap, and then reassemble tubular drain.
2) If disposal will not drain and will not run: Clean tubular drain, check for power to disposal.
If disposal is getting power and will not run, and reset button is not tripped out, and cutter disk rotates freely, then disposal is bad.
I wrote ez disposal replacement steps that include tips for tubular drain.
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Aug 21, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Water drains back into dishwasher from sink or disposal
You've got a broken piece of glass or something holding the drain valve open.
Solenoid operates the valve to drain water from dishwasher into drain line.
When power shuts off to solenoid...valve closes.
If valve is blocked by a piece of glass or toothpick or a sliver of bone...it can't close and draining water from disposal or sink can back flow into dishwasher.
I had a piece of glass caught in mine.
Hope this helps...
Jul 23, 2011 | GE Dishwashers
Never have used a garbage disposal, now after 4 month and using it only about 30 times the water in the sink will not drain. When I turn on the garbage disposal the water in the sink swirls so I know it is...
hello fowl..... you have a blockage in the garbage disposal. you can use a chemical drain cleaner and pour it into the sink where the disposal is located. you should also look into that drain with a flashlight to make sure that there is not a fork or some other object causing the blockage. If you do not choose to use the chemical, you can also disconnect the disposal using the wrench that should be under the sink where the disposal is located. if you choose this method, have a pail handy to catch the water. also unplug the disposal before you work on it. Joe
Apr 24, 2011 | Microwave Ovens
GE Triton won't drain completely
Hi Tina! (say Hi to the Family, too)
Your drain hose from the dishwasher (DW) was installed incorrectly after the DW was moved back into place. Good news!!! Easy fix. All it takes is a 5/16" nut driver (or socket) and some vinyl electrical tape.
Look under the sink, you'll see the white drain hose hooked up to (most likely) your disposal. You'll notice that it just kinda slopes downhill 'til it disappears through the cabinet, right? Well, the slope in question is actually the culprit! It's siphoning water from your sink and down into the DW. Everytime you run water in the sink, some of it goes over to your DW instead of down the drain. Go figure, right?
Here's the fix... You have to re-route your drain line to make it have an upside down "J" in it before it connects to the disposal.
Use your 5/16 and loosen the clamp at the disposal and remove the hose. Pull on the hose to get as much slack as you can from the DW and into where you're working. Now route the hose between the sinks (the recessed area there underneath) and THEN into the disposal. Now tighten the hose clamp to secure the hose to the disposal. For extra measure, use your tape to secure the hose to a water line in the back by the water valves.
Seriously easy job, Tina and Family. Maybe 15 minutes.
SG
Mar 23, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
Garbage disposal...won't drain
There should be a reset switch on the bottom of the disposal.
When using a disposal, always run water first, then turn on disposal. Then dispose food. Then keep water running until it all sounds clear before turning it off.
Mar 11, 2009 | GE 24 in. Profile PDW7800 Built-in...
Dble sink, one with the garbage disp. won't drain standing water
It's a drain clog within the disposal. Try a drain cleaner, if no luck, you will likely need to replace it.
Feb 18, 2009 | GE 24 in. Profile PDW7800 Built-in...
Dishwasher leaks at top of sink
hi some old dishwasherhas that y ,,,,,,the y is there so when washer drains it does not go bact to the machine,,,,,,,,some times the pipe that goes from y to disposer gets clugged and you can turn the hole tourd the sink the drain into sink
Jan 27, 2009 | GE 24 in. Profile PDW7800 Built-in...
Garbage disposal spouting water after turned off
Hello, turn on the disposal without water and pour hot water into disposal. Be careful not to let it splash back on you! If this doesn't help you have to remove the drain and drain trap and clean them out. If you need more help let me know. Good luck.
Jan 23, 2009 | GE 24 in. Profile PDW7800 Built-in...
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
336 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Mike
Treefrog15
Treefrog15
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
