Question about CellularFactory Quikcell Q9 Mini Bluetooth Headset Red for Acer phone
My bluetooth doesnt display LED light to show charge status when i plug it in? i cant tell if its charged or not.
I plug the charger into the headset and not a single LED light comes on...it is supposed to display a red LED light when charging and a blue LED light when its finished charging..... but nothing happens at all...
My nokia bh503 headset not charging
Leave it plugged in for 4 hours. Yello should turn red then green when fully charged
Oct 20, 2014 | Nokia Bh-503 Bh503 Bluetooth Stereo...
Red blinking light
Hi, Ephraim. The flashing red light indicates that the device is showing "low battery". It could be that the LG phone charger fits the charging port on your bluetooth headset but it is not compatible with your device. In order for you to know that it is charging, the device should show a steady red light(means charging).
Please take a look at the table reference below.
•With the Charger Plugged In
______________________________________________________________________
•Headset Indicator Headset Status
Red-----------------------------------------------Charging (battery level less than 50% charge)
Yellow-------------------------------------------Charging (battery level more than 50% charge)
Green--------------------------------------------Charging complete
With No Charger Plugged In
Off ---------------------------------------------Power off
Three blue flashes------------------------Powering on/off
Steady blue --------------------------------Pairing/connect mode
Rapid blue/purple flashes -------------Connection successful
Quick blue flash --------------------------Incoming/outgoing call
Slow blue pulse --------------------------Connected (on a call)
Slow blue flash ---------------------------Standby (not on a call)
Slow red flash ----------------------------Idle (not connected to phone)
Slow purple pulse -----------------------Connected call muted
Steady red ---------------------------------Attempting to connect
Quick red flash ----------------------------Low battery
Note: After 20 minutes on a call or of inactivity, the light stops flashing to conserve power, but the headset remains on
Hope that'll help you in some way.
**Please rate my post and/or leave a comment** ...Thanks...
Sep 25, 2013 | Motorola Mobility H560 Bluetooth Headset
Does not charge when the charger is plugged. The Red light does not turn on.
Just wait for the battery to be completely drained-I did that to mine just now.after the battery is completely drained, I charged it, and it began functioning again.
Oct 05, 2010 | Nokia BH-503 Bluetooth Headset
Does the LG HBM-210 have to be on to charge
According to the instructions provided by the operator manual...
"Connect the charger to the charging port.
- When the charger is connected, with the power on or off,
the Headset will turn off automatically, and cannot be used.
While charging, the LED indicator will show a solid blue light.
- The buttons will not function while the device is charging.
- It takes 2 hours to fully charge the Headset.
- When charging is complete, the LED indicator will turn off.
Jan 20, 2010 | LG HBM 730 Bluetooth Headset Wireless...
I plugged the AC charger into the bluetooth headset but no charging lights showed
hi
may be your charger is not ok try to charge your bluetooth by another charger
thanks
your friend from fixya!
Oct 26, 2008 | Cell Phones
Wep210
There's a small power jack under a tab at the base of the unit. I found it only charges if you plug it into the transformer travel charger. For some reason plugging it in the PC USB port doesnt work.
If the unit is being charged a red LED will light up, turns blue after 2/3 hours when its fully powered up.
Jan 21, 2008 | Samsung BLUETOOTH? WEP210 MONO HEADSET...
Charging
Jan 08, 2008 | Samsung BLUETOOTH? WEP210 MONO HEADSET...
CellularFactory Quikcell Q9 Mini Bluetooth Headset Red for Acer phone Logo
16 people viewed this question
Top CellularFactory Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a CellularFactory Radio Communication Expert? Answer questions, earn points and help others
