Home | Copiers | Functional problem cod...
Copiers
Problem for Copiers
Generic problem for all Copiers
Functional problem code SC542-00
By rich495 on Jan 21, 2009
I have an older copier and when I turned it on today it showed this code and I have not used it for a couple of days. It said to try turning the main power switch off and then back on which I did and code still shows.
Best Solution
posted on Jan 24, 2009
Very Helpful)
jpd8
Rank: Guru
Rating: 87%, 67 votes
SC542 error = Fusing temp. warming-up error.
The fusing temp. does not reach the fusing standby temp. within 125 seconds after the main power switch is turned on.
Causes:
Thermistor defective or out of position
Fusing lamp open
Thermofuse open
BICU defective
Power supply brd defective
Poor connections
ALWAYS DISCONNECT THE POWER FROM THE WALL BEFORE WORKING ON MACHINE
*** replace the thermistor AND the thermofuse*** If one went bad then the other will probably go bad soon. ( 95% it is one of these). You can check lamp first by disconnecting one end and putting a meter on it to see if it is open -- if open then replace.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Copiers
Questions and Unsolved Problems for Copiers
Answer
where in the Moorestown, NJ area can I get repair of my Xerox 1250 copies it has a light on the... (More)
Answer
conica minolta bizhub 35o vs kyocera in same price range
Answer
how can i solve the black line and half black of whole paper?
Answer
power light on but won't copy, it stays in sleep mode. does not wake up.. how do we get it to wake... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Copiers:
Top Copier Experts
Rank: Guru Guru
Solutions: 1481
Experience: The Truth is a set of corrected errors. Erwin Schroedinger
Ask Me
Find more Copier Experts
Top Copier & Fax Repair
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
