Question about sensor. computer control sensors. coolant temperature. engine
Coolant spraying out from a plug on side upper position
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 90 Answers
Need more info ,but you can try tightening the plug or replacing gasket/oring then tighten.
Posted on Nov 23, 2013
How do you remove the radiator on a 2007 chrysler sebring limited 3.5
REMOVAL
  1. Disconnect negative cable from battery.
  2. Remove radiator upper crossmember support. WARNING: DO NOT REMOVE THE CYLINDER BLOCK PLUG OR THE RADIATOR DRAINCOCK WITH THE SYSTEM HOT AND UNDER PRESSURE BECAUSE SERIOUS BURNS FROM COOLANT CAN OCCUR.
  3. Drain the cooling system.
  4. Remove the radiator fans.
  5. Disconnect coolant reserve/recovery hose.
  6. Remove vapor purge solenoid from mounting bracket.
  7. Disconnect upper and lower hoses from the radiator.
  8. Remove the A/C condenser side brackets to radiator attaching screws. Separate the condenser from the radiator by lifting upward to disengage from lower mounts. Allow the condenser to rest in front of radiator.
  9. Radiator can now be lifted free from engine compartment. Care should be taken not to damage radiator cooling fins or water tubes during removal.
  10. INSTALLATION
    1. Be sure the air seal is in position before radiator is installed. Slide radiator down into position. Seat the radiator with the rubber isolators into the mounting holes provided, with a 10 lbs. force.
    2. Position air conditioning condenser onto the radiator lower mounts and install upper screws. Tighten fasteners to 5 Nm (45 in. lbs.).
    3. Install the radiator upper and lower hoses.
    4. Connect the coolant reserve/recovery hose.
    5. Connect the vapor purge solenoid to the mounting bracket.
    6. Install the radiator fans.
    7. Install the radiator upper crossmember support.
    8. Fill the cooling system.
    9. Connect negative cable to battery.
Nov 10, 2016 | 2007 Chrysler Sebring
Why is the top spray arm not turning
All of the water coming to the upper spray arm comes through the feed tube. If the feed tube is blocked or the probe flapper is hung open, water will not flow properly to the upper spray arm. Be sure that when you push in the upper rack the manifold probe is in position in the feed tube. Try adding more water in the tub to see if the upper spray arm starts rotating. Other possibilities; low water charge, cracked spray arm & poor wash pump performance.
Jul 28, 2016 | Dishwashers
How to test water flow syatem
Take off the upper rad hose and position it safety as not to get sprayed. Then start the engine and see if water (coolant ) is pushed thru the system
Dec 08, 2012 | 2002 Mazda Tribute
Thermostat on 2005 aviator location
Removal & Installation
Print
4.6L & 5.4L SOHC Engines
  1. Partially drain the engine cooling system to a level below the thermostat.
  2. Disconnect the upper radiator hose from the water outlet adapter.
  3. Remove the power steering reservoir upper mounting bracket.
  4. Remove the bolts and remove the water outlet adapter.
  5. Remove the water thermostat and the O-ring seal. Discard the O-ring seal.
  6. Installation is the reverse of the removal procedure. Tighten the water outlet adapter bolts to 18 ft. lbs. (25 Nm). Tighten the power steering reservoir upper mounting bracket as shown in the accompanying illustration.
    Fig. View of the power steering reservoir upper mounting bracket and tightening specifications
    Fig. Exploded view of the water outlet adapter and tightening specifications
5.4L & 6.8L Engines
  1. Partially drain the cooling system to a level below the thermostat.
  2. Disconnect the upper radiator hose.
  3. Remove the coolant outlet connection, as follows:
    1. Remove the bolts.
    2. Remove the coolant outlet connection.
  4. Remove the (A) coolant thermostat and the (B) O-ring seal.
  5. Discard the (B) O-ring seal.
    Fig. Remove the (A) coolant thermostat and the (B) O-ring seal
To install:
NOTE Thermostat must be installed as illustrated.
  1. Use a new (A) O-ring seal to position the (B) coolant thermostat in the (C) upper intake manifold.
    Fig. Use a new (A) O-ring seal to position the (B) coolant thermostat in the (C) upper intake manifold
  2. Install the coolant outlet connection, as follows:
    1. Position the coolant outlet connection on the upper intake manifold.
    2. Install the bolts and tighten to 15-22 ft. lbs. (20-30 Nm).
  3. Connect the upper radiator hose.
  4. Fill the cooling system.
  1. Before servicing the vehicle, refer to the precautions section.
  2. Partially drain the cooling system to a level below the thermostat.
  3. Disconnect the upper radiator hose.
  4. Remove the coolant outlet connection, as follows:
  5. Remove the (A) coolant thermostat and the (B) O-ring seal.
  6. Discard the (B) O-ring seal.
To install:
5.4L DOHC Engine
  2. Disconnect the upper radiator hose, the heater water inlet hose and the heated PCV inlet hose from the water outlet adapter.
    Fig. Disconnect the upper radiator hose, the heater water inlet hose and the heated PCV inlet hose from the water outlet adapter
  3. Remove the water hose connection and thermostat.
  4. Installation is the reverse of the removal procedure. Tighten the mounting bolt to 18 ft. lbs. (25 Nm).
    Fig. Exploded view of the thermostat-5.4L DOHC engine
Aug 13, 2012 | 2004 Lincoln Aviator
How to replace thermostat on ford f350 turbo diesel
The F-350 designation refers to a 1-ton Ford F-Series pickup truck. The thermostat in your diesel-powered Ford closes off the flow of coolant when the engine is cold, forcing the engine to heat up faster. When the coolant has reached a certain temperature, the thermostat opens up and the coolant flows as normal. A malfunctioning thermostat in your diesel may cause your engine to overheat if the thermostat gets stuck in the closed position. Installation of a new thermostat will cure the problem and get you back on the road
  • Open the hood. Allow the motor to cool off so that you will not be scalded by hot coolant. Locate the thermostat housing by tracing the upper radiator hose from the driver's side of the radiator to its termination at the thermostat housing.
  • 2 Remove the cap from the white plastic coolant bottle at the front of the engine bay. Place a drain pan under the radiator drain petcock on the lower side of the radiator on the driver's side of the truck. Remove the petcock by rotating it counterclockwise with a 19mm wrench. Replace the petcock and tighten it in a clockwise direction once the coolant has fully drained.
  • 3 Remove the clamps from both ends of the upper radiator hose with a pair of pliers. Pull the hose from the radiator and from the thermostat housing, using a twisting motion. Set the hose and clamps aside.
  • 4 Spray penetrating fluid on the three mounting bolts on the thermostat housing and let it soak in for a few minutes. Remove the three bolts with an 8mm wrench turned counterclockwise. Remove the thermostat housing from the water pump and set it and the bolts aside.
  • 5 Remove the thermostat housing from the water pump to reveal the thermostat. Carefully pry the thermostat up with a flat-blade
  • screwdriver if necessary. Clean the mating surfaces on the thermostat housing and at the water pump with a rag.
  • 6 Place a new thermostat into the water pump with the pointed end facing upward. Install a new O-ring gasket into the groove on the thermostat housing mating surface of the water pump. Position the thermostat housing back onto the water pump and tighten the three bolts with a torque wrench to 15 foot-lbs.
  • 7 Push the upper radiator hose back onto the radiator inlet and the thermostat housing until it is fully seated at both ends. Replace the hose clamps in their original position with a pair of pliers. Refill the coolant that you drained from the radiator back into the white plastic coolant tank and replace the cap. Start the engine and let it warm up. Check for leaks and retighten your connections if necessary
  • Dec 08, 2010 | 2004 Ford F350
    The soap dispenser does not open completely during the cycle. We are using pod soap and it is just stluck in the partially open dispenser and the dishes are dirty.
    Most KitchenAid dishwashers have an adjustable upper rack, since I do not have your model number I cannot advise on specifics but if you move the upper rack to the higher position the dispenser will open a little further.
    Also if you are not washing well on the upper rack you may have either a plugged spray arm or sump.
    Look at the spray arms close, if the holes are plugged then it will not spray into the dispenser properly.
    If you have a tall tub KitchenAid then the sump may need cleaned. Here is a link to instructions that might help that. But not knowing your specific model these instructions may not apply
    http://www.fixya.com/support/r4628450-poor_cleaning_or_noisy_pump_whirlpool_or
    Apr 25, 2010 | KitchenAid Dishwashers
    Change thermostat on 1998 toyota camry
    1. Write down your radio code if it has some anti-theft device.
    2. Allow the engine to cool down for about 3-hours before the start of this operation.
    3. Open the hood, and disconnect the battery negative terminal. Tuck the negative terminal aside so it won't flip back.
    4. Locate the radiator drain-plug (plastic wing-nut) on the lower back side of the radiator, and turn it backward to remove it.
    5. Place a container under the radiator to catch the anti-freeze coolant.
    6. Remove the radiator cap.
    7. Once the coolant is drained, trace the upper radiator hose to where it ends on the engine(thermostat housing), and remove the hose with a medium size plier.
    8. Loosen the three bolts holding the thermostat housing. Gently take out the housing.
    9. Notice the position the thermostat was previously installed.
    10. Replace the old thermostat, and the o-ring around it. Clean its mounting area. Notice that the o-ring fits around the thermostat.
    11. Replace the thermostat housing and torque the three bolts to 78-inch pounds. Replace the upper hose.
    12. Replace the radiator drain-plug.
    13. Re-use the antifreeze coolant and be careful no dirt goes in with the coolant into the radiator.
    14. Return the radiator cap.
    15. Reconnect the negative battery terminal.
    16. Start the car and check for leak.
    Important: Anti-freeze coolant harmful to the environment. Return unwanted anti-freeze coolant to collection areas.
    Dec 17, 2009 | 1998 Toyota Camry
    Where is the thermostat located
    Just replaced my thermostat in a 1994 Saturn SL1. Lower hose on passengers side. Had to remove two 10mm bolts. Had to use special tool (paper tube) which came with new thermostat to twist and rotate the old one out of housing. Had to use spray on gasket tack on "O" ring only to get it glued into groove because it was wound up and stuck in paper tube (I mean special tool) which caused it to be bent and hard to seat in groove. Lay "O" ring on paper and spray one side with red gasket adhesive, let dry to tacky and lay in "clean dry" groove.
    Aug 03, 2008 | 1993 Saturn SL1
    sensor. computer control sensors. coolant temperature. engine Logo
    Top Buick Vehicle Parts & Accessories Experts
    Marc Taylor
    Thomas Perkins
    Thomas Perkins
    Jeff Turcotte
    Jeff Turcotte
    Are you a Buick Vehicle Part and Accessory Expert? Answer questions, earn points and help others
