Question about Konica Minolta Minolta 5600HS D - Hot-shoe clip-on flash - 56 m
Wide angle defuser is broken Minolta 5600hs
I lost Wide angle defuser Konica Minolta Minolta 5600HS D. Is it a problem?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Konica Minolta Master
  • 102,366 Answers
It's not a problem if you're not using a wide-angle lens. And if you are, you can always diffuse the flash by putting a thin white handkerchief or even a sheet of tissue paper over the flash.
Posted on Jan 10, 2013
  • v_dernovski
    v_dernovski Jan 10, 2013
    Thank you very much.
I am looking for manual of minolta 5600 hs d
Here is an online manual for your digital camera:
http://www.scribd.com/doc/22344755/Minolta-Maxxum-Flash-5600HS-D-Manual
Hope this helps!
Remember to Thumb me Up lots for all the hard work! :D
~~Dayminner
Jun 03, 2011 | Konica Minolta 5600HS for Maxxum Minolta...
I have a Minolta 5600HS flash that I have used for four years with my maxxum 7d without a problem until recently. The flash continues to function fine while on the camera and can be set to wireless mode on...
It could be a simple connection that is loose and just need to be put back into position, or it could be a controller circuit that is bad and needs to be replaced. This is not a user repairable problem. It should be sent in for repair.
Jan 20, 2010 | Konica Minolta 5600HS for Maxxum Minolta...
I have a Minolta 5600Hs flash. It's worked great
I would not recommend you fix it yourself since several of the inside componentes are high voltage and dangerous. But, why wont the flash turn on? if the batteries are good, could it be the battery contacts on the battery door and inside the flash? If the batteries have ever corroded (even a little) then that would be the problem. Use a pencil eraser to shine up the contacts until they are bright and shiney clean. Do not use sand paper or anthing vabbrasive as that will cause the contacts to corrod more and the problem will be worse.
Nov 18, 2009 | Konica Minolta 5600HS for Maxxum Minolta...
MINOLTA DYNAX 5400 HS flashgun manual
Since Minolta quit the camera/flash biz, Ebay is your best bet for a printed copy.
To get a free pdf file, Go to KM global website.
Select Canada, as yer country.
navigate your way to downloads.
Also check the Orphan camera website.
I have a pdf for one, but I am not allowed to give it to you here.
Try the Minolta groups on Yahoo.
Aug 11, 2009 | Konica Minolta 5600HS for Maxxum Minolta...
5600hs or 3600hs equivalent in other brands
I live in London, England, and have never encountered the brand you mention. However, I can recommend the Metz 48-AF1; it has a Guide Number of 48 and does pretty much everything that the 5600hs and 3600hs do at far lower cost, including the wireless flash which the A2 can work with. It also makes sense as it can be changed to fit any major brand by adding the appropriate adaptor so is highly resaleable. In the UK the basic flashgun sells for around £155 and an adaptor is around £30 extra, but I've noticed on my travels that it's far cheaper when priced in US $.
http://www.metzflash.co.uk/pages/metz48af1.html
Feb 15, 2008 | Konica Minolta DiMAGE A2 Digital Camera
Quantaray QBX-8000xi owners manual
1. No.
Unfortunately not.
This flash is a superb budget alternative to the Minolta alternatives but is only suitable for their film cameras. Sony's SLR's are based on the later Minolta Digital SLR's and they're all incompatible with this flash.
The technical differences between the film and digital Minolta cameras explains why a Minolta 5600HS (for example) had to be redesigned and redesignated as a 5600HS(D). The former will not work on Sony Alpha models, but the latter is fully compatible.
2. I haven't managed to find a manual for this model in my stock room and failed to trace one online.
Nov 01, 2007 | Cameras
Is wireless/remote flash available?
Yes. Wireless / Remote Flash allows the camera to control Minolta 5600HS(D) and 3600HS(D) flash unit. (sold separately)
Sep 15, 2005 | Konica Minolta DiMAGE A1 Digital Camera
Can the conventional Maxxum/Dynax flash units be used with this camera?
Yes. The following Minolta dedicated external flash units are compatible with the DiMAGE A1 for automatic flash control: Program Flash 3600HS(D), Program Flash 5600HS(D), *Program Flash 2500(D), Macro Twin Flash 2400*, Macro Ring Flash 1200*. * Program Flash 2500(D) will be available around August, 2003. *Macro Flash Controller is necessary
Is the wide converter attachable?
Wide converter can be attached by using the dedicated adaptor ring ZCA-300 and will provide equivalent to 26mm angle of view in 35mm film. The closest subject distance: Normal Recording mode: 70.5 cm (from CCD), 60 cm (from the front of wide converter) Macro mode : 20.5 cm (from CCD), 10 cm (from the front of wide converter) *1 Set the Lens acc. to Wide Converter. in the setup menu. (Optical zoom will be fixed at wide-angle end.) *2 Built-in flash can be used when attaching a filter, but shadowing may occur at the bottom of the image. In this case, use of program flash 5600HS(D), 3600HS(D), 2500(D) (sold separately) is recommended. *3 Filter with 52mm in diameter can be attached to the adapter ring.
Sep 13, 2005 | Konica Minolta DiMAGE Z3 Digital Camera
Konica Minolta Minolta 5600HS D - Hot-shoe clip-on flash - 56 m Logo
Top Konica Minolta Cameras Experts
Greg Cann
Greg Cann
Willem.
Willem.
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
