Question about Garden
Unsieze a weedeater motor after using regular gas
My son ran regular gas through my weedeater. how do I unseize it?
    Genius:
  • 1,669 Answers
Even if you are able to "unseize" it, it may not run afterwards. The reason you NEED to add oil to the gasoline is because that is the only lubrication the engine gets! You can try to unseize it by removing all of the remaining gasoline from it and putting in ONLY some 2 cycle engine oil. Then you will need to attempt to turn the engine shaft back and forth using the weedeater feed spool as a lever handle. IF, and I say if it breaks loose you may not have sustained alot of damage. If it doesn't...
Posted on Jan 10, 2013
My weedwacker was working fine. All the sudden it shut down. The rip cord won't pull out to start it up again. Need answer asap. Thanks
Jamie, could be a recoil problem, broken clutch, probable the engine has seized on your weed wacker. You can try and free up, rebuild or replace trimmer. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
What Stops Pull Cord for Gas Weeder
How to unsieze 2 cycle Weedeater
Seized piston engines can run again but not for long What do you think
Fixing seized up echo weed eater
Aug 15, 2016 | Garden
I purchased the weedeater last year and it ran fine. This year I can only set the choke setting on #2. If I place the setting on #3 the motor will cut off. Please help. Thank you.
Its very important to drain fuel at end of season and use stabilizer but now the car will need to be cleaned you can do it yourself with carb cleaner that carb off and remove both covers spray real good hope it works if not new carb needed
May 03, 2015 | Garden
Snapper mower
motor siezed up remove plug pour oil in cylider work it back and forth till it come loose and turns freely should start up
Aug 09, 2013 | Garden
1995 suzuki rf 900 not starting and backfiring
The bike uses regular gas. That 93 may be an issue esp if it has ethanol in it to boost the octane
Oct 27, 2017 | 1994 Suzuki RF 900 R
Hi i have a Ryobi c430 weedeater, what petrol do i use in it?. is it 2 stroke or a 4 stroke motor? i dont have the manual for it. thankyou
This is a 4-Stroke model. Just use regular unleaded gas in it. Here is a viewable manual of models like yours.
http://dl.owneriq.net/8/8875c2d5-4f85-4c2b-a141-df69cc2b8e93.pdf
The manual is 52 pages and takes a little time to download.
Oct 29, 2010 | Ryobi 15" Electric Factory Reconditioned...
Ratio for oil and gas on a ryobio weedeater
if you are using stihl oil the ratio is 50:1
Jul 03, 2010 | Ryobi Three Trimmer Combo
Weedeater blower will not prime
The primer bulb sucks fuel from the tank to the carb. When the carb has enough fuel the remainder is sent back to the tank. When you replaced the fuel line did you use the exact length of line and did you re-install the filter. On some of the trimmers the filter is weighted and holds the line in the fuel. Good luck...Lee
Sep 24, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Weedeater gas edger won't start!!!!!!!!!
yes, there is a spark module, but it's highly unlikely that two would have a bad module - more than likely, it is your gas mix. it must be fresh for the engine to run. the gas we have today will go bad in about a month and a half. if you happen to live in an area that has E85, forget it. small engines will not run very long, if at all on this junk. in some areas, you can get gas without alcohol, but it can only be used for lawn & garden equipment. it's expensive, but your engines will run
Sep 20, 2009 | Craftsman 25cc Gas Line Trimmer
Weedeater gas line
I ran a short piece of coathanger that I cut through the fuel line and used electrical tape (stretched tight) to tape it securely at the end and pushed it thru the hole. Then I removed the electrical tape and cut off the part of the hose that had been taped. You waste an inch or two of fuel line, but that's how I got mine thru. Sure hope this helps and best wishes.
Aug 26, 2009 | Garden
Garden Logo
94 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
