Question about Traulsen Trauslen Reach In Freezer
FREEZER NOT COOLING
I have a commercial freezer and its been giving me some problems lately. It is supposed to be at 0 to 10 degrees and it is at 25 to 35 degrees. The fans are working and i replaced the timer so i know its not that. I did notice the coils get icy time to time. Please let me know what it could be Thanks in advance
    Sergeant:
    Champion:
  • 249 Answers
What is your model number is then we can get started then
Posted on Jan 18, 2013
4 Suggested Answers
peyton32034
  • 410 Answers
SOURCE: Traulsen URS36DT:
checking a def system is kind of easy. if you have located the defrost timer just turn the little knob on the timer until the unit shuts off, shortly you should hear "hissing and pooping" from water dropping on the heater. this lets you know that the defrost thermostat is good. if you dont hear this noise check your def thermostat and heater for continuity. if you put it into def and the heater comes on then you have a bad timer..
Posted on Dec 12, 2007
  • 7 Answers
SOURCE: Traulsen Commercial Freezer needs charging?
The refrigerant level is low. The only thing is that the unit may not have a low charge. There can be several things that cause the unit not to refrigerate properly. It could have weak valves in the compressor or even a bad TXV(thermostatic expansion valve). Have you had this box repaired yet.? I see that this is an old post.
Posted on May 15, 2009
  • 1230 Answers
SOURCE: My service man replaced the defrost cycle timer
Most all commercial freezers have a fan delay/ defrost terminator. It is usually mounted on the end of the evap coil. It's purpose is to sense the temp of the coil during the defrost cycle. When it hits a preset temp., usually around 55 degrees or more (depends on Mfg.) It terminates the defrost cycle. It also doubles as a fan delay. It allows the evap coil to cool off from the defrost cycle before allowing the fan to come on. Usually, the coil has to get around 20 degrees before fan will energize. I would look for this as a possible problem. It could be one device with 3 wires or 2 separate devices with 2 wires each. I've seen it both ways.
Hope this helps.
Posted on Nov 20, 2009
Testimonial: "This is much in line with what the tech said. He will be back tomorrow to fix this part. "
Compressor vibrates and unit only cools to 20 degrees. tech says it "may" be compressor pressure valve ($1800.00) but no warranty. I cant find any such part listed for True T49-F commercial...
Okay first True uses capillary tube not an expansion valve.
You say the compressor vibrates not cooling ?
If the valves of the compressor are bad, he may mean
internal valves but usually pressures would not be good.
Give a little more detail please.
Apr 26, 2011 | True 49 cu. ft. / 1388 liter Commercial...
Commercial freezer will not get below 25.degrees. Three new motors, new fan blades, new compressor, cleaned, and new defrost thermastat put on. Even caulked any gaps.
Why were all these replacements made ? Sounds like the Technicians have no clue.
When the compressor was changed was the drier changed ? Was the system properly Evacuated and Leak tested ? Please give all the details as this sounds to me more like shoddy workmanship and parts changers.
Dec 07, 2010 | Whirlpool 19.6 cu. ft. Commercial Freezer...
What should be my pressure on a 404a freezer
usually depends on the temp of the conditioned space. Most freezers run about a minus 10 evap to get a 0 degree box. So look for a low side pressure of about 25. High side is ambient plus 30. A 75 degree ambient, for example, add 30 and get 105 degrees. That, on a P/T chart converts to about 253 psi. Those are approximate but I'm sure you can use this to fugure out what to look for.
let me know if you need more help.
Sep 27, 2010 | Continental Manufacturing Company...
Older Gibsonl upright freezer not cold
dear sir
please make sure first your freezer is well clean if it is already clean then contect to maintenance personell for refilling the gas.
hope answer the question.
thank you.
Jul 05, 2010 | Frigidaire Freezers
What is the max. surrounding temperature for it operate efficiently
Most of these items are built to go as high as 95 degrees and somewhat function. I would not go above 80 degrees based on my 25 years of experience in working with commercial refrigeration. If it's a residential unit, I have a chest freezer in my garage for the last 8 years and not had any problems at all. I'm in the middle of Georgia and temps get pretty high in the summer.
Hope this helps.
Dec 15, 2009 | Danby 3.6 cu. ft. / 102 liter Chest...
Commercial freezer (Randall) with a Ranco thermostat, not cooling
clean condenser? is evaporator free of ice? may need defrosting or low on freon. Tom
Jun 30, 2009 | Freezers
Proper temp. range in freezer
Hi dgh1,
The freezer should stay within 5 degrees of 0 while in operation. While in defrost the freezer may reach as high as 20 to 25 degrees. If any higher temperatures are reached your food will spoil as they are defrosted and refroze everyday. If you find that the temperature is allowing your food to defrost you may want to replace your defrost thermostat. This device is located on top of the evaperator coil inside the back of the freezer. It is made to turn the heater off when a temperature of 55 degrees is reached. One other possible problem could be your defrost timer is taking to long to restart the cooling cycle after defrosting. I hope this will help you and please send any other questions you may have, I am happy to help. and dont forget to rate me.
Mike Anderson
Anderson Appliance
(865)945-3808
Oct 28, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Traulsen Trauslen Reach In Freezer Logo
67 people viewed this question
Top Traulsen Freezers Experts
Dennis Boxerman
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Traulsen Freezer Expert? Answer questions, earn points and help others
