Question about Water Heaters
Burner on new Whirlpool gass water heater will not stay lit
It is a natural gas water heater. Once lit it starts to flutters and after about 5-10 seconds it goes out. Plenty of gas because it is hooked into the pipe line.
  • 1 more comment
  • Anonymous Feb 24, 2009
    it has been in use for over a year and then the pilot light went out
  • Dale Koehn
    Dale Koehn May 11, 2010
    how long has it been in place? is your venting for it clear? is the venting hooked into the same vent as the furnace ?
  • mikespipe Aug 04, 2014
    All new hotwater heaters have a sealed combuston chamber . meaning there is limited airflow in and if it is cloged it will burn up the o2 and the flame will go out. Keep the area around the heater clean and check for a filter that may need to be cleaned with either a vacuum or a airhose. if that is not the problem check the thermocouple. only the tip , the first inch should be in the flame if in to deep they burn out easily. If the thermocouple does not do the job yo are looking at a new valve. good luck
  • 90 Answers
One of the proper ways to light a gas water heater, is to turn the black knob to Pilot, put a match to the end of the pilot light, while holding the match there, push the red reset button down and hold the match & the reset button down for one full minute. Then, release the reset button and turn the black knob to On. This should keep the pilot light on.
Posted on Jan 22, 2009
Hayward H400FDN will not stay lit - Brand New install - NO Fault codes.
make sure wiring is correct especially if wired 120 volt read instructions inside panel
Jan 28, 2014 | Hayward Industrial Products H400FDN...
Gas burner wont stay lit
Is it the Pilot, or the main burner that won't stay lit?
The pilot has a little 'flame rod' in the path of the pilot flame, that conducts a tiny current thru the flame, to a detection circuit-- assuring that there is a pilot flame-- If that rod get's dirty, it can cause false trips. Is that any help?- Mack B
Oct 25, 2013 | Honeywell Pilot Burner for Natural Gas,...
Rheem water heater pilot lite stays lit, burner goes out
Tripped FV or TRD, or bad gas control valve, low gas pressure, air in gas line.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Unfortunately, Rheem does not post service manuals. Other companies post service manual, but only Rheem uses TRD FV system, while other companies use arrestor screen.
http://waterheatertimer.org/How-to-repair-Rheem-TRD.html
Add a comment and say what you discover.
May 24, 2013 | Rheem 42V75F Fury Heavy Duty Natural Gas...
Reliant 501 Natural Gas won't stay lit
Reliance water heater?
Thermocouple is good if the pilot stays lit continuously.
501 is older model. Unknown if this unit has FVIR protection and sealed combustion chamber or open air intake on front of unit.
http://waterheatertimer.org/pdf/Reliance-2006-Service-Handbook.pdf
With FVIR protection:
Get more fresh air to the unit.
Clean the flame arrestor screen.
Test and replace the thermocouple:
http://waterheatertimer.org/How-to-test-water-heater-thermocouple.html
Inspect and clean burner and combustion parts
Test gas pressure, bleed air out of gas line.
Replace gas control valve.
Test draft air by lighting match and see if smoke is pulled into the vent pipe at draft hood on top of tank.
Aug 20, 2012 | Water Heaters
I have an A.O. Smith Permaglas Water heat (Natural Gas) that will not stay lit.
There may be a draft blowing out the pilot. Place some fiberglass insulation inside the cover for the burner or pull down the insulation from inside the jacket just over the burner opening.
Mar 03, 2018 | Water Heaters
Reliance 606 natural gas water heater - model #640YORT - water does not stay hot. pilot has to be clicked to heat and then u can use hot water til tank empty and it will not continue to heat water.
If I understand correctly, the pilot light is not staying lit.
You light the pilot and water in the tank reaches temperature.
Once hot water is gone, then pilot light has to be lit again.
Gas pressure is good, and gas is flowing.
Thermostat is working at high end because it cuts off heating.
Vent is working because tank heats up.
Air intake is working.
Gas control thermostat might not be reading low temperature. Replace gas control valve.
Pilot tube might be dirty. Clean burner parts and combustion chamber, and air intake, and vent.
Backdraft might be blowing out pilot. Check for constant updraft by running water heater 5 minutes, and then light match under vent hood and see if smoke goes up.
Very hot air can put out pilot, especially when water heater located in attic. Add ventilation.
Improper vent might have water dripping back down into combustion chamber and putting out pilot light and rusting out the parts. Inspect for rusted parts and water.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
Aug 09, 2011 | Reliance Natural Gas Water Heater Control
I can light the pilot and the burner will come on, but it won't stay lit. I bought a new pilot assembly and installed it. the burner and the pilot light still won't stay lit. This is the unit that...
Most gas water heater problems can be solved by having service technician perform yearly maintenance. Or by doing maintenance yourself.
This maintenance includes cleaning burner parts and combustion chamber, checking gas pressure and supply, bleeding air out of gas line, checking vent draft, making sure air supply is adequate and not exposed to chemicals, cleaning air intake. Also adjusting flame sensor so it is positioned correctly. If water heater is connected to electric circuit, the outlet must have correct polarity.
You can get gas to appliance indicates the gas control valve and water heater are not locked out. But the gas control valve thermostat can still be bad.
Open following link for illustrations, typical service manuals, and maintenance information, and images of gas control valve thermostats.
Jul 20, 2011 | Reliance & Pilot Assembly for Natural Gas...
Once in a while after burner has been on and shower has been on for a while, the burner shuts down and pilot flutters, then pilot comes back on good but no burner .eventualy burner comes back on. if i turn...
Probably the burner and parts need to be cleaned yearly as recommended in most gas water heater manuals. Both tank and tankless today recommend same.
Open following link for Bosch troubleshoot resources:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Jun 20, 2011 | Bosch AquaStar Natural Gas Tankless Water...
I have a`steady drip from my pressure relief valve on my Bryant natural gas heater
What you need to do is replace it once thay start leaking there no good you need to tern the cold water off going to the water heater drain about five gallons and replace it make Sher you use plenty of pipe compound.
Jan 23, 2011 | Rheem 40 Gallon FVR NATGAS Low WATER...
Water Heaters Logo
467 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
