Question about GE SpaceMaker Microwave Ovens
Turntable not working - SpaceMaker GE Microwave Ovens
  • GE Master
  • 17,130 Answers
Possible failure of the drive belt or the turntable motor. Remove the bottom cover to confirm failure of the drive ,belt or if the motor has failed- check power to the motor when the microwave works if the motor tests OK.
Posted on Jan 11, 2013
Oven seems to be working with the exception of the turntable not revolving
Check that there is no damage to the plastic turntable rotor (i.e the part with wheels) underside the plate. Motor could be working but rotor missing or not connected properly, or damaged. Otherwise the turntable motor or motor driver circuit is fried.
Feb 04, 2015 | Microwave Ovens
Why wont my GE Spacemaker JVM1650 turntable wont work?
replace the turntable synchronous motor
look to ebay search for
ge jvm1650
then add turntable motor or browse down youll find a new motor
the coils inside may be duff
Aug 12, 2014 | GE Profile Spacemaker Over-the-Range...
Panasonic Microwave NN-S935BF turntable and light do not work. Microwave still works. Bulb and turntable motor okay. No power to light or turntable. Any ideas?
Your description seems to be confusing turntable and light do not work
Bulb and motor OK
Which is it?
They could be separate incidents. The drive motor could be fused and the globe just blew its life away..
Aug 15, 2009 | Microwave Ovens
Bulb & turntable
Yes the microwave is safe to use, without the turntable working.
May 03, 2009 | Microwave Ovens
Turntable sometimes works, mostly doesn't
It sounds like you have a jamming turntable motor.
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Jan 28, 2009 | Microwave Ovens
Turntable will not turn
If everything works, light and micro heating.. then I have 4 possibles for you to check... 1st make sure you don't have a button that allow you to turn the turntable on/off... 2nd take the glass table out and check the center plastic spinner(pull it out) and see if its broken. 3rd your turntable motor is bad, and 4th the relay for your turntable on control board is bad... helpfully that will do it for ya.. good luck.. mike
Dec 20, 2008 | Kenmore 62622 Microwave Oven
Turntable does not work
If the rest of the oven works fine, then this indicates that you might have a problem with the motor that turns the turntable.
If you try to turn the turntable manually (gently), does it turn freely or is there resistance? If it turns freely, the mechanical mechanism between the turntable and motor may be broken and the motor may be ok.
The oven's microprocessor also controlls the motor. There could be a problem there.
You'll need to have it looked at by a service center. Although its not that difficult to determine which of the reasons I mentioned above is the cause, it can be however, dangerous to operate a microwave oven with the cover off and with high voltage circuits exposed.
Please let me know if I can be of further assistance to you.
- Jim
Mar 08, 2008 | Goldstar MV-1526 Microwave Oven
Turntable doesn't turn
If you just purchased and Installed the microwave, I would call Sears and tell them what is happening, generally, it would still be under warranty if less than a year old. If its a countertop model, you may have to take it in, otherwise they should come to the home for the repair. I would also NOT indicate that you have looked at it as that would void your warranty.
Otherwise, it seems like the problem could be, a) touchpad , b) a relay or c) the main control board
Feb 02, 2008 | Kenmore 62642 / 62644 / 62649 Microwave...
Need to check if you have power to the turntable motor. Either is has a bad motor or a bad relay on the control board.
Nov 12, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
32 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
