Question about Sewing Machines
THREADING FILM IN A ELMO FP-C PROJECTOR
I just purchased a Elmo FP-C projector on EBAY. It looks like it was used very little. Would you please help me with two problems that I am having. The instructions that I rec'd with it are pretty good but doesn't cover everything. #1 It seems that the threading lever is stuck in the forward position. I am not sure if this is how it should be or not. #2 Having trouble threading the film. I clip the end of the film. Insert it in the threading slot. The sprocket picks it up ok but it won't go into the guide that takes the film on it's way to thread through projector.
    New Friend:
Is your film super 8mm? If yes, then the red sprocket above the lens should be pushed in, and the bottom black sprocket will stick out. If you have regular 8mm, then the black bottom sprocket should be pushed in. If the sprockets are not in the correct position, push the green lever forward (towards the screen) then open the two orange tabs, then push in the correct sprocket. Once you have the correct sprockets aligned, close the orange tabs. How to tell if you have 8mm or super 8mm film: Look carefully at the film image. If the sprocket hole is next to the middle of the image, it's super 8mm. If the sprocket hole is between images, it's 8mm.
Posted on Feb 04, 2013
  • 3 Answers
SOURCE: needle picks up bobbin thread but then thread gets stuck
I've had similar problems (as well as other problem with the thread breaking all the time and the "shuttle race" thing that holds the bobbin falling out. One very important thing that isn't mentioned in the manual but that the salesman stressed is that you have to use only "Schmetz" brand needles. They are a tiny bit longer, but that makes all the difference in the world if your stitches are skipping. I forgot and used Singer needles and had horrible results.
Posted on Aug 16, 2007
bargainbox
  • 1388 Answers
SOURCE: threading the bernina 1300DC serger
These things are always complicated when you try to write them down, so I suggest a call to your local Bernina dealer to arrange a quick lesson on how to do it.
If you can go back to the dealer whence it came, so much the better..........perhaps you could go in and buy some things you need and then as you are leaving, make the enquiry with the machine in your car, they may be able to show you how to do it right away......building relationships is a very good way of feeling comfortable about asking for help.
Also..........
If the manual diagram is too small, a local library or stationery supplier should be able to magnify a photocopy for you to see it all more easily.
Posted on Jun 09, 2008
  • 37 Answers
SOURCE: bottom thread of sewing machine jams up
Try turning the bobbin around. Some bobbins should turn clockwise, some counter clockwise. What you described is what my Kenmore and Brother machines do when the bobbin is in incorrectly.
Posted on Apr 15, 2009
chrismyers67
  • 53 Answers
SOURCE: Have a new machine and trying to thread for the
You should be able to turn the hand wheel (on the right side of the machine) towards you and you should see the take up lever on the top left. It does not stick above the machine.
Let me know if you need more help,
Chris
Posted on Jun 07, 2010
SOURCE: bobbin tension problem with kenmore model 385.16231300
I discovered the same problem. What I figured out (after having the machine "repaired" several times) is that it seems as if the bobbin type may be the suspect. I started looking closely and it seems as if I have 2 different types of bobbins. So, I tried both types. Since I don't know the bobbin number(s), you will have to put up with my description .... the bobbin that is flat, top & bottom, seems to bunch up. The bobbin "bounces" when I sew. The bobbins that are rounded on the top and bottom don't seem to "bounce" and it doesn't bunch up the lower thread. Now, I have read my manual front to back and it does not say what bobbin type or number to use. So, if anyone knows, it would be a great help. I am assuming the correct bobbin is the "class 66" bobbin. Does anyone know for sure?
Posted on Apr 29, 2011
I have a baby lock 5380E & can't seem to thread it correctly to make it stitch properly. Please help! I know it has to do with threading the upper & lower loopers correctly,
Hopefully you have the manual. It helps to use 4 different colors of thread so you'll be able to differentiate which thread is presenting a problem.
Just thread each thread as though it were the only one, like a sewing machine. Make sure you thread each in the proper order or it will most likely never work. AND ALWAYS RAISE the presser foot when threading and give each thread an extra little tug when going through the tension disk so the thread will seat completely.
Set the tension disks to the midway point, so they are all set about the same. Then test.
If something goes haywire, just bite the bullet, remove ALL the threads and start over threading from the beginning. Believe me, it very seldom works to try to re-thread only one thread...
It took me an entire day to get my new-used serger threaded properly. So don't despair... You might look around for a beginning serger class.
Oct 28, 2016 | Baby Lock Sewing Machines
Would like to get a owners manual for my husqvarna 190 selectronic sewing machine. I am having trouble with upper tension and need to make sure I am threading it properly, any suggestions
Here's an ebay that has one for $ 15.00. There are others.
http://www.ebay.com/itm/Vintage-Viking-Husqvarna-Sewing-Machine-Operation-Manual-Optima-190-180-150-/191517822256?pt=LH_DefaultDomain_0&hash=item2c975a0d30
Generic threading:
START TO THREAD WITH PRESSURE FOOT UP. AS YOU THREAD GIVE LITTLE PULLS TO INSURE THERE ARE NO SNAGS.
1. Go from right to left.
2. As you feed you will come to the tension. Make sure it is fed through the tension disc or it won't work.
3. Feed through the take up lever.
4. Feed through the final holes to the needle. Final little pull to check for snags.
5. Put pressure foot down and give little tug. It should have some resistance, but not excessive. Usually four on the tension control is a good starting point.
6. Check your bobbin for pressure. Pull out the bobbin case and let it hang from your finger with the bobbin inserted. While you bob it back and forth it should extend one inch. Adjust the tension as you need to. Put one drop on the little ring under the case. (It looks like a race track).
7. As you use the machine you may have to adjust the upper tension as you need.
Feb 28, 2015 | Husqvarna Sewing Machines
Husqvarna Prisma 990.Problem with additional threads on the lower side after sewing.See photo attached. Please help. Thank you
You will need to take the bobbin case out then pull the hook out. I believe there are 4 screws that hold the hook in. It sounds like you have some thread stuck in maybe behind the hook. If there isn't any thread look closely at the hook and you will probably find a burr where the needle hit the hook and it is catching the thread. If you find a place on the hook that is catching the thread you can use a little piece of sand paper then use some clear finger nail polish to smooth it out. That should take care of your problem
Nov 26, 2014 | Sewing Machines
HAVING TROUBLE THREADING FILM - ELMO FP-C
Is your film super 8mm? If yes, then the red sprocket above the lens should be pushed in, and the bottom black sprocket will stick out. If you have regular 8mm, then the black bottom sprocket should be pushed in. If the sprockets are not in the correct position, push the green lever forward (towards the screen) then open the two orange tabs, then push in the correct sprocket. Once you have the correct sprockets aligned, close the orange tabs. How to tell if you have 8mm or super 8mm film: Look carefully at the film image. If the sprocket hole is next to the middle of the image, it's super 8mm. If the sprocket hole is between images, it's 8mm. If your green lever is stuck in the forward position, that's because the film is not threaded. Once your film threads correctly, the green lever will spring back.
Jan 10, 2013 | Sewing Machines
How do you thread a singer merritt 1872?
Wow, one of the few Singer machines that doesn't have a free download manual. Hmmm..... Ok looked up a photo of your machine. It's pretty easy.
1. raise your presser foot.
2. Put thread on spool pin.
3. draw thread over to and under from behind of the pre-tension disc at top
4. Draw thread down from the right and under the tension dial to seat the thread into the tension discs and flex that spring a little.
5. Through the take up lever.
6. Down through the thread guide.
7. Down through the needle bar thread guide.
8. Through the needle.
Hope that helps.
Aug 20, 2012 | Singer Sewing Machines
I purchased a singer 1507 online and unfortunately, it came without a manual. I don't know how to thread it. Can you help me?
All the singer's I've ever owned have threaded the same way. I don't remember all of the technical names for the parts, but I will do my best to describe them. The thread feeds from the bobbin to a guide (looks like a little hook for the thread to pass through) on the left. Then down the first part of the "U" shaped channel and up the other side. There is a little lever that bobs up and down, sometimes it has just a hole in it, sometimes a channel that connects to the hole. Slip the thread through the hole. If it has a channel, that's even better. Just pop the thread through the channel to the "eye". Feed the thread downwards and to the needle. Some machines have a small springlike guide right above where the needle is at. You can pass the thread through here before you put it through the needle. I have one on my machine, but to be honest, I forget to put it through most of the time. I hope this helps! Happy Sewing!
Feb 11, 2010 | Singer 1507
Babylock Ellure thread issues
I have the same machine and love it. Sometimes if the thread is old that will happen to me.  And also I spray the thread with static guard before i thread the machine in dry cold weather.  Since you said you are an embroiderer I assume you are using the same weight thread top and bottom. The other thing that causes that on my machine is if there is a nick on the spool of thread I am using and the thread catches just a little as it comes off the spool.  I use a fine nail file and smooth off the edge where the little v is to reattach the thread when you are finish using it.  I never use them. You do sew a little and cut off the tail off the top thread before you let it go through the rest of design. I hope you have found the solution but I learned these tricks while having the same problem as you.
Jan 25, 2009 | Baby Lock Ellure
Thread looping underneath quilt
Your problem is the top thread. Make sure you lift the presser lever BEFORE you thread the machine. After threading the machine, just before you thread the needle, lower the presser foot, and test the top tension by pulling down on the thead. If there is little or no tension, adjust the top tension to a higher number, say from 3 to 5, or from 5 to 7, and test the tension again. If you fail to increase the tension by above procedure, look for cotton that might be stuck in the tension blades and remove it. Hope this will help you
Nov 11, 2008 | Juki TL-98Q
Auto threader cassette don't work any longer, How can i manually thread the machine to use it without the cassette?
I do know that you can purchase new cassettes on ebay for about $15.00. I understand that they can fail after a while. A service call may not be necessary. You may be able to purchase one from a dealer as well.
May 04, 2008 | Brother CS-80
Sewing Machines Logo
138 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
