Question about NetGear ProSafe JGS524 (DHJGS524NA)
Does a netgear jgs524 support vlans? - NetGear ProSafe JGS524 (DHJGS524NA)
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 25 Answers
The JGS is an unmanaged switch. It has no settings to configure or reset. When it receives a packet, it might preserve its VLAN tag when forwarding it, but there is no way to configure it to notice or handle VLANs in any particular way.
Posted on Oct 19, 2014
3 Suggested Answers
  • 20 Answers
SOURCE: Netgear JGS524 switch Power is
I suggest that you factory default the switch in case some security settings or Vlan's/STP have been enabled. Turn off Spanning Tree Protocol (STP) if yiu can access the switch. Check that you ahve no loops in the cabling.
Posted on Oct 26, 2010
  • 378 Answers
SOURCE: Netgear FSM7352S - VLAN not connecting
Create the same VLAN on all the switches that will need this VLAN. All ports that link to another switch should have ALL VLAN's set to tagged.
This one VLAN should not have an IP address on any of your switches. This way it won't get routed by any of your users.
Posted on Apr 25, 2011
When I enable the vlan option in an EAP9550 I lose wireless access
Bruce,
Is the goal to use a different VLAN for each access point (AP)? If so then you will need to configure each NetGear port to use the same VLAN as the AP that is connected to it. You will then need either a switched virtual interface (SVI) for each VLAN on the NetGear or a trunk port (802.1q) from the NetGear to the Cisco. I'm not sure the NetGear will support SVIs but it will support trunks. An SVI basically creates a gateway for each VLAN's subnet. For example, let's say AP1 uses VLAN 10 and the subnet is 10.0.10.0/24 while AP2 uses VLAN 20 with a 10.0.20.0/24 subnet. The NetGear will need 2 SVIs, one for each VLAN/subnet. The first SVI for VLAN 10 can be configured with IP address 10.0.10.1/24 while the second SVI can be configured with 10.0.20.1/24 for VLAN 20. These IP addresses will be the gateway for each VLAN. Finally, the NetGear would need to act as a router and route each VLAN's subnet to the Cisco device. Once again I don't believe the FS726TP supports this.
The other solution would be to create a VLAN trunk port between the NetGear and the Cisco device but I believe the Cisco RV042 does not support trunking. If it does the trunk would be configured to carry all of the VLANs to the Cisco device which would then have SVIs created on it.
If neither of the above is possible you would need to use the same VLAN for each AP and each of the interfaces on the NetGear and Cisco devices which negates the need for the VLANs.
I hope this helps.
Mar 13, 2014 | EnGenius Computers & Internet
I am trying to change the cfe on my netgear wgr614 V6 tdc but the jtag doesn't see it. The ends I am trying to get to is putting dd-wrt on it. Any ideas?
Once you've got a serial console attached you can access the CFE which is a bit like the bios of the WGT634U. Start up minicom and apply power to the router while holding Control C. You should see something like the following:
CFE version 1.0.34 for BCM95365R (32bit,SP,LE)
Build Date: Tue Feb 24 03:21:41 CST 2004 (root@jackylinux)
Copyright (C) 2000,2001,2002 Broadcom Corporation.
Add MAC client version(DNI).
Initializing Arena.
Initializing Devices.
et0: Broadcom BCM47xx 10/100 Mbps Ethernet Controller
CPU type 0x29007: 200MHz
Total memory: 0x2000000 bytes (32MB)
Total memory used by CFE: 0x81BB1280 - 0x82000000 (4517248)
Initialized Data: 0x81BB1280 - 0x81BB3E90 (11280)
BSS Area: 0x81BB3E90 - 0x81BB45D0 (1856)
Local Heap: 0x81BB45D0 - 0x81FB45D0 (4194304)
Stack Area: 0x81FB45D0 - 0x81FB65D0 (8192)
Text (code) segment: 0x81FB65E0 - 0x81FFFFB0 (301520)
Boot area (physical): 0x01B70000 - 0x01BB0000
Relocation Factor: I:E23B65E0 - D:01BB0280
configure vlans
*********************** VLAN Driver initial ********************
Process LAN port(2-5) vlan Architecture...
SUCCESS: trying to create VLAN 0 for switch
SUCCESS: trying to add LAN port
Process WAN port(2-5) vlan Architecture...
SUCCESS: trying to add WAN port
SUCCESS: enable ports success
configure vlans...done
Automatic startup canceled via Ctrl-C
CFE>
Now you can get a listing of the available commands by typing "help". If you want to boot a kernel from a tftp server do the following:
CFE> ifconfig eth0 -addr=192.168.1.1 -mask=255.255.255.0;
CFE> boot -z -elf -tftp 192.168.1.10:vmlinux.gz
Or you can automate the process by setting STARTUP using:
CFE> setenv -p STARTUP "ifconfig eth0 -addr=192.168.1.1 -mask=255.255.255.0;boot -z -elf -tftp 192.168.1.10:vmlinux.gz;boot -elf flash0.os:"
The router will now try and retrieve a kernel image called vmlinux.gz using tftp from 192.168.1.10. If this fails it will go ahead and boot the kernel on the flash. The is quite handy as in conjuction with a NFS root, it means you can do all your development without modifing the original firmware.
Mar 14, 2011 | NetGear WGR614 Wireless Router
Need to know if NetGear JGS524F switch supports VLAN's.
The switch above is an unmanaged switch so no it wont support VLans, sorry
Mar 02, 2011 | NetGear JGS524F ProSafe 24-Port Gigabit...
When i plug it in with out anything plugged into it it automatically starts blinking select green lights is there anything i can do to fix this?
The all lights will starts blinking everytime the switch is powered ON.
This is normal process as the switch is checking the status of all its ports during startup.
Please wait for 5-10 minutes this activity will completed and the port lights will not blink if nothing is connected.
If it still blinks without anything connected to the ports then you need to ask the vendor for a replacement.
Jan 08, 2011 | NetGear ProSafe JGS524 (DHJGS524NA)
Netgear JGS524 switch Power is on 24 port led is on but network is not working
Oct 26, 2010 | NetGear ProSafe JGS524 (DHJGS524NA)
Apr 06, 2010 | NetGear ProSafe FSM7352S (0606449038880)...
7910 IP Phone
please check if firewall is ON on your netgear router...
Dec 12, 2007 | Cisco 7910 IP Phone
DMZ HOST IN FVS 124-G
The Netgear FVS124-G is a superb combo VPN firewall DSL/Cable small business router. Loads of features and Dual Wan to boot. I highly recommend it's use in small businesses But... Keeping the necessary firewall, you are missing another component in a properly segmented network, a VLAN switch. It is highly customizable and gives you the configurability and speed you are asking for. Look at it's features here: ftp://downloads.netgear.com/files/FSxxxT_GSxxxT_smartswitch_UserManual.pdf The normal network security plan is: Internet -->Firewall-->Router (or Firewall/Router)-->VLan Switch-->Individual computers or VLan subnets. Using these two components together makes a more configurable and MUCH easier to setup network than using, say, one Sonicwall, or one CISCO PIX-501-BUN-K9 (which doesn't do VLan and you have to know Pix commands) You get FREE pre-sales and FREE post-sales support from Netgear, so call them on what makes sense for your situation. Sales Support (408) 907-8000 OR Email at: sales@netgear.com ZT3000 "Beta tester of "0"s and "1's"
Aug 03, 2007 | NetGear ProSafe FVS124G (FVS124GNA)...
Netgear JGS524 appears to be dead...
This is an un-mamaged switch, so it is very difficult to get any kind of diagnostic information out of it. Some times, this may mean that the switch is on and active, but at those times, there is some times a mode button to switch through the different types of indicators on the switch. This switch doesn't even have that. There is almost no documentation on this device. The only thing I could find was this install guide, and it doesn't mention anything about the lights indicating some type of diagnostic code. If you connect two machines to the switch, and both these machines have Static IP addresses (do not use DHCP), can they ping each other? If the can, then I say the switch is fine and its just a cosmetic problem. If they cannot, then I am afraid you will have to return this one as well.
Sep 18, 2006 | NetGear ProSafe JGS524 (DHJGS524NA)
NetGear ProSafe JGS524 (DHJGS524NA) Logo
866 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
