Question about Sewing Machines
HAVING TROUBLE THREADING FILM - ELMO FP-C
I just purchased a Elmo FP-C projector on EBAY. It looks like it was used very little. Would you please help me with two problems that I am having. The instructions that I rec'd with it are pretty good but doesn't cover everything. #1 It seems that the threading lever is stuck in the forward position. I am not sure if this is how it should be or not. #2 Having trouble threading the film. I clip the end of the film. Insert it in the threading slot. The sprocket picks it up ok but it won't go into the guide that takes the film on it's way to thread through projector.
Is your film super 8mm? If yes, then the red sprocket above the lens should be pushed in, and the bottom black sprocket will stick out. If you have regular 8mm, then the black bottom sprocket should be pushed in. If the sprockets are not in the correct position, push the green lever forward (towards the screen) then open the two orange tabs, then push in the correct sprocket. Once you have the correct sprockets aligned, close the orange tabs. How to tell if you have 8mm or super 8mm film: Look carefully at the film image. If the sprocket hole is next to the middle of the image, it's super 8mm. If the sprocket hole is between images, it's 8mm. If your green lever is stuck in the forward position, that's because the film is not threaded. Once your film threads correctly, the green lever will spring back.
Posted on Feb 04, 2013
  • 323 Answers
SOURCE: I am having trouble with the threading. It will
Do a tension assembly test.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Tension assembly test. To do this test. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.)
If it doesn’t work this way then you probably have a piece of thread or lint stuck inside the tension discs. To remove it, turn the tension to 0 zero and raise the presser foot.Using a small screwdriver, open the space between the discs and spray with canned or compressed air. The stuff should come out. Do the tension test again to make sure you got everything and then try sewing again.
sewman7
Posted on Apr 29, 2009
SOURCE: I am having trouble threading my minilock fr850
Well, the first thing is check the thread tension. (the part that you thread it through that has a knob on it). Grab right after the tension knob and pull gently. if the thread will not pull through easily, adjust the tension to a lower setting, pull out the thread, and try again until it will pull through fairly easily.
Posted on May 06, 2009
SOURCE: having trouble threading the needle, thread keeps
You might have either a tension problem or a bent needle. Try replacing the needle and then re-thread the whole thing and see if that helps. The majority of the time when I am having thread-breaking issues, once I replace and rethread, it is fixed. Hope this helps.
Posted on Feb 23, 2010
Tally Girl
  • 1122 Answers
SOURCE: new CE5500PRWBrother. having trouble threading
Have you tried hand winding the fly wheel towards you to bring the take up lever to the top of its cycle to thread it?
This does sound strange as most computerised machines the machine would stop at the top of the cycle so this should not be necessary. Is it possible that it has been damaged in transit.
Best solution is probably to ring the shop where you purchased it and talk to their sewing machine person about it, certainly if it is a fault it should be under warranty.
And if it is just a case of you learning how to use the machine, a reputable shop should always be happy to answer a question or spend five minutes showing you again how to thread the machine.
When I purchased my last machine, I think I spent an hour there having a demo first time, then went back again with questions and my fabric to test sew myself before buying.
Posted on Apr 08, 2011
Tally Girl
  • 1122 Answers
SOURCE: I have a White 7140
try http://www.singerco.com/accessories/instruction-manuals and search by typing in your model number. I couldn't see it there but there are other white machine manuals there so maybe one will give you help with threading. It sounds like the bobbin thread is not under tension, usually if the top is loose it is the bottom thread which is not tensioned and visa versa.
Posted on May 31, 2011
On GBC Ultima 65, I am having trouble with new film both top and bottom threading through cold heat rollers
I'd try listing this question under Office equipment, as this category is only for sewing machines.
Oct 27, 2016 | Sewing Machines
Nelco JA38 trouble starting
Please elaborate with the symptoms your machine is having. We can't help without any information.
Do you mean the motor is having difficulty running the machine? Are there difficulties getting it to stitch? Do you need help threading or winding a bobbin? Is it not moving the fabric through the machine???
Jun 02, 2016 | Sewing Machines
Would like to get a owners manual for my husqvarna 190 selectronic sewing machine. I am having trouble with upper tension and need to make sure I am threading it properly, any suggestions
Here's an ebay that has one for $ 15.00. There are others.
http://www.ebay.com/itm/Vintage-Viking-Husqvarna-Sewing-Machine-Operation-Manual-Optima-190-180-150-/191517822256?pt=LH_DefaultDomain_0&hash=item2c975a0d30
Generic threading:
START TO THREAD WITH PRESSURE FOOT UP. AS YOU THREAD GIVE LITTLE PULLS TO INSURE THERE ARE NO SNAGS.
1. Go from right to left.
2. As you feed you will come to the tension. Make sure it is fed through the tension disc or it won't work.
3. Feed through the take up lever.
4. Feed through the final holes to the needle. Final little pull to check for snags.
5. Put pressure foot down and give little tug. It should have some resistance, but not excessive. Usually four on the tension control is a good starting point.
6. Check your bobbin for pressure. Pull out the bobbin case and let it hang from your finger with the bobbin inserted. While you bob it back and forth it should extend one inch. Adjust the tension as you need to. Put one drop on the little ring under the case. (It looks like a race track).
7. As you use the machine you may have to adjust the upper tension as you need.
Feb 28, 2015 | Husqvarna Sewing Machines
THREADING FILM IN A ELMO FP-C PROJECTOR
Jan 10, 2013 | Sewing Machines
Threading bernette overlocker
have you tried the video's on youtube
Apr 06, 2012 | Bernina Sewing Machines
Needle only moves a little and then beeps saying needle up when the peddle is pushed. Machine will not run.
Good day Po!!!
Sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble; >Do this;
1.Top tension to tight >loosen tension 1 turn
2.Machine improperly threaded >check threading
3.Thread twisted on guide post > "
4.Thread twisted out of tension > "
5.Take up spring bent or broken >Check action of spring
6.Thread jumped off pull off finger >Check threading
7.Needle bent or burred >new needle
8.Bad cone of thread >try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tension spring to tight >Loosen tension slightly
2.Bobbin threaded wrong >check threading
3.Bobbin wound to tight or uneven >try new bobbin
4.lint or thread on bobbin case >clean inside case
5.Lint or thread inside hook >clean inside hook
6.Bobbin case nicked bent or burred >check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred >change
2.Needle set in crooked >Check
3.Thread jumped off take up spring >check threading
4.Thread jumped off pull off finger >check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth >Tighten bobbin tension
or loosen top tension.
2.forming loops on bottom of cloth >Tighten top tension
3.Bobbin placed in case incorrectly >remove and replace
4.Bobbin thread slipped from under >check threading of
tension >bobbin case
5.Lint or thread in top tension >clean between tension discs
Please just add a comment if you did not solve your problem by doing these procedures.
If this solution helps you please do not forget to testify and rate me...Thank you so much for using fixya!!
Jul 08, 2011 | Husqvarna Viking 1
Having trouble threading the needle, thread keeps
Feb 22, 2010 | Elna Sewing Machines
I'm having troubles with my brother sewing machine
Your tension is loose on top. Adjust your tension dial up a little at a time until you have a desirable stitch. Before adjusting the tension, you may want to look into the tension and see if there are any threads caught between the disc. If so remove them. Another common problem is that your machine is not threaded properly, make sure the pressure foot is in the up position when threading and if needed consult your manual for the proper threading diagram.
Jan 16, 2009 | Brother LS-2125 Mechanical Sewing Machine
I purchased a Euro-Pro Shark 998A but the B looks the same
Go to this address
http://www.euro-pro.com/europro/faqdetail.aspx?modelno=998B
It does not list a 9988A, but I would imagine there is not much difference in how the threading and bobbin is done. This is a page of instructions as well as a manual to download. The manual is in Pdf format, so if you don;t hae acrobat reader, you'll need to go to www.adobe.com/acrobat and download it for free so that you can read the pdf file.
Good luck to you and Thank you for using Fix Ya!
Aug 21, 2008 | Euro-Pro Dressmaker 998B
Sewing Machines Logo
85 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
