Question about Goldstar Refrigerators
My gold star refrigerator/freezer model no.GR-302FDS is not getting cold at the bottom section
catriver
  • 878 Answers
SOURCE: Amana bottom freezer/ refrigerator
Geezer, sounds like a defrost issue. I usually find the bi-metal to be the culprit on this model. Check out the pic. You will have to remove the back panel in the freezer and defrost the evaporator. Remove the ice maker if there is one. The back cover has 4 quarter inch screws. remove those. The air vent has 2 plastic clips one each side and one on the bottom, push in and pull the grill off. The thermistor cover has a slot for a flat blade screw driver,push in and pull the cover off. The thermistor will now slide behind the back panel. Check the bi-metal for buldging. As long as the evaporator fan is working, it's probably a defrost problem.
Posted on Jul 16, 2007
SOURCE: kenmore elite refrigerator, model # 59676534500
I went ahead and signed up for Sears' service warranty since I knew I had to get someone to come out.  IT costs $200/yr.  They say it covers everything, but when the technician came out, he told me that it just covers $500 per visit.  He said that a new motherboard and the labor alone was going to make it $498.  Anyway,   he had ordered a new motherboard. Apparently the motherboard wasn't working.  It is located in the back bottom left side of the refrigerator behind the panel.  There is a compartment on the lefthand side that slides out and houses the motherboard.  He put that in and also had to fix the fan that is in the back of the freezer.  That fan is the one that sends cool air up to the refrigerator part. When I had looked at the fan before the repair man came, it was not moving at all.  So at least take a look at the fan in the freezer.  Just take out the freezer drawers, and the fan is located in the top center of the freezer behind the compartment cover.  Maybe that's the problem with your refrigerator, the fan.  Hope that's all it is. Good luck!
Posted on Jun 25, 2008
SOURCE: Top freezer Freezes/ Bottom not cold
defrost problem. advance defrost timer to defrost (till it shuts off) . remove freezer panel, check voltage and amps to heater,if heater is hot, replace timer, if heater is cold and no voltage, replace defrost limit switch. defrost all ice, carefully! with hair dryer, no poking with screwdriver.
Posted on Nov 05, 2008
jumptrout51
  • 3361 Answers
SOURCE: the refrigerator section is not cold
Replace the freezer fan motor.
Posted on Feb 21, 2009
Maytag317
  • 1136 Answers
SOURCE: I have a Kenmore refrigerator (model 253.63732300)
Hi, Check in the freezer section and see if there is frost building up on the rear panel. Notice if the evaporator fan motor is running. If there is frost, you need to repair the defrost cycle.
Please let me know if this what you find so I can assist you further.
Vic
Posted on Jun 14, 2009
My gold star three door gr403s fridge isnt staying cold in the fridge section only. the freezer is fine but the middle chiller section is also having a few issues. Im not able to replace is as Im a pe
You might check this link for details that are similar to your fridge issue. Likely you do not have cold air fanning to the bottom compartment hence not cool. I assume your seals work properly and that it is a fridge internal issue.
Refrigerator Repair Not cooling properly freezing up on the back panel...
Feb 13, 2015 | Refrigerators
Can you tell me why please?
All the big cooling happens inside freezer compartment. Freezer gives little cool air to fridge compartment. Now when the vent blocks that little cold air cannot go into fridge compartment. Thus your freezer works good but not fridge compartment. Milk goes bad but frozen meet keeps good.....
Vent freeze up either due to defrost problemt, defrost drain line problem, Evaporator fan problem or even can be your damper motor not opening due to unit failure or frozen damper door.
Sep 19, 2014 | Whirlpool GX2FHDXVY Gold Stainless Steel...
The refrigerator isn't getting cold.... It is about 2 years old
IF the freezer is still cold, you have an air flow problem. This is usually a defroster problem or the fan in the freezer has quit.
Aug 27, 2013 | Whirlpool GX5FHTXVY Energy Star Gold 24.8...
Hi There, I require desperate assistance for my fr...
Throw it away and purchase a new one
Apr 14, 2017 | Refrigerators
Fridge Not Working
Your problem could be one of the following:
* compressor
* attachments to compressor (e.g.: relay, capacitor (if applicable) or overload protector)
* refrigerant (e.g.: restriction or leak)
* temperature control assembly
Contact an appliance service company.
Feb 19, 2010 | LG LRTBC1825T Top Freezer Refrigerator
Motor running, but freezer not freezing items.Second hand fridge was working from 10 Feb 2010 stopped freezing on the 19 Feb 2010 Gold Star GR 252 fds
First of all you have to check if the fan is working properly because this is the one responsible for "taking the cold out" from the evaporator and into the freezer
Jan 23, 2010 | Goldstar Refrigerators
I have a Whirlpool Gold Conquest Mod# GS6shexnt00 side-by-side. About 18 months after buying it the refrigerator section stopped getting cold but the freezer section still worked even though it had iced...
Yes, the difusser door is not allowing cold air to enter the fridge section, a fridge freezer is actually just a freezer, some of the cold air is drawn off from the freezer to chill the fridge protion, if the door is stuck, broken no cold air is getting to the fridge section
Aug 22, 2009 | Refrigerators
Refrigulator Malfunction
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 06, 2008 | Goldstar Refrigerators
Refrigerators Logo
46 people viewed this question
Top Goldstar Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
Are you a Goldstar Refrigerator Expert? Answer questions, earn points and help others
