Question about Dayton Gas Furnace Heater
Heating furnace blower won't stop - Dayton Gas Furnace Heater
  • Dayton Master
  • 2,557 Answers
Check out the afc could be dirty remove and clean back of it , or replace afc , also check fan on fan off settings on afc
Posted on Jan 11, 2013
Fan won't blow on ac, but works on furnace
The fans heat speed is low speed and the cool speed is high speed. High speed is controlled by the fan relay normally open switch, the low speed is controlled by the temperature delay or time delay.
see diagram
Jun 05, 2013 | Coleman Home Electric Furnace Eb15b/Eb15d
FURNACE WON'T TURN ON: I have a 1999 Fleetwood, Prowler RV. The furnace won't turn on.
Check the exhaust port of the furnace. Wasps like to build nests in there and it will not allow the furnace to ignite if blocked. You have a gas detector and it is turned on I assume? I forgot this many times.
Apr 20, 2013 | Heating & Cooling
Ruud gas furnace burners won't ignite
Remove the stat cover and jump out the red and white wires. If the furnace still doesn't come on, it is your t-stat. Replace it.
Mar 12, 2017 | Heating & Cooling
Furnace blower won't turn off
Does it have intell ignition?circuit board can be replaced easily and cheap if u do it yourself
Mar 18, 2013 | Heating & Cooling
Heil furnace blower motor stays on won't shut off at thermostat blows cold air continuously
Do you have t sat fan switch in on position??? If so blower will run continously set it to auto and it will cycle with heat call
Nov 12, 2012 | Heating & Cooling
Auto fan does not start electric furnace
see this causes and fix it. God bless you
If the furnace won't run, check the electrical service panel for a blown fuse or tripped breaker. Also make sure the power switch on or near the furnace is turned on. Check the unit for a reset button and try it. Some units have a built-in breaker or fuse panel.
If there is not enough heat, raise the thermostat setting five degrees to see if it turns the unit on. If the unit still does not generate enough heat, check the comfort controls . Clean or replace a dirty filter, clean the blower assembly (see the Forced-Air Distribution Fix-It Guide), and make sure that all registers are open and not blocked.
If the furnace turns on and off repeatedly (cycles), clean or replace the filter; and clean the blower assembly (see Forced-Air Distribution Fix-It Guide).
If the furnace is noisy, make sure access panels are mounted and fastened securely; spray squeaking belts with fan-belt dressing and replace worn or damaged belts; adjust the blower belt; lubricate motor and blower oil ports.
If the element does not heat, refer to the Heating Element Fix-It Guide for guidance.
Oct 08, 2012 | Coleman Mobile Modular Home Electric...
Furnace burner will not ignite
It could be the fan motor capacitor
Jul 15, 2017 | Heating & Cooling
My furnace and blower wont work but my pilot light is lit
It could be a number of things. Relay, transformer, bad motor, you either need a multimeter with a tiny bit of knowledge in order to track the voltage and find where it is stopping or a professional. Good Luck!!
Apr 30, 2017 | Heating & Cooling
Furnace blower won't stop running
Usually when the furnace blower motor runs all the time
The limit switch or rollout switch is usually open or bad.
The furnace board is seeing that one of those switches is open, so it brings the blower on to try to get the heat out of the combustion chamber area, so the switch will close. But if the switch is bad and won’t close, the furnace board will keep the blower running continuously.
Jan 04, 2010 | Amana Comfort Zone 12M32PBEH Air...
Dayton Gas Furnace Heater Logo
76 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
