Question about Armstrong H 67 1PH Bf In Line Circulator Pump
My pump is making a noise that I am trying to get rid of. I added the oil to the top of the pump (is this correct)? I have been trying to get rid of this noise for three days..please help
  • jhhay May 11, 2010
    Have you checked the coupler in the housing between the motor and the circulator? If not, take a look in there with the motor running and off, to see that all the springs and things are in place.
    If the pitch of the noise did not change when you added oil to the fill caps, then I would suspect the coupler.
    Problem Solver:
  • 7 Answers
You should call and contact Bell & Gossett .(847)966-3700 Address: 8200 N. Austin Av. Morton Grove,IL 60053. Ask them that if the part no # 103400 Price $260 fits for your pump Good luck.
Posted on Jan 24, 2009
When motor is running no noise from tappeds/rockers,when rpms is rising, rockers makes a noise and oil lite comes on
The obvious first thing to do is the check the oil level and make sure the level is correct. When is the last time the oil was changed? You might try changing the oil too. If you take it to a shop to have the oil changed, ask them if they can check the oil pressure to make sure the oil pump is working properly.
Sep 26, 2017 | Cars & Trucks
No oil to top of motor but 45lb at gauge rattels real loud
didnt specify yr-make -model-engine size engine but most engines like im saying most engines oil pump is at bottom of engine in the oil pan the oil pressure sensor may be sending out correct pressure but if sensor is down by filter/pump area thats where your going to get your reading ---the noise is your heads starving for oil problem can be sludge clogging oil from getting up to head ---oil filter collapse not correct oil for the vehicle or oil pump failing
Jul 25, 2015 | Cars & Trucks
Engine is making tapping noise at rear lower end
Drain oil and install correct amount, sounds like a lifter noise clicking sound not to loud just a steaddy tick, when you rev up gits faster right.....
May 19, 2015 | 1998 Toyota 4Runner
Mgb tappet noise
About 5 to 8 thousands clearance is standard. intake less than exhaust, (exhaust valves run hotter than intakes) If more than that, they will make noise. In rare incidences flat spots wear into a cam and cause noise and wear to the lifters. Check your oil pump for good pressure and run 20-50 oil. Drain oil during changes when it is hot to get rid of more sediment.
Jun 19, 2013 | Cars & Trucks
Runs great and a/c works great but makes a noise when you turn on the a/c like a bad alternator would make.
The bearing in the a/c compressor could be going bad. Try adding a few ounces of oil to the a/c to get rid of this noise by adding a small can of r134a with oil.
Otherwise, the compressor may have to be replaced to eliminate the noise, if it's worth it to you to spend hundreds of dollars on it.
I wish you luck on this repair.
Jul 31, 2010 | 1998 Volvo V70
I have to replace the oil pump, but the mechanic said that after i replace the pump the engine might still make noise. what can cause the engine noise after i replace the pump? how can i fix it? its a 1987...
Why replace the oil pump? That won't make noises go away or cause noises. Your mechanic should be able to answer theses questions, as to the cause of noises.
Mar 10, 2010 | 1987 Ford Mustang
Spinning sound when pushing gas peddle, sitting
try it with the belts off you can start it and see if the spinning noise goes away then it's accessory's like bad alternator or power steering pump but dont run it more than a minute or two or it will start to overheat. and if it still makes spinning noise make sure it's not coming from the transmission /use a broomstick against the engine block near each piston to hear the condition of the pistons if there scored real bad it makes noticable diff noise than a diff piston will make. check the front of the engin the water pump sometimes needs to be replaced because the bearing in it drys up and fails / there sealed bearings in a water pump than go make noise . good luck give you stuff to think about.
Nov 19, 2009 | Dodge Pickup Cars & Trucks
Oil light came on and there was a moaning tapping noise....... then the check engine light came on... then there was only a slight tapping sound... i added a qt of oil and tried to drive the car home and...
Was the oil low before you added any? What computer check? You went to a shop to have it scanned? Have the code issues repaired first then move on to the noise issues. Not a very new car I hope your not the original owner because you should not have these problems if you maintained it over the years and don't have 250,000 miles on it. If that's the case get rid of it
Sep 26, 2009 | 1998 Ford Taurus
Hard lifter noise after pulling trailer with Isuzu trooper 3.5L
Sounds like you didn't run the engine in. Check the oil for mangled main bearings.
Jun 14, 2017 | 1998 Isuzu Trooper
Armstrong H 67 1PH Bf In Line Circulator Pump  Logo
446 people viewed this question
Top Armstrong Plumbing Experts
Paul Carew
Andrew Bugbee
Are you an Armstrong Plumbing Expert? Answer questions, earn points and help others
